Old 04-18-2024, 04:42 PM   #1
SS_Dave
SS_Dave's Avatar
Drives: Chevrolet Camaro SS
Re-gearing
So, if you swap from stock 3.45 to 3.91 in an M6 car, is that going to throw off the speedo? Wondering if so, how much for considering having it corrected.
SS_Dave is offline   Reply With Quote
Old 04-18-2024, 04:55 PM   #2
gtstorey
http://www.csgnetwork.com/rgpspeedcalc.html
Old 04-18-2024, 04:59 PM   #3
SS_Dave
SS_Dave's Avatar
Uggg... Wasn't thinking about it. Now, I guess I need to add that to the bill $$$.
Old 04-19-2024, 07:54 AM   #4
The_bald_eagle_machine
Anthony S
The_bald_eagle_machine's Avatar
Drives: 2011 chevrolet camaro 2ss/rs
When I had my avalanche tuned, I told them the wrong gear ratio. I thought I had the 345 gears, turns out I had the 410 gears... Speedo was off by 10mph. Drove me crazy.
If you have a tuner who already tunes your stuff its fairly easy to flash a small change like that into the tune. They will probably hook you up for some beer money. Or if you don't have a local tuner, HP tuners credit is $100 plus the tuners fee for going in and making the change.
Follow me on instagram @The_bald_eagle_machine
https://www.camaro5.com/forums/showthread.php?t=600181
Mods: Texas Speed 2 inch headers, high flow cats, and X-pipe. Custom mid-pipe, Borla Xr1 mufflers. Torqstorm Supercharger, 3.1" pulley, ZL1 fuel pump. MGW Shifter, Mcleod RST clutch, Tick master cylinder and Tick Billet bushing reinforced slave cylinder. DSS One-piece 3.5" Driveshaft, Metco Driveshaft safety loop, BCRacing Coilovers. BMR Poly Diff bushings, Poly Rear cradle bushings, Sub-frame connectors, Lower control arms, camber arms, and toe links.
The_bald_eagle_machine is online now   Reply With Quote
Old 04-19-2024, 09:13 AM   #5
SS_Dave
SS_Dave's Avatar
Yep. I pinged the shop that previously tuned the car. They said no problem, they wouldn't charge.
Old 04-21-2024, 02:57 PM   #6
TheBrightSide
Drives: 2010 Chevy Camaro 2SS coupe (MT)
What software for tuning done?
I wonder what tuning/re-flash software they use… I’m aware of all of the flash tuners that we can buy, which are ALL OBDII-based, and simply function on a handheld flasher/tuner device.
I have yet to see one that doesn’t allow one to recalibrate for different gearing and tire/wheel combinations. Also, you can simply adjust only THOSE parameters and leave everything else as is, so you’re still basically stock ECU/ECM wise, only with a recalibration that doesn’t affect anything engine management wise.
I recently went with HP Tuners MPVI 3, and I love it; it’s just very complicated for some to learn, if you’re not a person who will take time to study the software and other car-related tech and computer tech stuff.
TheBrightSide is offline   Reply With Quote
Old 04-30-2024, 05:43 PM   #7
rdavis
Drives: 2012 SS
Most tuners will do minor updates for free of charge if they have already tuned your car. Or most all handheld tuners have the option to change the ratio for the speedometer.
2012 2SS/RS 6speed, Howards asa cam on 113lsa Stainless works LT's, NPP exhaust, Z28 Cai, 3.91 gears. Tuned by Blue Thunder 2 racing Lubbock Texas.
rdavis is offline   Reply With Quote
Old 05-13-2024, 06:01 AM   #8
AlecBlick
Drives: 2019 Chevrolet Camaro
Thanks for the info, I also want to know it. I was actually searching for this https://academized.com/thesis-writing-service website link online because I want to hire an essay writer because I am not so good at writing an essay assignment and that is why I always prefer to take help from an online essay writer. And when I was searching for it online, I also found link to your post as well.
AlecBlick is offline   Reply With Quote
Old 05-13-2024, 06:51 AM   #9
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
FWIW, if you're going to regear a naturally aspirated M6 car, there isn't much of a reason not to go to 4.10s...
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 05-13-2024, 07:41 AM   #10
MSgt O
MSgt O's Avatar
Drives: 2012 Camaro 2SS/RS Vert LS3/M6
Care to explain this for me? Whats the pros and cons? or perhaps just the pros it looks like??
MSgt O is offline   Reply With Quote
Old 05-13-2024, 08:10 AM   #11
acammer
acammer's Avatar
I actually have an article that goes into this in more detail:
https://gwatneyperformance.com/geari...1-manual-cars/
Old 05-13-2024, 10:00 AM   #12
MSgt O
MSgt O's Avatar
PERFECT!! Thanks!!!
