05-13-2024, 08:17 AM | #1 |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
Odd brake issue
Hey everyone this truly is an odd one. A handful of times after washing my car, using Adams Polishes wheel and tire cleaner on the wheels and tires and than parking it for a day or 2 the front brake calipers become stuck. When putting the car in reverse to leave the garage it take a lot of RPMs to get them "unstuck". And it almost becomes "unstuck" violently with a loud thud. Anyone else have this issues at all? The brakes function like they should afterwards. This has happened backing up and going forward.
2020 ZL1 A10 Shadow Gray Metallic
Magnuson Magnum DI TVS2650R| Mamo Throttle Body V2| RotoFab Intake| AWE Touring Catback Exhaust| TCM Tune| Tune| Eibach Pro| BMR Rear Cradle Lockout| PPF| Ceramic| BCForged HCS21 |
05-13-2024, 08:31 AM | #2 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
its rather normal for the pad and rotor combo on these cars. That moisture is going to lock them up if parked right way and allowed to sit. Ive only had one time that it was particularly hard to break them loose. I use the Z26 street pad and it's much less than the OE Brembo pad.
05-13-2024, 08:35 AM | #3 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
There was a guy on the FB groups that recently just posted something similar. Part of brake pad got stuck to the rotor.
Not sure if you're part of the 6th Gen ZL1 FB group but here's the post. https://www.facebook.com/groups/7188...7752343722852/ I've never had this issue but I use Carbotech 1512 pads. |
05-13-2024, 08:36 AM | #4 |
Probably doesn't like you
Drives: 2022 WCT ZL1 M6 Join Date: Jun 2015
Drive the car right after you wash it down, heat up the rotors / pads / calipers, or get some Atom-Mac and spray it on before you put it away.
I hope the 6th gen Camaro has a melodious horn trumpet. I'll tootel it at the ladies, yelling out "Hi hi." - RenegadeXR
كافر ΜΟΛΩΝ ΛΑΒΕ железобетонное очко Quod gratis asseritur, gratis negatur. There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly. |
05-13-2024, 08:40 AM | #5 |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
Don't wash the tires and wheels when the brakes are hot. Also, it helps if you move the car after you wash it rather than just wash the car and leave it sit. I pull the car out of the garage and wash it cold, then move it back into the garage and I never have this issue.
GM Gen V Calibrator
05-13-2024, 09:29 AM | #6 | |
05-13-2024, 09:30 AM | #7 | |
05-13-2024, 09:55 AM | #8 | |
05-13-2024, 10:32 AM | #9 |
Yeah very odd indeed.
05-13-2024, 03:37 PM | #10 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
Yep. This would happen on my last 3 cars, including this one. Just need to drive it around my cul-de-sac two or three loops before I park it in the garage.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp // CSP LT's & Ultra Cats // Elite Ultra CC // BMR MM
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
05-13-2024, 04:08 PM | #11 |
Snackbar Tuning
Same, and I still have OEM pads. Never had an issue. I would guess it may be the type of wheel cleaner being used and that its being liberally sprayed on the rotors too and maybe not being washed off properly.
GM Gen V Calibrator
05-13-2024, 05:07 PM | #12 |
fo'shizZL1
In my case, it's just water. Even if I just spray the car down with the pressure washer, it will do it. (I had the exact same thought and tested it.) Maybe it has to do with hard or soft water?
05-13-2024, 06:10 PM | #13 |
Snackbar Tuning
hmmm maybe, we have hard water down here in Florida
GM Gen V Calibrator
05-13-2024, 06:22 PM | #14 |
Drives: 2023 SS 1LE Sharkskin Join Date: Jun 2023
I think it could have something to do with it. I wash my car with only deionized water and then it sits for days, up to two weeks. There is visible rust on the rotors, but they have never seized to the pads.
ΜΟΛΩΝ ΛΑΒΕ
