04-20-2024, 04:24 AM | #1 |
Drives: 2015 V6 LT (RS Package) Auto Join Date: Jun 2018
Camaro 2015 A/C issue
Hi Everyone,
I have had trouble with this car A/C since I bought it 5 years ago, replaced the compressor 2 times, replaced the evaporator, and bypassed the heater, but still when the heat of the summer hits hard in Dubai, the cooling is not good. Lately I noticed that the compressor cycles on about 10 seconds and cycles off 10 seconds, is that normal in Dubai in the summer? Also I noticed that the temperature dial has no effect on this compressor cycle, whether I set it to Max cold or Max hot, the compressor still works 10 seconds and shuts 10 seconds, is that normal? Now I understand that my heater is bypassed, so I don't get any hot air when I set it to hot, but still the compressor should work less when its set to hot and more when it is set to cold, right? Thanks in advance, Last edited by Elgeweily; 04-20-2024 at 04:26 AM. Reason: Typo |
04-20-2024, 08:03 AM | #2 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
Have you read the reams of material on Camaro blend door issues? But since you bypassed the heater core, I supposed even a broken door shouldn't matter. Unless having a door that isn't in the proper position might be letting too much warm air from the sun beating down on the dashboard. Not sure about that though.
However, a short cycling compressor is a sign of low refrigerant. On Tuesday, I will be able to confirm whether my SAME issue can be corrected by adding R134 and servicing the AC system.
04-20-2024, 08:21 AM | #3 |
Drives: 2013 Chevy Camaro 1LT Join Date: May 2022
I was having a similar issue on my 13 camaro. My shop replaced the expansion valve and the issue went away. If the expansion valve isn't working correctly, it can make the system act like there's not enough coolant.
04-20-2024, 09:49 AM | #4 |
It don’t come easy.
First I’ve heard this. Very good to know.
04-21-2024, 04:59 AM | #5 |
I forgot to mention that I just recently flushed and refilled the coolant....so this can't be the issue.....so I get from your responses that what I am having is a short compressor cycle, but that doesn't explain why it's not affected by the temperature dial.....could there be something faulty that prevents the climate control setting from controlling the compressor cycle, like it could be stuck on a medium setting, regardless of what I set it to?
Tags |
camaro gen5 a/c |
Thread Tools | |
