Old 04-27-2019, 10:48 PM   #1
Black 6.2L SS
Black 6.2L SS's Avatar
Drives: 2014 1SS/RS, LS3, NPP
Running same size 1LE wheels all around?
4 months ago I bought a black 2014, 1SS/RS with an LS3. Since it has the RS package it has the "midnight silver" wheels. They are decent looking, but I really like the black 1LE wheels. I'd like to buy some eventually.
I'm pretty sure my stock wheels are 20x8" (front) and 20x9" (rear) sizes. 245/45-20 (front) and 275/40-20 (rear).
Question: 1LE wheels are 20x10 and 20x11 sizes. As long as I'm buying, I'd like it set up so that I can rotate my tires. I don't track the car. Can four 20x10 1LE wheels be run on all four corners with the proper 285/35-20 size tire all around? Look okay?
Thanks in advance.
Black 6.2L SS is offline   Reply With Quote
Old 04-28-2019, 06:01 AM   #2
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
I run 20x10 on all 4 corners with 285/35 tires. Works great and handling is better.
Scott@Bjorn3D is offline   Reply With Quote
Old 04-28-2019, 09:09 AM   #3
Black 6.2L SS
Good to know! Do you have a pic?
Old 04-28-2019, 11:07 PM   #4
Rons1le
Rons1le's Avatar
Drives: 2015 Camaro 2SS RS 1LE AGM
1LE factory rims 20x10 are front only and the 20x11 are rear only do to there offset..
Sent from my SM-G960U using Tapatalk
2015 2SS RS 1LE NPP/w Kooks headers, Procharged, ID1050X injectors, Katech belt tensioner, Mighty Mouse Catch Can, BMR subframe connectors, Matco driveshaft loop, AEM Wideband/Boost/Fuel gauges , Z/28 Splitter and Spoiler/w Wicker bill, Power Stop rotors and brake pads, MRR Z/28 Rep Wheels 20" w/p zeros 285 fronts and 305 rears, ZL1 addons Rock guards and Tow hook, Rear window louvers, Flags on the quarter windows and the moonroof, Billet aluminum door handles.
Rons1le is offline   Reply With Quote
Old 04-29-2019, 10:06 AM   #5
jcampos
jcampos's Avatar
Drives: 2014 Chevy Camaro SS
GOOGLE my friend... It will look identical to a factory 1LE...
jcampos is offline   Reply With Quote
Old 04-29-2019, 10:23 AM   #6
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2019 Camaro 1LE
A lot of people run same size wheels and tires for track use and to be able to rotate tires. 20x10 with 285/35/20 seem to work for most people.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717
SSEssence is offline   Reply With Quote
Old 04-29-2019, 01:26 PM   #7
Black 6.2L SS
The reason I was interested in a pic was to see how the offset would look when running 1LE 20x10" front wheels on the rear of the car, (to achieve the same sizes all around; 285/35-20 on four 20x10" rims).
It sounds like guys run that way so any offset variation must not be too bad.
Thanks everyone!
Old 04-29-2019, 11:18 PM   #8
Zombie killer
Emerald Coast Camaros
Zombie killer's Avatar
Drives: 2013 2SS/RS L99
Although my go to wheel setup is 19x11 (305s square) , some events I am limited to 285s and I stretch them slightly on 20x10.5” rims. This is about as wide as you can go and keep the offsets the same for rotating. I had custom 4 mm plates made for the fronts to clear the Brembos on the style rim I chose.
Zombie killer is offline   Reply With Quote
Old 04-30-2019, 06:24 AM   #9
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
When Zombie Killer talks, shut up and listen, you about to be educated on some s**t. He knows his stuff when it comes to your car and setup.
Old 05-01-2019, 08:09 PM   #10
jksynergy
jksynergy's Avatar
Drives: 11 SW SYNERGY SERIES/14 1SS 1LE
You would be fine. The offset on the front 1LE wheels is +23. I run a 20x10 square setup on our 1LE with out any issues. My offset is +20 and no issues with clearance.
Sent from my SM-T377T using Tapatalk
2011 Summit White Synergy Series Edition, the hot innocent woman named Ava that we show off around town, dressed in white complete with angel's wings. Sold, but never forgotten.
2014 1SS 1LE. Bama, sporting Red Rock Metallic demon's horns, when we are ready to get naughty and open a can of whoopass! Airaid, Spectre, Xpel,Bowler shifter Peddars, UMI, Ult Perf. Diode Dynamics, JRE Tune, XS Power battery,
Hooker Headers Blackheart exhaust,Powerbrake
InstaGram & Twitter: @jlouie62
FB: hangtimeracing
jksynergy is offline   Reply With Quote
Old 05-01-2019, 08:33 PM   #11
Black 6.2L SS
Thanks.
I read on the 1LE section’s tire and wheel statistics that the front wheel offset is 23 and the rear wheel offset is 43. That sounds like a big difference.....so my original concern was that I didn’t want the front sized rims to not look flush (nice) with the rear fender lip.
(Awesome looking car by the way!)
Old 05-01-2019, 08:57 PM   #12
jksynergy
jksynergy's Avatar
Thanks.
They will be slightly in compared to our setup. I do run 285/35's all around also.
FB: hangtimeracing
Old 05-02-2019, 07:14 PM   #13
StingrayblueSS
StingrayblueSS's Avatar
Drives: 2013 Camaro SS
Thanks.
The 1le has a 20x11 on the rear with 43 offset and 20x10 front 23 offset. 285 tire all the way around.
StingrayblueSS is offline   Reply With Quote
Old 06-22-2019, 07:02 PM   #14
terry_b
terry_b's Avatar
Drives: 2014 2SS/RS 1LE
Send a message via MSN to terry_b
For my winter wheels, I run 20x10 23 offset on front and rear (which is the same as the OEM 1LE front).
Fit is perfect, the rear actually sticks out just a bit more on this setup. Should be a non issue if you are stock height, but if you lower it you might run into issues with rubbing on the plastic fender liner - mostly over bumps.
terry_b is offline   Reply With Quote
