Old 12-06-2023, 10:56 AM   #1
BlownC7
Drives: Chevrolet Corvette
Delete
Brand new never used SCE 4.150 Athena head gaskets.
CR191559L
CR191559R
Will work with 4 or 6 bolt blocks/heads. They will be good on any bore in the 4.000"-4.125" range.
If you aren't familiar with these head gaskets, they're about the best seal you can possibly get WITHOUT any machine work on the heads or block! I just ordered the wrong size, or I'd be using them.
Asking $320
BlownC7 is offline   Reply With Quote
Old 12-10-2023, 02:41 AM   #2
Ashen L99
Ashen L99's Avatar
Drives: Ashen grey, 1SS, L99
Pm sent
Roto-fab CAI, Nick Williams 102mm TB, LOD X1 V3 intake manifold, GMPP LS3 heads, Night Fury cam, TSP 2” long tubes, Corsa ZL-1 catback, Nitrous Outlet 102mm plate kit/150 shot, NGK BR7EF plugs with Taylor plug wires, DSX flex fuel kit, ZL-1 fuel pump and injectors, B&M deep trans pan, Yank 3400 converter, 3.45s with BMR Delrin bushings, mishimoto 169° Thermostat, GM ground effects, T-Rex upper grill, Z/28 Spoiler, Lolly pop Lime brake calipers, ZL1 10 spoke wheels, 12” subwoofer, and custom paint matched interior.
Ashen L99 is offline   Reply With Quote
