Old 05-06-2019, 12:43 PM   #1
SneakySS
OEM? Whats that?
Drives: 2014 Camaro SS Black Widow
Moving to Texas
What up People?!
Im moving from Louisiana to Texas soon and Im curious what the smog laws are. Any clues? I have cat deletes. Gonna be a problem?
Anyone know any trustworthy shops in the Dallas area??
2014 Southern Comfort Black Widow SS LS3
Magnuson Supercharger, ceramic coated ARH headers w/cat deletes, BTR blower cam, Mahle forged pistons, AEM Methanol injection, JRE 8 rib Super tensioner, Innovators West 8 rib serpentine pulley system, Melling high flow oil pump, Lingenfelter high flow fuel pump, McCleod RXT ceramic coated Twin disk clutch, Hooker BlackHeart exhaust. Escort 360 radar detector & dashcam.
Rockford Fosgate 1000w prime amp, 2X12” Rockford P3D2’s
Build and mods done by R&D Motorsports in Baton Rouge
Tune/Dyno done by ,,Engine Power Systems in Baton Rouge
SneakySS is offline   Reply With Quote
Old 05-06-2019, 01:58 PM   #2
SynergyGreenSS
SynergyGreenSS's Avatar
Drives: 2011 2SS
I have friends who have had a lot of success with Bailys hyperformance. They’re who I’ll be going to next tine I need anything done. As for smog laws, I have no idea as my car is still registered in California
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears
SynergyGreenSS is offline   Reply With Quote
Old 05-06-2019, 06:03 PM   #3
SneakySS
OEM? Whats that?
Thanks for the info. I’ll look them up.
Old 05-07-2019, 07:56 AM   #4
bkevind
bkevind's Avatar
Drives: 2013 2SS RS 1LE
Texas state inspection (emissions and safety) varies by county.
It's visual + OBD2 and short test drive (brakes etc)
Some counties are less restrictive than others.
468, Mishimoto rad + oil cooler, TSP LTH
MCS 2WNR
CTSV/ZL1 front calipers/rotors + G-Loc
Forgestar CF-5 19x11
bkevind is offline   Reply With Quote
Old 05-07-2019, 09:55 AM   #5
Vegas Bound
Drives: 2013 Sparkly Red One
If you are moving to the Dallas area, make it Denton county. Basic visual, drive and OBDII smog check. The shop that did my annual check knew my car and only did the OBDII.
As for performance shops, Anything Automotive in Denton is the place to go. Honest shop, they talked me out of doing things that wouldn't help or weren't needed on my car. How often does that happen? John, Jason and Frank are the best around. Their tuner, James, is a magician.
Vegas Bound is offline   Reply With Quote
Old 05-09-2019, 04:15 PM   #6
PepeLePew
PepeLePew's Avatar
Drives: 2010 2SS Coupe; 2011 2LT Vert
Anything Automotive definitely has some talent. Jason has built some crazy stuff and James is well known for his tuning. I live a little farther East down 380 so I take my car to True Street Motorsports in McKinney. Clint runs the shop there and he is incredibly helpful. He is personally a Ford guy and works on a ton of mustangs, but he and his team do all cars. On any given day there are 20-30 highly modded cars in the garage and in the lot. He has an awesome tuner as well.
What part of Texas are you moving to?
2010 2SS/RS LS3 - K&N, GM Performance Axle Back, Hurst Shifter, TSP 1 7/8ths long tubes no cats, TSP Stage 2 "Bald Eagle" cam, GM 3.91, 466whp/429tq
PepeLePew is offline   Reply With Quote
Old 07-20-2019, 06:49 AM   #7
SneakySS
OEM? Whats that?
Umm maybe Dallas area. Ive seen YouTube videos of Texas Camaro's with cat-deletes. WTF??!
Old 07-20-2019, 08:12 AM   #8
Vegas Bound
Cat-deletes, I don't know what you are talking about.
I have ultra high flow cats.
Old 07-20-2019, 09:01 AM   #9
SneakySS
OEM? Whats that?
I had those but I melted them into nothingness lol
Old 07-20-2019, 07:24 PM   #10
Vegas Bound
Not much inside mine left to melt, except air. Super ultra high flow cats.
Old 07-20-2019, 07:58 PM   #11
Roader
Drives: Camaro
I lived in San Antonio for few years so similar but different. You’ll be able to find a place to pass you if you search. Usually all local car guys know where to go
Roader is offline   Reply With Quote
Old 07-20-2019, 09:25 PM   #12
Vegas Bound
Denton County is OBDII only. No sniffer. No visual.
Old 07-20-2019, 10:37 PM   #13
Crankshaft
Drives: 2011 Chevrolet Camaro ss
Im in Houston area and have no cats either but my tuner tuned the ECM for this setup so no check engine light, my brother has similar setup on his Mazdaspeed3 and it passed emissions because the car reads no codes. FYI the sniffer is used on pre OBD2 cars(95) so anything after that gets only the scanner and if there is no codes set for higher pollution the car should pass unless you get a pesky inspector who will get on his belly to physically check for cats; tint will more likely keep you from passing since its easier to check. Welcome to Texas, former home of Whataburger. Some areas outside major cities only get safety inspections and nothing more, the testing depends on what area you register your new address as.
Crankshaft is offline   Reply With Quote
Old 08-09-2020, 04:27 PM   #14
TigerBanks
TigerrR
TigerBanks's Avatar
Drives: Camaro SS
living in Texas now but I`d say I am not about laws in that life xd
I wish you are feeling good cause Texas is a covid hot spot..
TigerBanks is offline   Reply With Quote
