Old 03-04-2024, 07:43 AM   #85
X-max-X
@ max.i.s.cool
X-max-X's Avatar
Drives: 2015 1/LE
Originally Posted by The_bald_eagle_machine View Post
I love seeing other cars with Torqstorm superchargers. I love mine, and your setup is legit. Sorry to thread jack SlowLs1.
Appreciate that, brother! It's been a great unit for me
X-max-X is offline   Reply With Quote
Old 04-04-2024, 05:55 PM   #86
SlowLS1
SlowLS1's Avatar
Been a while since an update. Been putting a lot of hours in at work, but I do get to tinker here and there!
Body work is about 80% done. I don't have a current pic of the body work, I've done a lot more work on the strut towers and they look much better. They are covered now to protect them during the wiring phase.
Pulled off to work on wiring before pulling the motor.
Got my crossmember brackets fabbed up!
Probably be pulling the motor (what's left of it" in the next couple of weeks)
Still deciding on what short block I will be buying...
It's a long road, but I will get there sooner or later. Just trying to enjoy the ride! (except bodywork, I despise bodywork)
Brian
SlowLS1 is offline   Reply With Quote
Old 04-04-2024, 07:45 PM   #87
Bee
Bee's Avatar
Drives: SS/RS - Rally Yellow
Great job so far...I can't wait to see how it all starts to come back together!
Check out my build here.
SEPA5 South Eastern Pennsylvania 5th Gen Camaro Club
Bee is offline   Reply With Quote
Old 04-05-2024, 04:30 AM   #88
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
Looking great! I feel the same way about body work as well.. lol
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP
Ashen 6.2 is offline   Reply With Quote
Old 04-05-2024, 05:59 PM   #89
SlowLS1
SlowLS1's Avatar
Thank you sir. It's looking pretty rough right now, but I am certain it will come together in the end!
Old 04-05-2024, 06:01 PM   #90
SlowLS1
SlowLS1's Avatar
It got so bad, that I basically decided to stop and start wiring. It was depressing me to come home every day and see the mess I had.
I'm not good at it, don't want to be good at it. LOL
Old 04-06-2024, 04:51 AM   #91
acutron42
acutron42's Avatar
Drives: 2013 Camaro 2SS AGM
Looks great to me!!! You probably won't fully appreciate it until it has color on it.
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails.
acutron42 is offline   Reply With Quote
Old 04-08-2024, 01:22 AM   #92
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
When I was contemplating on what I wanted to do for my engine I came really close to buying this guy. They sell it in a few different compression ratios. https://www.jegs.com/i/ATK-Engines/059/SP73/10002/-1
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 04-08-2024, 11:27 AM   #93
SlowLS1
SlowLS1's Avatar
Joe, what made you decide against it?
Old 04-08-2024, 11:29 AM   #94
SlowLS1
SlowLS1's Avatar
I’m sure you are right. It does look better since we last talked about it.
Old 04-08-2024, 11:31 AM   #95
morepowerjoe
Mainly money, because it only cost me around $4000 to build mine.
Old 04-08-2024, 02:14 PM   #96
SlowLS1
SlowLS1's Avatar
I get it. I've been saving my pennies for a while now and while I haven't decided exactly what I am going to do. I prefer to only do it once. I'm open to all options at this point and appreciate post like yours. Helps me figure it all out.
Old 04-27-2024, 06:56 PM   #97
SlowLS1
SlowLS1's Avatar
Minor update. Been working on the engine harness and my OCD is killing me.
Today I got the top side wiring “done” but I am seriously considering redoing it. Not really happy with how the injector wiring laid out. Give me some honest feedback. Should I redo it?
That is the only wiring on top. Everything else will be underneath. My biggest gripe is the loops on the injectors. The heat shrink I have is rigid after shrinking.
Thanks,
Brian
Old 04-27-2024, 06:57 PM   #98
SlowLS1
SlowLS1's Avatar
Don’t mind all the disarray and mess. It’s a work in progress
