Old 06-05-2023, 04:02 PM   #1
pjm333
pjm333's Avatar
Drives: 2013 Camaro ZL1 Convertible
P0033 Code
2013 CamaroZL1 Convertible
P0033 Turbocharger/Supercharger Bypass Valve "A" Control Circuit
Car was off the road on a trickle charger for 5 months and every year I get codes when I put it back on the road. Disconnect the battery and all is well but this year the P0033 code is sticking around.
The car runs & drives fine and looks like its the "Supercharger Bypass valve adjustment" Any help with fixing this code is appreciated. Thanks !
125 JRE 125 RWHP Package
pjm333 is offline   Reply With Quote
Old 06-24-2023, 04:35 AM   #2
pjm333
pjm333's Avatar
I had to replace the Bypass Regulator Solenoid, code is gone all is well.
Old 04-15-2024, 04:33 AM   #3
Sal329
Drives: 2008 Cadillac CTS
Since disconnecting the battery didn't resolve the P0033 code this time, it's likely a more persistent issue with the turbocharger or supercharger bypass valve control circuit.
I recommend checking the wiring and connections associated with the bypass valve to ensure everything is intact and functioning properly. If the issue persists, it may require professional diagnosis and potentially replacing the bypass valve or addressing any underlying electrical issues.
Read this guide about turbocharger issues, there you'll find plenty of possible causes and how to fix them.
Crystal Red 2008 Cadillac CTS 3.6 direct injection, Magnaflow X pipe, Borla Pro XS mufflers, LFX intake manifold, Airaid CAI, ported throttle body, W-1 oil catch can, LED daytime running lights and fog lights, FE2 suspension, 20" Camaro SS wheels
Sal329 is offline   Reply With Quote
