Old 07-22-2010, 11:15 PM   #43
Pumpkin1LT
Pumpkin1LT's Avatar
Drives: 2010 Camaro 2SS
Here is what i have done so far. Tomorrow I will finish her up. Pretty happy with the out come so far. For the smaller harder to reach areas like the curves in the door I opted to use a small flathead (eyeglass repair kit size) to navigate around those curves. Worked out quite well. But be VERY cautious and careful...the flathead can scratch the plastic if you aren't slow and gentle.
A happy wife is one in the garage getting dirty under her 2010 Camaro!
Pumpkin1LT is offline   Reply With Quote
Old 07-22-2010, 11:28 PM   #44
rallyrob
rallyrob's Avatar
Drives: 2010 rally yellow camaro rs A6
wow great job pumpkin it looks great it wasint really hard was it and its cheap did you get 3 packs of tubeing from joanns?
rallyrob is offline   Reply With Quote
Old 07-22-2010, 11:33 PM   #45
rallyrob
rallyrob's Avatar
this is something so tiny but it gives it a great look for $6 bucks
Old 07-22-2010, 11:59 PM   #46
Pumpkin1LT
Pumpkin1LT's Avatar
Since Wrights didn't make the right shade of Orange in the Max Piping, I had to purchase 3 packs of 4yd Orange Fabric Edging..roughly about $9.00, however, to get the "piping effect", I had to buy about 12 yards of small cording (about $10) to wrap into the Edging, in short, fabricating my OWN piping. But since I have some background in sewing, it wasn't that difficult for me to do, just more time consuming. And yes, I did get it all at Jo-Anns...much better selection there. I always buy MORE than I need, cause you never know if you might have an "uh-oh" or "re-do". Better safe than sorry. I'll put up better pictures tomorrow.
And HOW AWESOME were those colors?! The Yellow, lime green and Medd Blue were DEAD ON for the Camaro colors!
Old 07-23-2010, 03:00 AM   #47
rallyrob
rallyrob's Avatar
when i got it i only got 2packs of yellow so it was anuff for the door and dash i still got to get 1 more pack for the passanger door but what im thinking now to do it take it off and take off the dash and door pannels and hot glue it becus some of the trim is comeing off from the door i took off the little peace next to the whell and i hot glue it so i think i might try to glue all of it becuz ocer time its just goin to fall out the dash and door
Old 07-23-2010, 08:59 AM   #48
TonyNo
TonyNo's Avatar
Drives: 2016 2SS, SW
Looks great pumpkin!
Let's get some shots of the ends and come up with a good way to handle them.
FYI, if you do the ABL-style (top of dash only), then you only need two packs.
TonyNo is offline   Reply With Quote
Old 07-23-2010, 10:01 AM   #49
Pumpkin1LT
Pumpkin1LT's Avatar
The only issue you are going to encounter with the hot glue is that it will leave somewhat of a large beading where you apply, and if youapply too much it may interfere with the placement of the panels after your done.. They may not fit. Instead of hot glue, I would suggest a good no sew/fabric glue (don't go cheap on it cause it will not hold. After you apply the fabric let it dry over night .
I am thinking that I may put a line of thin cording in the seam behind the piping to hold it in place. As like with any "concept" idea, trial and error until you find what works.
Old 07-25-2010, 01:25 AM   #50
rallyrob
rallyrob's Avatar
This l
Looks great
Old 07-26-2010, 10:38 AM   #51
Pumpkin1LT
Pumpkin1LT's Avatar
i figure because I made my own piping, it was easier to manipulate the inner cording..so when it came to getting a clean flat edge, i simply used hot glue to pinch the edge together, then folded it over, hot glued and pinched it again to make it nice and flat. It created a nice clean edge for my starting point.
Old 07-26-2010, 10:46 AM   #52
TonyNo
TonyNo's Avatar
Nice. Got pics of the two ends on the doors?
Old 07-26-2010, 11:06 AM   #53
Primus
2G1FF1EV0A9113319
Primus's Avatar
Drives: 2010 1LT/RS 6MT
They didn't have any silver/grey so I tried to dye some. Currently they look like a blackish-blue. So unless I can get them to a more grey color I'm probably going to trash mine.
2010 Camaro 1LT/RS M6 Black
1100: 10/13/2008
2000: 4/02/2009
3000: 4/08/2009
3300: 5/14/2009
3400: 5/21/2009
3800: 5/28/2009 VIN: 2G1FF1EV0A9113319
4000: 5/28/2009
4150: 5/28/2009
4B00: 5/28/2009
Delivered: 6/10/2009
Primus is offline   Reply With Quote
Old 07-26-2010, 11:24 AM   #54
Pumpkin1LT
Pumpkin1LT's Avatar
I might be able to help there. You looking more for a Silver to match SIM or the CGM?
Old 07-26-2010, 11:26 AM   #55
Pumpkin1LT
Pumpkin1LT's Avatar
Those edges were indeed a challenge! The panels were much tighter in those spots and trying to "tuck" the piping into the seam only pulled it out so that the panel wouldn't lie flush. Ill take a pic of what I did.
Old 07-26-2010, 11:53 AM   #56
Pumpkin1LT
Pumpkin1LT's Avatar
It was VERY difficult trying to figure out a way to clean this up... I couldn't get the piping to go into the door panel (too tight and it lifted the panel and left a gap). If you were to simply glue a strip of piping on top of that seam (without wedging it into the seam crack) you could run the risk of the door not closing properly because of the "bulge" the piping would leave..although I am pretty sure the piping is pliable enough that it would flatten out over time. This seems like the best option if you want to carry the piping all the way around the panel. Carefully cut off the fabric overhang (but not to much as to open the seam where the cording is) and very carefully glue the piping into that crease. I may try this today.
I simply stopped the piping and didn't bother trying to bring it all the way around. It isn't the cleanest, but the best that I could do. Again, folding the ends over and glueing them flat. Short of taking the entire panel off, I don't think there is a way to get the fabric under that panel in that specific area.
DIY Dash and Door trim for under $30 Darth Martel Camaro DIY & HOW-TO instructions & discussions 29 09-15-2010 06:49 AM
WANTED: INTERIOR TRIM (doors and dash) Red67Stang Interior Parts & Accessories 1 03-07-2010 07:58 AM
Factory dash ABL? bkwagonss 5th Gen Camaro SS LS LT General Discussions 3 09-17-2009 10:41 AM
Question about fabric panels on doors and dash. THUMPER20X Cosmetics and Lighting Modification Discussions 0 09-06-2009 10:47 AM
protectant/shine for dash doors and console ? D1BADZ Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 4 07-02-2009 03:53 PM
