Old 02-16-2024, 12:32 PM   #1
jayd1
Drives: 2015 Camaro
2015 LS factory radio randomly turning off and on.
The factory radio has been randomly turning off, then back on. I found a thread where the factory radio had similar issues, the dealer had stated there were some possible soldering issues.
I removed the radio and found several solder connections that were questionable. There's a choke coil on the main board that is connected directly to the 12v + and 2 of the 4 soldered connections were possibly bad. There were also a few questionable connections where the wiring harness connector is soldered to the main board.
I re-soldered all of the questionable connections; the radio is working properly now.
jayd1 is offline   Reply With Quote
