03-17-2020, 05:43 AM | #1 |
Drives: 2014 Camaro SS Join Date: Nov 2019
Gear oil compatibility for rear differential
I’ve read there is a service bulletin for the rear diff on 2010-15. It states dealer will change out gear oil with new synthetic oil, but the seals have to be replaced because the original seals are not compatible with the new oil. My 2014 SS has original seals, so I’m wondering, what aftermarket gear oils are compatible ??
03-22-2020, 02:24 PM | #2 |
Drives: 2SS/RS LS3 NPP Join Date: Feb 2018
I switched to Amzoil last year, no leaks on the original seals.
Taylor 409's, BF Comp 2's, Z26 pads, Hurst billet shifter
03-22-2020, 02:49 PM | #3 |
When you look for gear oil for it, they're all synthetic. You'd have to go out of your
way to buy conventional gear oil for it, like at a Walmart, or auto parts store. Having an LSD, you also need the friction modifier. Some brands will have it in there already. I haven't seen any TSBs on that, and from what I know, they're synthetic from the factory. |
03-22-2020, 05:15 PM | #4 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
The TSB was for '10 to '11 year models that had complaints of diff chatter. The TSB states to replace the axle seals because they are not compatible with the replacement fluid. Yours being a '14, you're covered under the TSB as well.
More to come. |
03-23-2020, 03:14 AM | #5 |
I don't see how seals can cause that, they just keep it from leaking out, and are
no where near the clutch pack. That's so odd, and even odder if changing them actually fixes the problem. I know fluid without the modifier causes it. Also, it says only in reverse when turning. So, why not forward, if it's seals? That's so odd... |
03-23-2020, 05:20 AM | #6 | |
SomeguyK
More to come. |
03-23-2020, 04:58 PM | #7 |
Really? The very beginning of the TSB says this:
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI. Condition/Concern: Some customers may comment on a chatter or moan type noise from the rear of the vehicle while making low speed turns. This condition may be caused by a slip/stick of the posi-traction clutch plates. As the plates slip and stick, a jumping or jerking feel occurs, accompanied by a chatter noise. Recommendation/Instructions. Caution: The rear axle seals must be replaced. The original seals are not compatible with the new fluid. So, yeah, they seem to indicate RIGHT there, the SEAL is the cause. They don't say in the first few statements, that the fluid needs changes to fix it, then in turn the seal also needs changed because it is incompatible with the fluid you're going to need to change over to. Just bad wording, or wrong order... First, it reads like the seals are the cause, then they go ON, to say you need to change the fluid... I know what the deal is, but that's not what it says initially. |
03-23-2020, 05:26 PM | #8 |
SomeguyK
Wow....ok.
More to come. |
03-23-2020, 07:16 PM | #9 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Either way.....I guess....unless you are experiencing issues, I would stick with what the owners manual recommends.
I changed mine to Lucas NONsynthetic w/friction modifier....no issues. But that's just me.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
03-28-2020, 11:36 PM | #10 |
Drives: 2011 2SS, 2006 GMC Sierra Join Date: Jul 2019
The 14 as well as my 11 came new with conventional oil in the diff. When I bought my car it had 56k on it with a slight chatter on slow turns. Most likely had the original fluid in it. I put a qt of royal purple max gear synthetic which has the additive in it already. I would say within a couple days it was gone. No leaks. Been in for 4-5k now
03-29-2020, 11:59 AM | #11 | |
'69 Owned Since '79
Drives: '69 Z/28 LeMans Blue w/White Join Date: Oct 2008
The seals are not compatible with the new fluid. Need to change the seals so they do not fail after the swap. I bet they have seen original seals leak if you do not change them when you swap the fluid. |
07-20-2020, 09:35 PM | #12 |
Going places
Drives: 2011 2LT/RS Victory Red Join Date: Oct 2010
So, because there is a TSB, is there a charge for replacing the axle seals?
"just stay with traffic, you'll be fine". = famous last words |
07-21-2020, 09:14 PM | #13 |
SomeguyK
There shouldn't be. If the vehicle fits the criteria.
More to come. |
