03-23-2021, 08:17 AM | #1 |
Brake Caliper Bolt p/n
Morning,
I cannot for the life of me verify the part number for the SS 1LE front brake caliper bolt. This is the 6-piston Brembo setup. -------------------------------------------------------------- Part number: __________ ??
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8 Results: 470 hp / 447 tq |
03-24-2021, 02:16 AM | #2 |
front #11611085
rear#11570091 they are the same on all SS, SS/1LE, ZL1, ZL1/1LE
03-24-2021, 06:56 AM | #3 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Here’s another option from Screaming Chicken.
There non-TTY bolt an it’s a complete set. https://screamingchicken.com/2016-21...caliper-bolts/
Orange Krush II
03-24-2021, 02:33 PM | #4 | |
No way really? I just ordered these: 11570092 I'm not sure what i just purchased then.
03-24-2021, 10:41 PM | #5 |
same part just updated part number looks like. Few $ cheaper too.
05-05-2021, 09:29 PM | #6 | |
Drives: 2018 1SS Join Date: Dec 2018
Are the brake caliper bolts TTY on these cars?? I did not think those were.
2018 Red Hot 1SS, GM lowering kit & 1LE Sway bar kit, ZL1 1LE solid rear cradle bushings, BMR sway bar end links, GM CAI w/tune, Pray ported IM, Mamo ported TB, VS Forged VS07 rims 20x11 & 20x10 w/ Michelin PS4S
05-09-2021, 05:01 PM | #7 | |
Yes they are, as are alignment bolts too. *sigh
05-09-2021, 06:22 PM | #8 |
Brake caliper bolts ARE NOT one time use TTY. They are TTA or TA. Which means torque + angle. They can be cleaned and reused with Loctite per the service manual. I've done it many times.
First Pass: 150 N-m (111 lb ft) Final Pass: 15-30 degrees |
05-09-2021, 08:49 PM | #9 |
I love that I got two opposite answers to that question. I was at my local dealership this past weekend and they said that they reuse the caliper bolts as well. Not that that means much - not all dealership techs are superstars, but I would think they know the basics.
05-10-2021, 09:22 AM | #10 |
[QUOTE=Shawnqa800720;11007602]I love that I got two opposite answers to that question. I was at my local dealership this past weekend and they said that they reuse the caliper bolts as well. Not that that means much - not all dealership techs are superstars, but I would think they know the basics.[/QUOTE
Easy enough to access the service manuals and get your own answers like I do. www.repairprocedures.com |
05-13-2021, 09:47 PM | #11 | |
[QUOTE=carguy55;11007774]
Would be great if it were free, but needing to subscribe seems crazy in this age of information. Are there free options - open access to service manuals? I thought that was passed as legislation, but maybe that was just local...
05-14-2021, 10:05 AM | #12 |
[QUOTE=Shawnqa800720;11010122]I use the $15 for 1 day option and print to PDF everything I need
05-14-2021, 03:46 PM | #13 | |
Drives: 2017 1SS 1LE Join Date: Jun 2016
2017 SS 1LE.
03-02-2024, 05:50 PM | #14 |
BLEW BIU
Drives: 2018 2SS 1LE Hyper Blue Join Date: Oct 2017
