04-15-2010, 08:07 PM | #1 |
Drives: 2010 IBM Camaro SS Join Date: Jun 2007
DIY: PDIM + USB Port installation
I installed the PDIM and USB port on my 1SS. I haven't yet got the software update so the radio doesn't recognize anything I plug in there.
The instructions that come with the PDIM are pretty good but the pictures aren't always clear so I took a few to help out. Tools Needed: 9/32 socket/driver Small Flat Blade Screw Driver Optional: Needle nose pliers Note: On an automatic you need to have the gear shift in D to do this and have the E-brake on. 1) Lift up on the console top cover and disconnect the wiring harnesses for Traction control, power socket and gauges. (Use something to pry it up if you cant get it with your fingers) 2) Remove the four screws fixing the gear shift to the center console. (They are in the white plastic parts) 3) Pull the center console side trim on each side outward to release the clips and remove the trims. 4) Remove the screws on each side of the console rear end cover. There should be 2 on each side. (move seats forward so they are visible) The instructions say to remove the armrest as well but I did not have to do that to proceed) 5) Disconnect the wiring harness from the aux jack and power socket. Release the clips on each and push them through into the console compartment. 6) Remove the screw at the front of the center console on each side. 7) Remove the screw just behind the gear shift in the center console. 8) Remove the 3 screws at the top rear of the console 9) Carefully lift and work the console over the gear shift assembly and remove it. Note: For automatics you need to release the 3 clips that hold the gear shift assembly to the base. (The clips are white plastic and a bit tough to release) 10) Disconnect the wiring harness near the E-brake 11) Remove the 2 screws at the rear of the console that fix it to the floor of the vehicle. 12) Lift from the rear and remove that portion of the center console 13) Remove the existing wiring harness from the part removed in step 12. (It is clipped in, you do not need to cut any tape etc) 14) Install the replacement wiring harness using the built in clips. 15) Clip the PDIM module into this console part. 16) Connect the 2 connectors to the PDIM module Now you are ready to reinstall the console and close it up. You will need to insert the USB plug and Power jack after you get the console portion back into the car. After that make sure you hook up the 3 connectors to these items. |
04-20-2010, 05:43 PM | #2 |
Update: I got the programming done today and it works perfectly. The dealer didnt know what software update to do so I gave them the info and they had no trouble.
04-20-2010, 05:52 PM | #3 |
SoCal Mayhem
Drives: 2010 Camaro 1SS/RS Join Date: Aug 2008
Great write up and pictures
What version software is your radio/PDIM running?
04-20-2010, 05:55 PM | #4 |
Darth Martel
Drives: Black 1SS with 20% tinted windows Join Date: May 2009
sweet man... glad I just found this as I should be getting mine in tomorrow. Will be my project for next week.
04-20-2010, 06:44 PM | #5 |
04-20-2010, 06:54 PM | #6 |
SoCal Mayhem
While in USB mode, press and hold the menu button, the radio will display the software and hardware versions.
04-20-2010, 07:15 PM | #7 |
It says:
HW ID: CC SW ID: CE |
04-20-2010, 07:16 PM | #8 |
SoCal Mayhem
05-01-2010, 09:06 AM | #9 |
Darth Martel
Thanks for the write up... just did this and it really helped a lot. Now to install the steering wheel controls.
05-01-2010, 09:44 AM | #10 |
Drives: 1968 Bronco,2001 Fatboy,2010 SS Join Date: Jan 2010
What was the total cost and part#'s ?
05-01-2010, 09:57 AM | #11 |
About $135 for the PDIM and $40 for the software programming. Since I installed it myself there was no labor charge for the PDIM part.
05-01-2010, 10:53 PM | #12 |
Drives: LS, Metallic Grey Join Date: May 2010
Nice DIY on USB
My question is pretty basic: My LS has no USB or connectivity package, just an 1/8" aux port. Is the pdim intended to add a USB-and if so, will I have to go to a dealer and request some kind of programming update for my Ipod to play and stay charged and be controlled by the radio?
05-01-2010, 11:08 PM | #13 | |
SoCal Mayhem
After that you will have a USB port that functions just like the 2LT/2SS/1LT with C&C.
05-02-2010, 08:01 PM | #14 |
Camaro Addict
Drives: too many Join Date: Sep 2009
cant wait til these cars start hitting the junk yards in the future. it'll feel like finding a hidden treasure.
1990 IROC-Z Vert LS
1996 SS Vert LT4 1992 Z28 Z03 T5 1992 Z28 Z03 L98 2018 Sierra Denali 6.2 1997 Z28 Z4C 1995 Z28 |
Similar Threads | ||||
Pfadt Race Engineering DIY Drop Spring installation procedure | PfadtRacing | Suspension / Chassis / Brakes | 20 | 09-23-2011 09:31 PM |
PDIM / USB port firmware update done in Houston? | rolnslo | USA - Texas | 28 | 02-09-2010 03:46 PM |
USB port stopped working | philthy | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 85 | 11-11-2009 06:14 PM |
USB port intermittent... shall we compile a list of PDIM failures? | JDBeck23 | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 49 | 09-01-2009 01:57 AM |
USB Port location/relocation | 2ssJB | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 15 | 05-01-2009 04:28 AM |
