06-30-2018, 03:46 PM | #1 |
Drives: 2013 zl1 Join Date: Aug 2017
Track addict or Harry's lap timer
What kind of reviews do you guys have on these apps. What's better for HPDE and what Bluetooth dongle are you using. I went with this one
Sent from my HTC 10 using Tapatalk |
06-30-2018, 11:06 PM | #2 |
Drives: 2010 2SS/RS Join Date: Dec 2009
How does it work with the lap apps?
Orange Krush II
07-01-2018, 03:25 PM | #3 |
You have 1 of these apps, and then need a Bluetooth device to plug in to obd2 port and then use your phone to record driving on the track in the app and it will display some vehicle info along with the track map and gps follows you throughout on the map. Pretty sweet.
07-01-2018, 05:41 PM | #4 |
Drives: 13 Camaro Join Date: Oct 2016
TrackAddict is a 1000 times better. I've had both for more than four years. I still use TrackAddict. Harry's lap timer I used once.
07-01-2018, 06:23 PM | #5 | |
07-02-2018, 09:59 AM | #6 | |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
X = longitudinal Y = lateral Z = vertical Norm
'08 GT coupe 5M (the occasional track toy)
'19 WRX 6M (the family sedan . . . seriously) |
07-03-2018, 09:13 AM | #7 |
08-23-2018, 07:28 PM | #8 |
Drives: 2015 SS 1LE Join Date: Sep 2014
Does it have to be a phone or can you dedicate a small iPad? Don’t know if you need the cellular data for the gps to work.
09-23-2018, 08:59 PM | #9 |
Drives: 2013 Camaro 1LE 1SS Join Date: Aug 2012
Why is track addict better, can you shed some light?
I work for General Motors and am not an official spokes person for General Motors. My views and opinions are my own and not those of General Motors.
09-24-2018, 08:51 AM | #10 |
09-24-2018, 08:54 AM | #11 |
10-08-2018, 09:34 PM | #12 |
I tried track addict back in 2009/2010 and did not have good reaults. I tried several others and had some good results with Harryis but still has issues. I ended up searching again and Track Addict has a lot of good reviews and strong following so I have it another try. I really like it and they definitely took care of all the issues I had back in the day. I used to have three or four apps because they were so unreliable from event to event but now I have just Track Addict. For me the UI is simpler and it always records the track properly and never fails to start or finish at the start/finish lines.
http://www.camaro5.com/forums/showthread.php?t=344754 Summit White 2014 2SS 1LE Recaros, NPP exhaust, Nav 2010 2SS A6 - sold. |
10-11-2018, 11:52 AM | #13 | |
