Old 04-18-2015, 10:42 AM   #1
rtclark82
Drives: silver 2013 ZL1 Procharged
18x10 wheels for sale
4-18x10 flat black wheels with 295/45/18 Nitto RRR tires. 95% tread left. not used long. $1,800 plus shipping unless in North Carolina or close to I could meet to deliver wheels/tires. Please let me know if interested? PM me or call / text 336-937-5367
rtclark82 is offline   Reply With Quote
Old 04-18-2015, 11:08 AM   #2
rtclark82
two of them have light scratches on the inside of the wheels (fronts only) where the stock brake pads rubbed putting them on. they fit fine you just may want to shave the ball off the front stock pad like i did after that or if you have replacement pads / race pads with no ball there will not be any issues. i can send pics if need be
Old 04-18-2015, 09:39 PM   #3
cvp33
America FVCK Yeah!
cvp33's Avatar
Drives: 2021 ZL1 1LE A10
Nice race setup for somebody! Great seller BTW!
cvp33 is offline   Reply With Quote
Old 04-21-2015, 08:10 PM   #4
camarossdusk
whippled 5th gen
Drives: 2013 camaro ss
If still have them for sell pm me very interested
Whipple running 13 lbs of boost, Innovators west 8 rib with 10 percent over drive crankshaft pulley. Fore level 2 Dual pump fuel system, with duel TI auto fuel pumps, ID 1300 fuel injectors, tuned on e85. Driveshaft shop aluminum driveshaft, 1400 hp half shafts, Detroit tru-trac. ls9 camshaft, CNC ported heads, with trunion and dual valve spring upgrade, LS9 head gaskets, ARP 2000 head studs, Manley stainless valves. Adjustable Bmr toe rods, trailing arms, rear adjustable sway bar, full cradle bushings, upper control arm bushings, BMR diff. bushings, bmr driveshaft safety loop.
camarossdusk is offline   Reply With Quote
Old 04-21-2015, 08:13 PM   #5
blk13
Drives: 2013 zl1
What rims are those?
blk13 is offline   Reply With Quote
Old 04-22-2015, 12:18 AM   #6
IOM Black Diamond
HT5 COTW 1/21/13
IOM Black Diamond's Avatar
Drives: 2010 Camaro Inferno 2SS RS 6M
Can you please pm me with more info on the wheels please. This is just what I have been looking for. Thank you
IOM Black Diamond is offline   Reply With Quote
