Old 09-04-2016, 12:24 PM   #1
Wtgrantham
Wtgrantham's Avatar
Drives: 2018 Red Hot ZL1 Convertible
One more tonneau........
I hate to drive on the highway with the top down as all that material flying around scares me, and I don't use my tonneau cover because the couple of times I did it almost pulled loose and flew out (I have the one that clips on with plastic tabs on the bolts)
So I have seen several different threads that people have submitted, like Velcro strips and elastic tie downs. So what is the ultimate solution?
Can somebody point me in the direction of the modification that will most secure that cover and allow me to feel secure that it won't fly away?
Thanks
Wtgrantham is offline   Reply With Quote
Old 09-04-2016, 12:45 PM   #2
Yknjack
Yknjack
Yknjack's Avatar
Drives: 2014 Yellow RS Vert
I have not experienced this problem in my 2014 vert and I use it a lot. It may be that it is tighter between the seat back and the top when I tuck in the leading edge of the tonneau cover. If that flap stays in it should not get air under the cover. Perhaps there is a way to make the front tonneau flap fatter adding some self stick foam to the underside.
Yknjack is offline   Reply With Quote
Old 09-04-2016, 05:22 PM   #3
GodWentPunk
GodWentPunk's Avatar
Drives: 2015 2SS White Convertible CE/INDY
I've got a 2015 and not experienced any issues. Mine has the elastic bands that are used to secure it to the back seat. After I tuck the little wings that are attached to the body of the cover, it all seems real secure.
ARH LTH/HFC/Legato muffler, RDP Custom Tune, K&N Blackhawk CAI, Bigworm Blackout kit, ZL1 Rims, Phantom Grills, VMAX PTB
GodWentPunk is offline   Reply With Quote
Old 09-05-2016, 07:26 AM   #4
NYCamOwner
"Katy"
NYCamOwner's Avatar
Drives: 2014 2LT A6 'Vert
The OP has the original tonneau cover which secures different than what Yknjack and GodWentPunk have. There are a few threads to convert the older clip on style to the bungee/post type.
2014 Black 2LT Convertible
Elite Engineering Catch Can, Vitesse Throttle Controller, CAI Cold Air Intake
Possible next mods:
Throttle Body
Exhaust
Upstate C5 Member
No, that is not me in the avatar..... I just love hot girls and hot cars.... or hot girls IN hot cars....
NYCamOwner is offline   Reply With Quote
Old 09-05-2016, 09:05 AM   #5
Mick
Mick's Avatar
Drives: 2011 2LT/RS M6 VR Convertible
I've had my 2011 for 5 years and always use the tonneau cover (with the v-cut plastic clips) and have never even come close to having it come off. Just check it to make sure it is securely fastened they way it was designed.
11/20/2010 - (1100) 03/07/2011 - (2000) 03/22/2011 - (3300) (TPW 3/28) 04/01/2011 - (3800) It is ALIVE! 04/06/2011 - (4200) 4/23/2011 - (6000) Delivered!!!
Mick is offline   Reply With Quote
Old 09-05-2016, 11:32 AM   #6
Larry_551
Larry_551
Larry_551's Avatar
Drives: 2011 1SS/RS Convertible
Greetings,
I had some minor buffeting when I first installed my tonneau cover, but after buying a wind deflector from Love The Drive all was good, nor more problems.
At high (legal) speed, the combination of deflector and putting the windows up pretty much eliminated any movement of the cover.
Just to make sure, I did add a few strips of Velcro at the front centre of the cover. I've never had any movement of the cover since.
Hope this helps,
Larry
K&N intake. Moroso air/oil separator.
McLeod RST twin disc clutch. Monster slave cylinder & bearing support. Stainless Works LT headers and high flow cats. Solo Mach XC cat back. Tune by DynoSteve.
Larry_551 is offline   Reply With Quote
Old 10-25-2016, 04:40 PM   #7
B-52 Guns
B-52 Guns
Drives: 2011 Inferno 2SS/RS convertible
2011 2SS/RS. I was concerned about the clips also. Told my dealer it was a safety issue so they gave me the newer one with the bands. That was about 3 years ago...
B-52 Guns is offline   Reply With Quote
Old 10-26-2016, 06:55 AM   #8
Baba
Baba's Avatar
Drives: 2011 Camaro 2LT RS Convertible
This may be the most helpful thread on modifying the tonneau cover with the tabs. The OP posted elaborate pics with explanations and instructions.
http://www.camaro5.com/forums/showthread.php?t=272309
Summit White
Black Leather
3 Pedals
Build Date: 06/27/2011
Purchased: 07/30/2011
Title Received: 08/15/2011
1984 Camaro (3rd Gen.): Traded: 1987
"Meet the new boss. Same as the old boss."
Baba is offline   Reply With Quote
Old 11-18-2016, 11:52 PM   #9
aquaholic
Drives: 2012 Camaro Convertible
Velcro solved my issues.
aquaholic is offline   Reply With Quote
