Old 03-30-2023, 06:03 PM   #1
searay90
searay90's Avatar
Drives: 2002 GMC 2500 HD Duramax
WANTED: ZL1 OEM Fuel pump module (working or not)
looking for a 5th gen ZL1 fuel pump module to use for some experimentation. I am trying to see if I can create a Frankenstein fuel pump module for my 2006 chevy SSR (LS2 6MT).
I want to see if I can marry the top hat of my fuel pump with the down rods, and bucket from a ZL1 pump. That way I maintain the four connection points (1 fuel, 1 vapor canister, 1 pump power & fuel gauge, 1 fuel tank pressure sensor) on my top hat, but gain the ability to PWM control the high capacity fuel pump of the ZL1 module.
Want to figure this all out before I drop my tank and have the SSR down for an extended period of time.
I'm in the process of piecing together an LSA supercharger to install on the LS2 and want to have all my ducks in a row when it's time to install everything.
I will pay shipping if you happen to have one to donate to the cause.
If I can prove this will work, then I will buy a new ZL1 pump from rockauto and do the mods to my top hat. If I can't make this work, then its back to the drawing board.
Thanks
searay90 is offline   Reply With Quote
