Old 12-22-2011, 10:36 AM   #1
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
ZL1 rear bumper
OK guys here is the rear, I do not have prices as i cant post a price if i had it you will need to do that.
New part # for the ZL1 bumper is # 22894196 there is no price as of today and non in stock, and you may need a new absorber too but i dont have a #
Parts you need:
#22894221 Fascia List:$129.76
#22895336 mud flap $33.64
#22895337 mud flap $33.64
#20952863 brackets $16.37
#22743862 brackets $7.58
#20952864 brackets $16.37
#20957052 heat shield $119.77
#20957053 heat shield $119.77
#22743863 brackets $7.58
#22743864 brackets $7.58
#22743865 brackets $7.58
And i say you need this.
#22846710 absorber $118.04
Some members dont think so but i say yes.
Jer4251
i wasnt able to install the 2 center bolts on the underside. they didnt line up with the absorber, i had to use some force on the 2 ends but they are installed.
Old 12-22-2011, 11:30 AM   #2
c_LoW29
Drives: 2011 2SS/RS, 2010 Mustang GT
so the lower diffusor wont fit on our SS bumper?
c_LoW29 is offline   Reply With Quote
Old 12-22-2011, 11:31 AM   #3
pyr0b0y
need....more....hp
pyr0b0y's Avatar
Drives: The Neighbor Hater
i do need a new bumper too...........hmmmm
Mast Motorsports Built LS3 Stroker 418, IPS GT35R Twin Turbos, Exedy GTO4XD Twin Disc Clutch, Aeromotive A1000 Eliminator Stealth Fuel Pump, AEM Meth Injection, DSS 1400hp Axels, BC Coilovers, Pfadt & BMR Suspension, Hawk HPS Pads, Drilled/Slotted Rotors, Hurst Shifter, Custom Roll Cage by Blu808, T3 Ports, 22" Custom Concave Mesh Rims
pyr0b0y is offline   Reply With Quote
Old 12-22-2011, 11:52 AM   #4
2SSRS@Gen5diy
How sad that?
There the same bumper.
Old 12-22-2011, 11:54 AM   #5
c_LoW29
So you are saying it does fit our bumper if that is the case I will buy one so I can put it quad tips
Old 12-22-2011, 12:06 PM   #6
twentytwelvebee
twentytwelvebee's Avatar
Drives: 2012/2ss "transformers edition"
so looks like we would need #s 10,15,16,17 for the diffuser?
twentytwelvebee is offline   Reply With Quote
Old 12-22-2011, 12:12 PM   #7
2SSRS@Gen5diy
there is a lot more then that, you will need # 18,19,20, may be 12,14 too
Old 12-22-2011, 12:14 PM   #8
twentytwelvebee
cool, thanks for the info!
Old 12-22-2011, 12:19 PM   #9
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
I'm hoping number 33 for the left and right side are a bolt on to our SS. If they are not too pricey I may get a pair and try. You think any other parts would be needed like #29, 30 and or 31 ??
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers, rotors & pads, BMR Trailing & Toe Arms, rear cradle & diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 whls, 275/40/20 & 315/35/20 tires, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console & Grant steering wheel.
flht99b is offline   Reply With Quote
Old 12-22-2011, 12:26 PM   #10
2SSRS@Gen5diy
Ed M.
They do.
Old 12-22-2011, 03:19 PM   #11
flht99b
flht99b's Avatar
Just checked with my dealer and he wasn't able to bring up any prices for #33 yet but the part numbers did show up so hopefully soon they will be available.
Ed M.
Old 12-26-2011, 12:06 AM   #12
Sevn86
Sevn86's Avatar
3100 Sequenced:10/12/09
3400 Broadcast:10/22/09
3800 Produced:10/27/09
4200 Shipped:10/29/09
Old 12-28-2011, 06:29 PM   #13
eclipsen
What about the rear spoiler? Will that fit a 2010 SS?
2010 Camaro 2SS/RS, 6M, ADM Race scoop, CAI intake, VMAX TB, Kooks LTs, Solo Mach X, MGW Shifter, Dynotech driveshaft, 1LE 3.91 gears with JRE updates, BMR bushings/Toe/Trailing Arms, Pedders ZL1 sways and XA Coilovers, Heritage Grill, Yenko side stripes, SS emblems, Havoc Rear Spoiler.
eclipsen is offline   Reply With Quote
Old 12-28-2011, 11:24 PM   #14
camaro2lt
camaro2lt's Avatar
yes it will
SS bumper cover installed on my 2LT/RS 01pewterz28 Cosmetics and Lighting Modification Discussions 60 01-15-2015 03:57 PM
Light burned hole in rear bumper HopeRidesAlone Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 1 12-03-2013 08:09 PM
List ZL1 Option Codes OldJedi Camaro ZL1 Forum - ZL1 Specific Topics 103 11-30-2011 07:25 AM
Great Motortrend Article - GM’s Reuss: Camaro ZL1 “Wait is Worth it,” IOMZL1 Camaro ZL1 Forum - ZL1 Specific Topics 21 10-10-2011 02:32 AM
Dent forming in Rear Bumper ambientweather Camaro Convertible Forum 3 08-01-2011 06:44 PM
