Old 02-23-2024, 08:06 AM   #1
CAMARO_HEAVEN
Big John
CAMARO_HEAVEN's Avatar
Drives: Wife 2013 Camaro 2SSRS / ME?
Front control arms
Can someone help me out I purchased the rear front control arms 23105014 and 23105015 when I received the parts they have 20951300 and 20951301 stamped on the actual part which is the numbers for the v6 and SS cars. I also ordered the front most control arms 23105018 and 23105019 and those have the actual part number stamped on the part. If someone could please let me know for certain on the rear front arms if the above is correct or not. Just want to make sure I did not get taken before the return period runs out.
Thank you very much
John
CAMARO_HEAVEN is offline   Reply With Quote
Old 02-23-2024, 08:49 AM   #2
NoDakZ/28
NoDakZ/28's Avatar
Drives: 2014 Z/28 CTF
Just a little confused, on all camaro rear suspensions we have an upper, and lower control arm not front and or most front control arms. If you are referring to the trailing arms or toe links then we can get a better idea. Non of your listed part numbers come up under the rear Z28 suspension. Upper control arms: GM 23110245 and 23110246, Trailing arm: GM 23104900, Toe Link: 22845487.
2014 1LE - Sold
2014 Z/28 #99008 CTF SIM
NoDakZ/28 is offline   Reply With Quote
Old 02-23-2024, 09:00 AM   #3
CAMARO_HEAVEN
Big John
Sorry for the confusion I guess they are radius rods which gm calls them front control arms. I am talking about the ones on the front of the car. On the z28 parts list here on camaro5 they are listed as control arms 23105014 and 23105015
Thank you
Old 02-23-2024, 09:05 AM   #4
NoDakZ/28
NoDakZ/28's Avatar
Thank you
Ah yes my apologies I thought you were talking rear suspension, those numbers are correct for the lower control arms and handling links.
2014 1LE - Sold
Old 02-23-2024, 09:12 AM   #5
NoDakZ/28
NoDakZ/28's Avatar
My guess whoever you purchased the lower arms from, saw that the z28 lowers are discontinued and sent you the SS arms.
2014 1LE - Sold
Old 02-23-2024, 09:21 AM   #6
CAMARO_HEAVEN
Big John
Yes that is what I think also. That is by I would like to know what is actually stamped on the real z28 arms. As I have researched and some say the arms are the same with different bushings. I don’t want to come off half cocked if these are real so that’s why I am asking.
Old 02-23-2024, 09:32 AM   #7
NoDakZ/28
NoDakZ/28's Avatar
I did find a used hub assembly from a verified Z and the part number you have is matching, you should be good!
2014 1LE - Sold
Old 02-23-2024, 10:36 AM   #8
CAMARO_HEAVEN
Big John
Attachment 1146911
Thank you for that info.
Have a great day
Old 02-23-2024, 12:54 PM   #9
Leadsled
Leadsled's Avatar
Drives: 2010 Camaro SS 6MT
Do you have the picture of the arm? I actually just did this mod, about a year about. They will come stamped the same as the SS arms However you just have to look at the bushing... The bushing will be painted red and/or they will have the White insert. Take pics. and I will confirm. or I have pics in my Journal build
TSP 229/244 .629"/615" CAM w/ a bunch of goodies 465whp/443tq tuned by MayhemMotorsports-NC
Leadsled is offline   Reply With Quote
Old 02-23-2024, 04:53 PM   #10
CAMARO_HEAVEN
Big John
Thank you.
I looked at your build thread and mine look like yours. I’m pretty sure they are real. Here are my pictures if you want to verify for my piece of mind.
Thank you so much.
