Old 04-13-2024, 11:29 AM   #1
SS_CTS-V
Drives: 2015 SS, 2006 CTS-V (wrecked...)
Help! Can’t get oil pump off…
2015 Camaro LS3 manual transmission
Have the oil pan lowered about 1/4 inch, got the pickup tube unbolted from the oil pump. All pump bolts off, insides of the pump removed, but I can’t get the pump off of the pickup tube. There is t any slack or movement in the pickup tube at all, and I can’t rotate the pump body enough to get this done. Any tips?
SS_CTS-V is offline   Reply With Quote
Old 04-13-2024, 02:56 PM   #2
SS_CTS-V
Got it! Just had to use a small pry bar on the pickup tube, light pressure and it popped right out. Now to get the oil pan back on….
Old 04-13-2024, 07:57 PM   #3
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
Glad you got it off. I was going to respond but didn't know what to tell you because I've always had my pan completely off to change the pump.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is online now   Reply With Quote
Old 04-13-2024, 11:03 PM   #4
SS_CTS-V
I wish I had that option, but I’m working in my driveway on jack stands….
Old 04-15-2024, 07:36 AM   #5
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
Installed my cam in the driveway. The oil pump was my biggest issue. Came off ok. Install with the o-ring on to the pickup tube was tight and the angle would not line up. Thought for sure I would cut/damage the o-ring. Even used the aftetmarket girdle to help with the pickup tube. It was a struggle. I used feeler gauges to align the pump, primed it by removing the plug on the driver's side block. When starting, held the gas pedal to the floor. This is a flood condition that will allow the engine to crank and build oil pressure, without starting.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
Badbubba is offline   Reply With Quote
Old 04-15-2024, 10:28 PM   #6
SS_CTS-V
For sure, same issue for me, but I got it on and I have spare o-rings just in case. I'll be sure to prime before starting.
Unfortunately, I cross threaded the bottom bolts in the timing cover, so now I have a bran new one!
Old 04-16-2024, 12:12 AM   #7
morepowerjoe
You know you could always through a pair of CFD's crossmember flanges on there and get that oil pan of in the future.
Old 04-16-2024, 11:21 AM   #8
Trawz
Trawz's Avatar
Drives: 2013 Camaro 1LE
I will be tackling replacing my oil pump here in the next few weeks and would love to get a pair of CFD's crossmember flanges installed before hand to make the whole job much easier.
I reached out to CFD and yet to get a response.
2013 1SS/1LE
Corsa Extreme cat-back, Speed Engineering LT Headers with black ceramic coating, C7 Z06 Front Brake Upgrade, Mishimoto Oil Cooler, BMR Tunnel Brace, Mishimoto Oil Catch Can, MSD Plug Wires, Mishimoto Radiator and Hoses.
Trawz is offline   Reply With Quote
Old 04-16-2024, 03:41 PM   #9
SS_CTS-V
Let me know when you hear something. I can weld these in myself.
Old 04-20-2024, 12:19 PM   #10
SS_CTS-V
CFD replied, he’s still selling. I’m going to order a set ASAP
Old 04-25-2024, 11:02 AM   #11
Trawz
Trawz's Avatar
CFDZ replied, he’s still selling. I’m going to order a set ASAP
Really? I have not heard back.
I defiantly want a set to make changing the oil pump easier to remove.
2013 1SS/1LE
Old 04-25-2024, 11:18 AM   #12
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
May I ask the contact info? Thinking I may want a set for down the road.
0stones0 is offline   Reply With Quote
Old 04-26-2024, 08:01 AM   #13
SS_CTS-V
He's a member on here, just send him a private message. He was very responsive to me.
Old 04-26-2024, 03:58 PM   #14
0stones0
It don’t come easy.
0stones0's Avatar
Thanks! Appreciate it!
