03-16-2024, 12:14 AM | #1 |
Drives: 2005 C6, 2013 ZL1 2020 Ram Cummins Join Date: Jul 2015
Dash logic
It's me again😂🍺
2013 M6 ZL1 I've had a dash logic since I bought my car 2 years ago. I just finally got around to installing the flex fuel sensor tonight. The car has not been tuned yet. I don't see the pid for displaying alcohol (ethanol) content in the dash logic menu. Is this only available after it's tuned? I'm taking it to the tuner next week and I wanted the feature available to help them out and avoid any delays |
03-16-2024, 06:46 AM | #2 |
Drives: 2013 zl1 vert Join Date: Dec 2018
They have to turn the ethanol parameter on in the ecu first
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
03-16-2024, 12:16 PM | #3 |
03-18-2024, 08:49 AM | #4 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
Did you try playing around with the settings on the dash logic? It should technically read how much ethanol is in the gas. Even if it's minute amount.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
03-18-2024, 11:21 PM | #5 |
I did. I connected it to my computer and put it in config mode. The PID for alcohol content was not even present. I thought it should be there since it's just reading the signals the car is putting out. Without ECM having been tuned for E I would think it would just display zero.
05-08-2024, 02:33 AM | #6 |
Update. I contacted the dashlogic manufacturer and they informed me that v1.15 does not include the alcohol pid. They sent me v2.3 which has been working great.
05-09-2024, 10:38 PM | #7 |
Drives: 13' 1LE Join Date: Apr 2012
Dash logic is good stuff
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
