Old 11-20-2011, 02:26 AM   #1
1BADZL1
THE CAMARO KING
1BADZL1's Avatar
Drives: 2012 Camaro ZL1 on order #PZSD7S
Question PTM MODE 3 & 4?
Modes 1, 2, and 5 seem pretty self explanatory...
Can anyone explain the two differences between PTM MODE 3 & 4?
MODE 3:[I] TC on "Sport 1", w/ESC "On" and MR set to "Sport"
MODE 4:[I] TC on "Sport 2", ESC "Off" and MR on "Sport"
2012 Camaro ZL1 Car Name: Bruce
ZL1, LSA, MN6/MG9, DSX, RTQ, VR,
Current Status:
2030
1000 Initial Order 11/11/2011 Chevyland
1100 Order accepted at dealer: 11/11/2011 - PZSD7S
2000 Order accepted by GM: 12/14/2011
3000 Accepted By Production Control: 00/00/2011 - TPW 00/00/2011
3100 Sequenced: 00/00/2011
3300 Scheduled For Production:0/0/2012
3400 Broadcast: 0/0/2012
3800 Produced: 0/0/2012
4000 Available To Ship: 0/0/2012
4200 Shipped: 0/0/2012
5000 Delivered To The Dealer: 0/0/2012
6000 Delivered To Customer:0/0/2012
1BADZL1 is offline   Reply With Quote
Old 11-20-2011, 02:42 AM   #2
MikeJrSS
MikeJrSS's Avatar
Drives: Black 2011 2SS/RS LS3
ESC = Electronic Stability Control. Stabilitrak in other words.
MikeJrSS is offline   Reply With Quote
Old 11-20-2011, 02:44 AM   #3
1BADZL1
THE CAMARO KING
1BADZL1's Avatar
Talking
Thanks. But not the answer I was looking for unfortunately.
Current Status:
2030
Old 11-20-2011, 02:51 AM   #4
1BADZL1
THE CAMARO KING
1BADZL1's Avatar
Also what are distinct differences between MODE 2 & 3?
I guess if one knew the distinct difference between "Sport" and "Tour"
we might be able to figure it out.
Current Status:
2030
Old 11-20-2011, 02:55 AM   #5
MikeJrSS
MikeJrSS's Avatar
Right well mode 3 is with the ESC on. This means you won't be able to slide to the sides as much because the computer will sense it and correct it by either applying the brakes or reducing engine power. I don't remeber which for the Camaro. The general purpose of ESC is to stop you from losing control, for instance if you mashed the throttle around the corner and started to get sideways the car would realize it and save you from spinning out.
Mode 4 is with ESC off which will allow you to slide the car around corners.
Hope that answers your question.
Edit: I'm assuimg with TC (which is traction control) "sport 2" would allow more wheel spin than "sport 1"
Old 11-20-2011, 03:06 AM   #6
MikeJrSS
MikeJrSS's Avatar
Generally softer suspesnion is better for daily driving. The bumps and what not in the road aren't felt as much. "Tour" sets the MR suspension to be softer.
In racing, stiffer is better. Helps the handling of the car around corners and such. That being said "sport" sets the MR suspension to be more stiff than the "tour" setting. Won't be as stiff as the "track" mode though which is in PTM mode 5.
Old 11-20-2011, 01:09 PM   #7
1BADZL1
THE CAMARO KING
1BADZL1's Avatar
Question
Thanks. This is more of the answer I was seeking. The difference between sport and tour.
Thanks so much.
So would launch control be mode 5 for running such as straight line correct?
Current Status:
2030
Old 11-20-2011, 04:12 PM   #8
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Thanks so much.
Yes, Launch Control is accessible when Mode 5 is selected.
This, from Chevy's ZL1 site:
MODE 4:
Sport; Active Handling Off.
For use by skilled drivers who are already familiar with a particular track. Dry conditions only. Requires more driver experience than Modes 2 and 3. Active handling is off and available engine power is still limited to match Mode 3.
MODE 5:
Race; Active Handling Off.
Requires more driving skill than in other modes. For use by experienced drivers who are familiar with a particular track. Dry conditions only. Active Handling is off and engine power is available for maximum cornering speed. Also for use with the ZL1 Launch Control feature on a prepared drag strip surface
Old 11-20-2011, 05:52 PM   #9
1BADZL1
THE CAMARO KING
1BADZL1's Avatar
Thanks dragon.. had not seen this..
Current Status:
2030
Diagnostic Trouble Codes (DTCs) for OBD II equipped GM vehicles steeleshark2 Tuning / Diagnostics -- engine and transmission 11 04-08-2020 10:49 PM
Sport Mode vs. Drive Mode vs. Manual Mode Velociraptor Dragstrip and Launch Techniques Discussion 82 10-02-2019 08:23 AM
Push Start button? CG'sSS Camaro DIY & HOW-TO instructions & discussions 158 06-06-2012 07:27 PM
has anyone read about the PTM? toilets Camaro ZL1 Forum - ZL1 Specific Topics 7 10-15-2011 08:43 PM
PTM Modes hairtrigger Camaro ZL1 Forum - ZL1 Specific Topics 6 09-12-2011 03:13 PM
