04-24-2024, 08:48 AM | #1 |
Drives: 2011 Camaro SS Join Date: Aug 2023
Texas Speed 427 low NA power
Have a TSP 427 (LS3 based), however I'm not getting the power expected. Expecting 525-550rwph but only getting 488rwhp. Tuner was thinking possibly the cam is too small for the combo? Was a custom grind cam from TSP which was installed with the long block by them.
The real kicker here is the peak power is at 5900 then drops off which makes me think it may be a cam issue? I called Texas Speed tech support and the tech seemed confused as well and wanted me to check a ton of things that I feel like I shouldn't be doing since they built the long block... IDK, maybe I'm expecting too much lol. Wanted me to pull timing cover, confirm cam was degreed correctly, pull valve covers check rockers, measure/check for bent pushrods, pull heads and check lifters. Before I contact my salesman because I have no plans on tearing in to a 19k engine I paid them to build, wanted to check with you guys to see if you have any ideas/had an issue similar or see what I may be missing? Side note, this is an engine built for boost (F1A ProCharger) that is running NA atm. Engine was broke in using TSP break in procedures, break in tune, drove with break in tune while breaking in clutch (about 1000 miles or so), then dyno tuned which yielded low numbers. Below are details about the car and drive train 2011 Camaro SS Manual Engine- LS3 based 427 4.000 stroke, 4.125 bore PRC 260cc heads Rollermaster double roller timing set TSP Chromoly pushrods -11cc Wiseco forged pistons (equaling 10.7:1 Compression) Johnson 2110r lifters TSP Roller rockers Cam (See cam card attachment) Fuel Injection Clinic 1200cc injectors Stock LS3 intake and throttle body Texas Speed 2" long tube headers Texas Speed Mid and Axel back w/ TSP Mufflers TR6060 (Stock) McLeod RXT Clutch 1 Piece DSS Drive shaft 2013 ZL1 Cradle (Diff/Axels) 3.73 gears BMR poly cradle and diff bushings Any ideas would be greatly appreciated! |
04-24-2024, 09:16 AM | #2 |
I would be interested to know if your clutch is fully broke in and also what the dyno would say if correction was set to SAE. McLeod recommends something like 1500 clutch cycles and no reference to mileage.
04-24-2024, 01:22 PM | #3 |
I put well over 1500 clutch cycles. Most of that mileage is in town in stop and go traffic. I just started driving it to the gym everyday just to get the clutch cycles in lol.
04-24-2024, 10:56 PM | #4 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
Mustang dyno?
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
04-25-2024, 12:02 AM | #5 |
04-25-2024, 02:29 AM | #6 |
04-25-2024, 11:32 AM | #7 |
I mean they could have it loaded differently. But still kind of low for the combo that you have.
04-25-2024, 12:24 PM | #8 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
I don't think your expectations are unreasonable. You mentioned the engine was built for boost but that cam and compression seem like a healthy N/A combo to me. Maybe there is a head or intake component mismatch causing the power drop-off after 5900. That engine should be pulling hard up to about 6500. $19K and they want YOU to inspect and/or troubleshoot their build? I wouldn't be too happy either.
04-25-2024, 01:38 PM | #9 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
If this made 300-400 hp then I might would expect TSP to want the engine back to check it out. At those marginal somewhat low numbers, I'm not sure exactly what TSP can do from Texas. This could be a dyno/tuning issue as far as TSP knows. The fair compromise is that TSP agrees to have a local professional check things out and if something is found TSP pays for the inspection. If not it's on the OP. Otherwise motor needs to come out and sent back to TSP and cost is still on whoever was wrong.
04-25-2024, 03:23 PM | #10 | ||
^Agreed. The specs are close to my old polluter cam, and I made 490ish/500 on my sbe ls3. Quote:
Have tsp foot the bill.
04-25-2024, 03:44 PM | #11 |
04-25-2024, 04:39 PM | #12 |
Then of course op is on the hook.
04-25-2024, 05:06 PM | #13 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
I've been reluctant to say anything because I don't really understand what a ls3 based 427 is. I didn't even know you could bore out a ls3 to 4.125. Someone school me please.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
04-25-2024, 06:31 PM | #14 |
EDITED: The EXECUTIONER from TSP is a re-sleeved LS3 block punched to 427
