Old 04-17-2010, 05:01 PM   #1
silverfox
silverfox's Avatar
Drives: 2010 camaro ss
Procharger runs out of air
Just a headsup to procharger guys.
I've been running a procharger since aug 09 and have been building the motor around it since then. After all the mods i found that the stock procharger inlet filter would collapse at 550rwhp and my tuner removed it and went to 575rwhp so i had them put a bigger one on. This filter required removal of the stock brackets on the inner fender so if you want stock configuration read no further. It did give me 25 more rwhp with the install of the duece fuel pump from fastlane. Without it or simular larger filter you will be held up.
silverfox is offline   Reply With Quote
Old 04-17-2010, 05:16 PM   #2
ron10
Drives: 2010 2SS IOM L99
looks good.
Old 04-17-2010, 05:20 PM   #3
GQ4Life
Drives: 2010 Camaro SS LS3
good info.. wonder if anyother superchargers have that problem?
and people wondered why i put a big filter on my last car..
2015 Corvette Z06.. Lime Rock Park 1:01; Watkins Glen 2:14; Thompson Speedway 1:21
GQ4Life is offline   Reply With Quote
Old 04-17-2010, 05:25 PM   #4
Jeremy@HOB
Jeremy@HOB's Avatar
Although you'll always benefit from a larger filter you should not have had collapsing issues. We've built multiple 2010 Camaros making 500-650rwhp and all of them still run the ProCharger filter. This is the first instance I've heard of. Glad you got an easy fix for it though.
Jeremy@HOB is offline   Reply With Quote
Old 04-17-2010, 07:13 PM   #5
Andro
NOICE!!! ™
Andro's Avatar
Drives: Force Fed 427
+1 I'm running a slightly smaller air filter and she's running 774 at the wheels with no issues
Old 04-05-2011, 05:03 PM   #6
Kyle.Gilmour
Charter Circle Member
Kyle.Gilmour's Avatar
Drives: 427 LSX- with TWINS
What is the part number on that filter?
Old 04-06-2011, 08:06 AM   #7
Jason@RPM-Motorsports
Jason@RPM-Motorsports's Avatar
Drives: 98 WS6
This is the first I have heard also. We have done several over 700 rwhp and one that made 950 rwhp with a F1A and had no problem with the filter setup from Procharger.
Jason@RPM-Motorsports is offline   Reply With Quote
Old 04-06-2011, 09:46 AM   #8
flyby
Drives: 2010 Silver SS
I have about 700 to the wheels on a f-1 and have had no problems. Suggest you look into a larger intake, the supercharger likes more area to force air into, I have a fast 102
flyby is offline   Reply With Quote
Old 04-07-2011, 10:10 AM   #9
Andro
NOICE!!! ™
Andro's Avatar
My intake on a F1-R
Old 04-07-2011, 10:12 AM   #10
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
That's one big A$$ filter!! Glad you got her sorted out.
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 04-07-2011, 01:21 PM   #11
TC
TC's Avatar
Drives: 2010 VR 2SS-RS
Where did you guys route the tube to that goes into the end of the filter?
TC is offline   Reply With Quote
Old 04-07-2011, 01:21 PM   #12
GQ4Life
Originally Posted by Andro View Post
My intake on a F1-R
Sounds like time for test. Have someone lend u the big Ass filter & run dyno back to back 2 runs each
Old 04-07-2011, 02:20 PM   #13
Andro
NOICE!!! ™
Andro's Avatar
Yup tried to use the big cone filter but the blower closed it shut at WOT on the dyno so had to make my own filter and intake system for it
Old 04-07-2011, 04:16 PM   #14
GQ4Life
Haha too much power ..
K&N Engineering Typhoon Air Intakes & Filters | +18whp/18wtq | FREE S&H AJ@ECSMotorsports V8 Bolt-Ons & Tunes 120 11-01-2010 11:04 PM
NEW PRODUCT! K&N Typhoon Cold Air Intakes!!! MoranoRacing V8 Bolt-Ons & Tunes 2 12-28-2009 11:39 AM
Calling all Vendors with CAI's - PROVE Your CAI Gains! READ JANNETTYRACING Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 618 10-20-2009 11:39 AM
Bolt on 150+ Horsepower to your 2010 Camaro with ProCharger rt66 Forced Induction 7 08-27-2009 02:49 PM
