Old 11-19-2010, 09:42 AM   #1
Pt_killa
Pt_killa's Avatar
Drives: Black 2010 Camaro V6
Stock Crank Pulley Pinned???
I've been building a cheap centri supercharger kit on my own for the past couple of months using parts I already owned. I built the whole bracket and tensioner assembly and had it mounted and running with a belt but forgot to check if the stock crank pulley is keyed to the crank. I wanted to ask the members of camaro5 if they knew before I pulled the crank pulley bolt or assembly off to check.
Pt_killa is offline   Reply With Quote
Old 11-19-2010, 10:03 AM   #2
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2016 Camaro SS
Stock pulley is not keyed to the crank. Most blower kits come with a drill/ream/template/pin kit to install.
Tony
Fquick.com/NineBall
Old 11-19-2010, 02:00 PM   #3
ROD1
Retired
Drives: 2010 Camaro RS V6 #1301 DOB 3/23/09
Tony
No blower kits for the V6. It would be nice if there was though.
ROD1 is offline   Reply With Quote
Old 11-21-2010, 11:34 AM   #4
Pt_killa
Pt_killa's Avatar
Thanks for the info nine ball.
I've been wondering if the crank should even have to be pinned since the kit won't be making too much power(aim 350-400rwhp tops) and the supercharger won't have to spin too fast. The only reason I asked was because I see the V8 vortech and procharger kits include a kit to key the crank. Any info or suggestions?
Old 11-22-2010, 12:09 PM   #5
Pt_killa
Pt_killa's Avatar
I notice a couple of motors don't pin the crank on some factory supercharged vehicles. That is the only thing that is holding me up so far. Heres the latest pic of the setup I have :
Currently, the volute is not sticking up and the bracket and supercharger has been painted black. Also, I added an automatic tensioner. The supercharger will feed into a fmic.
Old 11-22-2010, 12:15 PM   #6
ROD1
Retired
Pretty neat, is Trifecta tuning it?
Old 11-22-2010, 12:26 PM   #7
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
Sweet. I would still pin it. Have you checked with performance shops in your area to see if they can do it?
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 11-22-2010, 12:44 PM   #8
Pt_killa
Pt_killa's Avatar
Vince at Trifecta said he can do it. Shouldn't be too hard to tune since the hp/tq rise linearly and most of the boost comes in at high rpms when the engine can handle it the most. I'm going to check with some shops in the area for pinning. I originally had the blower running off of a pulley attached to the water pump but if I'm going to pin the crank I'll be looking to create or buy a custom crank pulley as well. The blower ran fine off of the water pump but im pretty sure the bearings on the pump will give out faster than stock due to the increased stress. I know ATI sells a replacement balancer for our cars. I believe you can bolt a pulley on top of the balancer to drive the supercharger.
Old 11-22-2010, 01:22 PM   #9
Demon Hunter
Demon Hunter's Avatar
Drives: 2010 Black Camaro LT
Can't wait to see how this one turns out....
Demon Hunter is offline   Reply With Quote
Old 11-22-2010, 01:52 PM   #10
Mach
Mach's Avatar
Drives: White M6 1LT RS
Looks great.. Keep it up!!! Cannot wait to see a SC run our v6's.
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done!
Mach is offline   Reply With Quote
Old 11-22-2010, 04:47 PM   #11
GretchenGotGrowl
Post dyno and track times when you get them.
Old 11-30-2010, 01:49 PM   #12
Pt_killa
Pt_killa's Avatar
Does anyone know if the LY7 engine is pinned? In one of the earlier FI thread "Capa Supercharger Install Manual", Capa does not have the owner pin the crank when installing the vortech V2. I know our engines are similar and GM's part catalog does not reference any dowel pin or key for LY7 engines. I prefer not to tamper with the crank if I don't have to.
Old 11-30-2010, 02:01 PM   #13
xx_ED_xx
xx_ED_xx's Avatar
Drives: 04 Silverado
I would highly suggest it. You also dont want the end of your crank snappping off either. If you can get me some good pictures of the pulley and then some good pictures of the end of the crank with the pulley off. I can give you some ideas. We double pinned them on the viper's.
xx_ED_xx is offline   Reply With Quote
Old 11-30-2010, 02:30 PM   #14
ROD1
Retired
Killa, I think Nineball thought he was in the V8 section.
DIY Noweeds exhaust diverter installation CanadianCamaro Camaro DIY & HOW-TO instructions & discussions 42 08-15-2016 11:11 AM
3.0 pulley and stock bottom end, go boom? Supercharged SS Forced Induction - V8 34 12-11-2010 08:54 AM
Over 230 Satisfied 2010 Camaro Customers! Paddock Chevrolet has 40 in stock NOW camarojoe Dealer Camaros for Sale 2 05-24-2010 05:58 PM
In need of a stock crank pulley litle88 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 04-15-2010 08:50 PM
Calling Shorty Header Owners Inferno2SS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 87 04-05-2010 01:59 AM
