04-14-2012, 07:14 PM | #1 |
Fast Orange
Mild2Wild works on ZL1!
Over the last couple of days I have been working with Ed of LEEACUSTOMS on the correct installation of the Mild 2 Wild system for the ZL1. It is a snap to install by just replacing the exhaust flap fuse (F8). But due to the tight fit of the cover we had to go another route similar to the Vette option using the seat fuse. I did have to trim a small amount of the cover at the slot in the top side to allow the 2 wires room to exit.
Remove the 20amp radio fuse and install it on the fuse tap where the white wire was and plug it back into the radio fuse spot with the red wire facing down (so the fuse tap should have the 10A as it was, with the 20A in front of it), leaving the red 10A in the tap as is, Install the white wire with the red spade into the exhaust fuse spot using the bottom position. I will attach a pictures installed for reference. Also the sweetest part is the programming to Home Link is a breeze. Simply hold the Mild 2 Wild remote 1-3 in. from the Home Link buttons, then press and hold the ON button at the same time as the Home Link button of your choice until Home Link flashes rapidly. Then do the same for the OFF button. The system now operates stock in the ON position. And always open in the OFF position. It stays in whichever position you leave it in, even on restarts. Thanks Ed! |
04-14-2012, 07:17 PM | #2 |
Fast Orange
I forgot to mention that I think we have a forum vendor that carry's them.
http://www.southerncarparts.com/cama...er-p-4039.html |
04-15-2012, 02:13 PM | #3 |
Fast Orange
ZL1 Mild2Wild install
I posted in the modification section but started thinking that many people may not be looking in that section.
Over the last couple of days I have been working with Ed of LEEACUSTOMS on the correct installation of the Mild 2 Wild system for the ZL1. It is a snap to install by just replacing the exhaust flap fuse (F8). But due to the tight fit of the cover we had to go another route similar to the Vette option using the seat fuse. I did have to trim a small amount of the cover at the slot in the top side to allow the 2 wires room to exit. Remove the 20amp radio fuse and install it on the fuse tap where the white wire was and plug it back into the radio fuse spot with the red wire facing down (so the fuse tap should have the 10A as it was, with the 20A in front of it), leaving the red 10A in the tap as is, Install the white wire with the red spade into the exhaust fuse spot using the bottom position. I will attach a pictures installed for reference. Also the sweetest part is the programming to Home Link is a breeze. Simply hold the Mild 2 Wild remote 1-3 in. from the Home Link buttons, then press and hold the ON button at the same time as the Home Link button of your choice until Home Link flashes rapidly. Then do the same for the OFF button. The system now operates stock in the ON position. And always open in the OFF position. It stays in whichever position you leave it in, even on restarts. Thanks Ed. There are several vendors on this forum that carry the Mild2Wild controller. southerncarparts and GMpartshouse to name a couple. |
04-15-2012, 02:19 PM | #4 |
Drives: 2011 2SS/RS LS3 Join Date: Nov 2011
Good Lord!!!...lol.....You guys are modding these things already!!??...lol...Enjoy!!
We're all rooting for you! |
04-20-2012, 08:18 AM | #5 |
Just wanted to let everyone know we have these IN STOCK and ready to ship!!
04-20-2012, 11:03 AM | #6 |
Drives: Invalid Join Date: Aug 2010
Is there a video?
04-20-2012, 11:05 AM | #7 |
Working on one shortly
04-21-2012, 09:59 AM | #8 |
Are your exhaust valves open when the car is off? Or closed. Tried to install the mild2wild switch and the valves never moved. Is the zl1 different from the z06, where the valves are always open?
04-21-2012, 12:34 PM | #9 |
ZL1 #140
Drives: Camaros: 68 SS, 10 2SS/RS, 12 ZL1 Join Date: Mar 2008
I just ordered the mild 2 wild and pulled my fuse today. Fuse pull is perfect around town below 3k rpm. I'll most likely use the mild 2 wild as a way to reduce drone while cruising the freeway.
Good stuff! |
04-21-2012, 02:14 PM | #10 | |
Fast Orange
They are open when off, both stock and fuse pulled or switched. To see them closing you will need someone in the car to bring up the RPMs. If you have it installed you should be able to hold the rpms at 2000 and hear it opening and closing with the switch. |
04-21-2012, 04:08 PM | #11 |
Maybe our exhaust is broken. Haven't seen the valves open or close at all. Revving from idle, even when the fuses are put back to stock. Kinda disappointed. Anyone have a video of their zl1 that can demonstrate that it actually works? Did a straight fuse pull and it didnt seem to change the exhaust tone at all. No change at idle, no change during normal driving.
04-23-2012, 01:26 PM | #12 |
Drives: 2006 Silverado SS, 2009 G8 GT Join Date: Aug 2008
Still no video...... Geesh hurry up people!
04-24-2012, 11:27 AM | #13 |
Drives: 2SS/RS - Black - GFX Join Date: Nov 2008
Well guys,
I had a DIY post in this thread about how to do this mod yourself without a $100 M2W electronics box... That's fine, but the mods need to delete the entire DIY section if that is the case.
Ordered: 10-13-08
Built: 3-30-09 (#1691) Recieved: 6-12-09 Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods. Last edited by Bell040; 04-24-2012 at 08:54 PM. |
04-25-2012, 09:28 PM | #14 |
Drives: 2012 Victory Red ZL1 MG9 Join Date: Mar 2008
I had one installed today. The same one used in my Z06 vette. They replaced the fuse in the back rear qtr panel with the mild to wild. Taped the remote transmitter to the fuse box so it wouldn't rattle and works perfect. Purchased and installed at Corvettes of Houston.
Similar Threads | ||||
Transcript of Camaro ZL1 Q&A Webchat with Chevrolet | Tran | Camaro ZL1 Forum - ZL1 Specific Topics | 42 | 12-22-2017 04:42 AM |
2013 ZL1 Most Powerful Chevy Convertible Ever... | Abstrak | Camaro ZL1 Forum - ZL1 Specific Topics | 1 | 03-08-2012 08:21 PM |
Thinking Ahead: SSX Wheels and other tire and rim alts for ZL1 during cooler months | 1BADZL1 | ZL1 Wheels/Tires | 31 | 12-27-2011 08:40 AM |
2012 Camaro ZL1 Price Announced at $54,095 MSRP ! | TLSTWIN | Camaro ZL1 Forum - ZL1 Specific Topics | 735 | 12-20-2011 08:48 AM |
Need help with order please | zfuzz | Camaro ZL1 Forum - ZL1 Specific Topics | 7 | 11-22-2011 06:40 AM |
