01-05-2011, 09:20 PM | #71 |
Drives: 2011 CGM 2SS/RS A6 Join Date: Mar 2010
01-05-2011, 09:35 PM | #72 |
I'm not totally useless..
C'mon, of course they do or they could never shift when turning! Ever watch F1? Ever since the intro of paddle shift they have always been on the wheel and move with it...
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
01-05-2011, 09:41 PM | #73 | |
Drives: 2SS/RS L99 BLACK Join Date: Apr 2010
http://www.camaro5.com/forums/showthread.php?t=116908. The tap shift buttons that GM uses can come apart fairly easy, with extended levers attached to them I can see where if bumbed with some force they could pop off. |
01-05-2011, 09:43 PM | #74 |
F1 cars as do most race cars have much different steering than do our Camaros, they require minumal turning of the steering wheel to make full turns.
01-05-2011, 10:17 PM | #75 |
01-05-2011, 10:19 PM | #76 |
Drives: 2018 Camaro 2SS Join Date: Aug 2010
I bought CFD's revised pistrol grip shifter with tap shift buttons. Hopefully installing this weekend. I don't think anyone's going to make a steering column mounted paddle set up.
Excited, this is a quality piece..
01-05-2011, 10:27 PM | #77 |
Drives: aqua 2ss l99 Join Date: Jun 2009
cant you invent a module for shifting that picks up your brainwaves like the movie "Firefox"?
cmon, you know you wanna.
May your exhaust note, sing in harmony with your blower.
01-06-2011, 09:23 PM | #78 |
bump!
when are these coming out?? |
01-07-2011, 06:55 AM | #79 | |
Drives: 2011 ss camaro Join Date: Aug 2010
just don't do it in russian.
10/28/2010 got it
02-01-2011, 05:01 PM | #80 | |
02-15-2011, 05:45 PM | #81 |
Drives: 10 IBM SS RS/14 1500 Z71 Join Date: Jan 2010
Are these ever coming out or did it fall through????
02-15-2011, 05:52 PM | #82 |
I called B&M the other day for shits and giggles and they said, "still in R&D"... Seems pretty simple to me. Can't see much R&D needed really, after you have a prototype....
02-15-2011, 06:11 PM | #83 |
Not trying to promote my products here but a few things I noticed with the prototype. First if you look at the size of the levers and how they are mounted and then look at how they would fit with the steering wheel mounted on the car there is not enough clearence between the levers and other controls (directionals, wipers, etc) Second I am very familiar with the switches and the way they are designed with large levers mounted on them it seems that if they were tapped or bumped haphazardly the outer portion of the switch could easily pop off or after continuous useage break. The switches are activated with a rocking motion by pushing on the outer edge, with the levers attached the motion would be more top to bottom possibly causing the switch not to activate and the last thing internally there is not a lot of room for fasteners so it may be possible that they are relying on adhesives or at least on the prototypes. Again I'm not sure but these are the things that caught my attention, they are all things that could probably be overcome but to take it from prototype to a working unit would probably need these issues addressed and that takes time, if it was that easy someone would have done it already I would think.
02-15-2011, 06:18 PM | #84 |
Drives: Dreaming Of the 2011 SS2 A6 - Soon Join Date: Feb 2011
Count me in.
Similar Threads | ||||
Super Sale on Raptor Shift Lights @ KY SPEED | FRCBobby | Audio / Visual / Electronics/ Gauges / Nav | 44 | 11-25-2011 10:34 AM |
Raptor Peformance Dual / Single Mode Shift Lights Now Available At APEX Motorsports!! | Apex Motorsports | Interior Parts & Accessories | 144 | 07-03-2011 09:14 PM |
Pic's of Aftermarket Shift Knob on Stock shifter stalk | jammer174 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 3 | 12-04-2010 08:49 PM |
Tap Shift When to Use | NoFatChx | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 2 | 03-24-2010 09:18 AM |
