03-29-2015, 08:48 PM | #1 |
Boosted Moderator
First startup...
Here is the first start up of my new ERL 417 cubic inch aluminum block motor. AllPro heads, custom intake manifold with a huge plenum and very short runners, custom exhaust manifolds, twin 76/75 Precision turbos, 225 lb/hr Siemens DEKA race injectors, solid roller cam, 10.5:1 compression...
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
03-29-2015, 09:06 PM | #2 |
Drives: 2010 2SS Join Date: Sep 2012
Wow....
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
03-29-2015, 09:22 PM | #3 |
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro Join Date: Oct 2013
That sounds awesome, should be a hell of a beast. Hope you can get it to hook. Throw in some pics of the engine when you can. Nice job.
03-29-2015, 09:47 PM | #4 |
Working on my 2nd one!
That sounds great Robert, I'm expecting to be doing that very same thing in mid - April!
Well I hope. Curt
[SIGPIC][/SIGPIC]
03-29-2015, 10:12 PM | #5 |
Drives: 2009 ZR1 Join Date: May 2010
That's audio porn to me
03-29-2015, 10:19 PM | #6 |
Very nice.
Nick
Corvette Z06 -1200ish rwhp |
03-29-2015, 11:29 PM | #7 |
'It's an experiment'
+1. Love it! And I know how that feels!
-Don
747 RWHP 794 RWTQ
03-29-2015, 11:44 PM | #8 |
Boosted Moderator
As requested... And I apologize for only one pic per post. Darn iPad...
03-29-2015, 11:48 PM | #9 |
Boosted Moderator
Another one... That is a 4" boost pipe feeding a 102 mm throttle body... Decided it was time to upsize from the factory original...
03-29-2015, 11:48 PM | #10 |
Damn, that is awesome! RJT color?
Can't wait to see some runs... -Don
747 RWHP 794 RWTQ
03-29-2015, 11:51 PM | #11 | |
Boosted Moderator
This is a Mile and more car... It's way too heavy and geared wrong for 1/4 mile passes... At full throttle I'll shift into 5th somewhere well north of 200 mph... Calculated to be right around 227 going into 5th gear...
03-29-2015, 11:51 PM | #12 |
Drives: 2011 Camaro SS/RS Join Date: Dec 2010
that sounds awesome!! only thing i didn't like about the video was when it ended haha. I look forward to seeing the numbers it puts down!
2011 SS/RS @ home 12/28/2010
03-30-2015, 12:05 AM | #13 | |
Wow... -Don
747 RWHP 794 RWTQ
03-30-2015, 03:44 AM | #14 |
Drives: 2010 zr1 Camaro 2011 vert Join Date: Apr 2013
Insane!......... Can't wait for the final numbers......... MPH of coarse
