10-22-2011, 08:38 AM | #1 |
OKCamaros
Drives: 4 banger Diesel Join Date: Mar 2010
Headers Gasket.
Hey guys quick question I'm about to get my Headers installed and wus wondering if I need a new set of gasket for Headers or the stock ones are good enough? or should I get new OEM ones? cuz the my headers only came with some kind of a seal.
If I remember correctly someone here said that the Aftermarket ones leak and the stock ones are better? or do they mean OEM replacement? |
10-22-2011, 08:44 AM | #2 |
**Sold n' Sad**
Stock is best! Some headers (like TSP) include a set of brand new stock gaskets but you will be fine to reuse the factory one's you already have on there.
2011 Camaro 2SS, SIM, 6M, HUD, 10% tint, black out lenses, SS emblems, TSP 304 LT's, Roto-Fab, MGW shifter, gto res, 8K BFXENON, HP Tuners, Redline Fluids. ***Sold*** Now in an 11' F150 supercrew FX4.
Still addicted to the this forum |
10-22-2011, 08:48 AM | #3 |
knows 2 facts about ducks
Yes stick with the OEM headers. Either reuse your current ones or buy a new set from a GM parts supplier.
10-22-2011, 10:04 AM | #4 |
OKCamaros
thanks guys!
10-22-2011, 10:10 AM | #5 |
Drives: 2010 Camaro 1SS/RS Join Date: Jan 2011
Don't use the paper gaskets they suck!! I ran them bc they came with the headers I bought and ended up have to buy a new oem gasket for the driver side just to make it home then reused on old one for the other side!! Never thought my grandpa would be right, he always said "use the stock stuff till it breaks"!!
TSP Cam 231/236 112 LSA,TSP UD,Fast 102 w/Ported TB,AirAid CAI,1 7/8 catted Stainless Power LT,3 IN MBRP 3 in Exhaust/180*,Spohn LTA's,Toe Links, Drag Bar,Diff bushings,Hurst shifter,Hendrix/DSS 1400HP Axles,Nitto NT555R's,Lethal Performance Custon Tune 480 RWHP 454 RWTQ!! Best run so far is 11.94@121 LPE 3.91's Coming soon NW 102, and DSS DS, then car should be complete!!!
10-22-2011, 12:12 PM | #6 | |
OKCamaros
Mine came with like a rubber in a tube that when it dries it forms as a gasket. I think I'm just gunna reuse the stocks ones till they break. |
10-22-2011, 01:18 PM | #7 |
Good call. I wouldn't trust stuff that came in a tube
10-22-2011, 02:05 PM | #8 |
+1 on reuseing the factory gaskets or new oem gaskets. The aftermarket gaskets are usually junk. And there is nothing more annoying then a header leak.
10-22-2011, 02:19 PM | #9 |
White 2ss, LT, CAI, Tune
Drives: 2010 L99 Join Date: May 2011
+2 on factory gaskets... they are the best....
10-22-2011, 02:24 PM | #10 |
Drives: 1994 1LE / 2006 Z51 Corvette Join Date: Jul 2009
OEM gaskets. Just make sure to match the port on the gasket to the header port. GM has made both D shape and round port gaskets. Just make sure the gasket matches the exhaust you are putting on.
We have been using OEM header bolts and gaskets for years with zero issues. |
10-22-2011, 03:57 PM | #11 |
What they said. New OEM gaskets are what I recommend.
10-22-2011, 06:44 PM | #12 |
Camaro Owner Since 1987
Drives: 2011 2SS/RS L99 RJT Join Date: Jun 2006
I used the ones that came with my headers and so far they are working OK. I did keep the stock ones just in case.
Bill
2011 Camaro 2SS/RS L99 RJT
CAI, Inc. Cold Air Induction;ADM Scoop Rx Catch Can;Rx Breather;Roto-Fab Washer Container VMax Ported RJT Throttle Body XSPower Headers and XSPower 3" Exhaust System Elite Engineering Tunnel Brace, Gorilla Wheel Lock System; Bear Rotors, Hawk HPS Tinted Windows 35%;EFILive Tune |
10-22-2011, 06:47 PM | #13 |
Yes the OE gaskets are best. I usually hit them with a quick coat of copper spray. There are some great aftermarket header bolts available too.
Similar Threads | ||||
JBA Performance Headers | Mid-Pipes | Exhausts | V6/V8 | FREE S&H!!! | AJ@ECSMotorsports | V8 Bolt-Ons & Tunes | 100 | 11-13-2010 03:51 PM |
The truth about Shorty Headers | JoshJ81 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 33 | 02-20-2010 01:44 AM |
2010 Camaro American Racing Headers FREE Shipping | MoranoRacing | V8 Bolt-Ons & Tunes | 2 | 02-10-2010 08:45 PM |
Doug Thorley headers and axle-back ROCKS! | SPANKT U | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 13 | 01-07-2010 10:36 AM |
JBA releases exhausts, headers and midpipes. | Bewenched | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 17 | 09-16-2009 03:04 PM |
