08-29-2023, 08:28 AM | #1 |
Drives: 2019 Chevrolet Camaro SS Join Date: Apr 2021
Procharger intake through hood
Has anyone on here done this? I asked the person that i saw on facebook and it and they never got back to me. Their post said they picked up 10-15 wheel, which i’m really worried about picking up power rather than pulling in cooler air.
And respectfully, i understand the argument that procharger engineers said it made no difference being over the header, but i really don’t see that as possible by any means, unless maybe they tested on a car with stock manifolds that still had a heat shield.
'19 Camaro SS | LT4 High Side and LT4 injectors | Fore Innovations Dual In-tank pump | Too High PSI Secondary Port injection (Not set up yet) | Holley Low Ram | BTR Stage 3 S/C Cam | Circle D 3600 Stall | Forged pistons and rods | D1X procharger, 3.85 pulley making 12 psi
08-29-2023, 09:26 AM | #2 |
Petro-sexual
Justin Keith did this on the C7 Z' he used to have. It was CLEAN.
'20 ZL1 Black "Fury" A10, PDR, Exposed CF Extractor Magnuson Magnum DI TVS2650R // RFBG // Soler 103 // TooHighPSI Port Injection // THPSI Billet Lid // FF // Katech Drop-In // PLM Heat Exchanger // ZLE Cradle bushings // BMR Chassis-Suspension Stuff // aFe Bars // Diode Dynamics LEDs // ACS Composites Guards // CF Dash // Aeroforce // tint // other stuffs |
08-29-2023, 02:11 PM | #3 |
Drives: 98 Camaro Join Date: Apr 2022
Got any photos?
08-29-2023, 02:54 PM | #4 |
yes photos please
11-18-2023, 07:37 AM | #5 |
Still never saw any photos of this. I can say that with the filter off and bellmouth on that the iat’s start out a bit higher than with the filter on. Flip side is that the bellmouth makes more power even on low boost
11-21-2023, 01:19 PM | #6 |
Drives: 2016 Camaro SS Join Date: Oct 2021
While I have the headers pulled off this winter I am thinking about wrapping them.
I wrapped my CanAm turbo back pipe this year and the reduction radiated heat coming off the pipe was pretty noticeable. The filter from the procharger is only about 6 inches from the headers, any reduction in under hood temps should help.
2016 Camaro 2SS 759whp 686wtq tuned by KingLt1
Procharger D1SC - Diamond Pistons/Manley Rods BTR stage 3 cam - Circle D converter American Racing headers - Borla S-type |
11-23-2023, 08:03 AM | #7 | |
Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
11-23-2023, 09:10 AM | #8 |
Honestly the Procharger kit that uses the stock airbox is probably the better option since the inlet is facing towards the front of the car. At the track you could easily pop off the airbox and put a bellmouth on
I always run the hood heat extractor open so I only see a few degrees above ambient temp when cruising. In traffic is where temps go up |
11-23-2023, 10:48 AM | #9 | |
Drives: 2016 1SS NFG A8 Join Date: Aug 2017
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA |
11-23-2023, 12:37 PM | #10 |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
Not sure if this is the build your talking about Justin has done so many. Hood open and hood closed.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
11-29-2023, 07:09 AM | #11 |
Oh ok cool thx for photo
11-29-2023, 02:05 PM | #12 |
I am going with Heatshield, looks like it offers better heat reduction and more durable than titanium wrap. I also get quite a bit of heat through the floor boards hoping this will help with that as well.
Tags |
forced induction, headers, intake, procharger, tuning |
