05-07-2024, 08:42 PM | #1 |
Drives: 2016 Camaro SS Join Date: May 2020
So these pinch welds look normal?
So I recently got into another Camaro, a 2021 Camaro LT1 that I purchased from a dealer. I recently noticed that the front passenger fender has a crease in it. Also the there is a paint chip near the inner edge where it is also creased. So first thought was somebody lifted in the wrong spot. Got to looking under the car and there is a piece that the fender and rocker panel mounts to that is creased. Also the pinch weld on the passenger side looks weird, can someone tell me if this looks like major damage. The pinch weld has two half’s that are welded together, one half of the pinch weld is lower than other half. The driver side looks normal and both half’s are flush where they meet. Is it possible that one side of the pinch weld got pushed up by jacking beside it? I could look into pdr or just replacing the whole fender, but the pinch weld being compromised has me worried. Any input or experience would be appreciated, I see this has happened to a few people on here.
2016 1SS, M6, Summit White.
GPI Stage 4 cam, E85... MSD Atomic intake, dynatech longtubes, primary and secondary cat delete, ZL1 low side pump, cold air inductions cai, BC coilovers. |
05-07-2024, 09:16 PM | #2 |
Drives: 2018 Camaro 2SS A8 Join Date: Jul 2017
That pinch weld is "normal" unfortunately, they don't come flawless even from the factory and yours didn't "shift" either. The pinch welds on mine are better, but the two sides aren't perfectly aligned there either.
However, the rest of the damage, including the creased panel and the grossly misaligned door, are telltale symptoms of a lifting accident
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 |
05-07-2024, 10:45 PM | #3 | |
05-07-2024, 10:54 PM | #4 |
2020 Shadow Gray 2SS
Drives: 2020 2SS - A10, NPP, MRC, CAI Join Date: Dec 2019
I agree with arpad_m, the pinch welds may or may not indicate an issue but the other things definitely look like a bad lift by someone...
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Fender Badge, Footwell Lighting
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... BOTH are a lot of fun to operate... |
05-07-2024, 11:08 PM | #5 |
I bet they tried to lift it right on the rocker panel beside the pinch weld, cause the side skirts are cracked at the front underneath. That’s just unfortunate , my ocd is going to drive me crazy even if I can get the crease out thinking something is comprised structurally.
05-07-2024, 11:09 PM | #6 | |
05-07-2024, 11:24 PM | #7 | |
05-11-2024, 11:09 AM | #8 |
My PDR guy was able to get all the crease out, he did it for free too. Cause he see me a lot lol I can’t seem to find that piece that is bent up underneath the car. It looks like where the rocker and fender mount. I straightened it out, not sure if I should try to replace it or if it will affect anything.
Tags |
fender, jack points, lift damage |
