Old 10-22-2010, 09:46 PM   #1
55Designs
Drives: 2010
Pedders CASTER Bolt Kits post up some more details on these.
I am very interested in buying the caster bolts that I think Pedders offers.
Does any other manufacture offer a caster solution?
I want to see photos of the notches required for the caster bolts and a basic idea of the process.
We got out car dialed in really good today but our caster is L=5.4 and R= 5.6 we kinda wanted to try to get it to the 7+ range to see how the steering feels.
Comments and suggestions please.
55Designs is offline   Reply With Quote
Old 10-22-2010, 10:07 PM   #2
Rob@WretchedMS
Drives: His Wife Crazy
i don't have any pics of the slots, but at the front of the radius arm where the bolt goes through to hold it to the sub frame, you will see that area is outlined from the factory. This is done so you know where to use a carbide grinder to remove the metal in that area. This is the same process that GM used on their struts to allow camber adjustment for years.
This allows you to install our eccentric bolt kit and make the caster adjustable. I believe the caster can be brought up in the mid 7s.
Rob@WretchedMS is offline   Reply With Quote
Old 10-22-2010, 10:24 PM   #3
55Designs
Drives: 2010
Thanks Rob i will have to take a look to see if I can view the imprint of where I need to notch. Is the steel single or double walled?
Do you have these bolts in stock? PM if so
Old 10-22-2010, 10:30 PM   #4
Rob@WretchedMS
Not sure on the single/double wall, sorry.
They are in stock, can ship out on Monday.
Old 10-24-2010, 06:15 AM   #5
sting808
Drives: 2010 SS RS
The front radius rod mount is single wall with a metal lip piece that's welded on for what looks like eccentric adjustments. I didn't put my front Pedders eccentrics on since I wasn't comfortable grinding it myself.
The metal lip plate for the mount area makes the metal twice as thick as the normal mount itself(on both sides). There is an old thread somewhere that DMS(?) highlighted how to grind for installation.
sting808 is offline   Reply With Quote
Old 10-24-2010, 11:18 AM   #6
Kilo-9
Dog Is My Copilot
Kilo-9's Avatar
Drives: 2011 2SS/RS LS3
This thread on the Pedders forum shows the grinding:
http://forums.peddersusa.com/showthread.php?t=863
Not sure if you need to be registered to view the pics...
Kilo-9 is offline   Reply With Quote
Old 10-24-2010, 03:39 PM   #7
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
You can see the pics. Not that I have any idea what the pics mean, but I can see them
[B]
Old 10-24-2010, 07:50 PM   #8
55Designs
Drives: 2010
Guys thanks for posting up that link showing the photos.
from reading that thread it seems G8 guys have a front pull and some Camaros which is why they used this caster adjustment.
Our car has zero pull and is straight as an arrow. Not too sure we would even bother since we drove 300 miles this weekend and the car feels great as is.
Can anyone here who has this done to their SS with a full suspension chime in as to what they felt after increases the caster with these bolts?
Old 10-24-2010, 08:31 PM   #9
Rob@WretchedMS
Increasing Caster will improve steering feel, steering return, turn in, and as a result performance.
Being able to adjust it will allow you to fix a pull if your caster spread is to high
Old 10-25-2010, 12:24 AM   #10
DMSDesign
Suspension Specialist
Drives: 2011 Camaro
Pedders has an install manual for the bolts. Not sure if they have it posted, but they have it.
mike
dms
DMSDesign is offline   Reply With Quote
Old 05-28-2014, 02:38 PM   #11
Hatebreed69
Hatebreed69's Avatar
Drives: 2010 Camaro 1SS
mike
dms
Can you still get these?
Hatebreed69 is offline   Reply With Quote
Old 05-29-2014, 08:14 AM   #12
jeremywes
jeremywes's Avatar
Drives: 2012 Camaro SS
Probably not but you can use an OEM rear bolt on the front. Not quite as good but better than no adjustment at all.
jeremywes is offline   Reply With Quote
Old 05-30-2014, 10:38 AM   #13
Hatebreed69
so from the pictures you can use the rear bolt. Do you have to shorten it?
Old 05-30-2014, 11:32 AM   #14
jeremywes
jeremywes's Avatar
They are the same length
Formal High-perfomance Education? Dan3 General Automotive + Other Cars Discussion 11 06-08-2020 01:52 PM
Camaro vs Corvette? Dr Jkel Chevy Camaro vs... 71 11-12-2010 01:39 PM
Pedders Suspension Benchmark Track Testing and New Jersey Track Day Info@PeddersUSA.com USA - NY / NJ / PA 35 10-26-2009 05:20 PM
Please Post Details from the Chats! jmliptak 5th Gen Camaro SS LS LT General Discussions 0 07-22-2008 09:06 AM
