Old 12-30-2023, 03:45 AM   #1
booboo37
booboo37's Avatar
Drives: ls3 Mustang
New Gm L8T crank for Ls or Lt
New L8T 6.6 gas cranks ..... These are the better steel cranks found in the newer 2020-2023 gas Silverado and GMC HD2500 trucks and vans.... .Great stroker cranks for Ls…
$550 ..plus shipping.......60lbs with box from Mi. 48240
3.860 stroke
58x crank trigger
8 bolt flywheel pattern
Center counter weighted design
Ls iron blocks need clearenced slightly for the center counter weights,,,,,aluminum Ls blocks don't need clearance...
booboo37 is offline   Reply With Quote
Old 01-01-2024, 10:35 AM   #2
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
What would displacement be with one of these with stock rods?
Orange Krush II
Old 01-02-2024, 01:56 PM   #3
booboo37
booboo37's Avatar
Drives: ls3 Mustang
Can't use a stock rod unless you want Wiseco or someone to make a custom piston.........Mast Motorsports and Scoggin Dickey has Wiseco make them pistons for a 6.125 rod...............Some guys use 6.2 long rods and order a common piston for 4.0 stroke and 6.125 piston to end up at zero deck heigh......
You have a crank stroke that is .238" longer than the typical 3.622" of an LS, so your pin height has to move up in the piston by .119". The math does work out for a 1.12" pin height using an L8T crank and 6.200" rods length with a common piston for a 4" stroke/ 6.125" rod ........Got that ??
Old 01-02-2024, 09:35 PM   #4
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Huh no
Orange Krush II
Old 01-03-2024, 05:40 AM   #5
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
Based on the 3.86 stroke, 400 CID if you use 4.065 (stock bore) pistons. 402 if you hone it out to 4.07
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes.
