04-29-2024, 10:26 AM | #1 |
@Blackmamba_1LE
Drives: 2017 1LE Join Date: Jun 2017
Tires w/ High HP Applications
Hello guys, its been a while since I posted here so I've lost track of basically all the builds and convos in here. I'm sure this has been asked before but couldn't pinpoint a way to search.
Anyway, I'm curious to see what people are driving around with for setups that are over 900rwhp and 900rwtq. Let me explain... I have a drag pack... however; I'm not looking to race, nor want to be driving to car shows or long drives on them. I know people suggest R888's but all I've seen is tires are super loud and rain performance is still bad anyway so in my view I might as well drive on the micky's. (Which I really don't want to). I currently am on PSS 4s, had also the cup2's... nothing is even close to hold. I lightly press gas in second and the car immediately goes snap sideways. So, I find myself just driving super slow and in fear of even overtaking another car since, basically can't press on the gas. Anything new out there that I may have missed in the 2+ years of been out of the game?
Florida High Performance: H/C Whipple LME 377 900WHP
04-29-2024, 11:24 AM | #2 | |
Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
Honestly, get yourself a Smoothboost. Simply dial down the boost for street use and dial up full kill at the track. No brainer.
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
04-29-2024, 11:29 AM | #3 |
Petro-sexual
It seems you're on track with those Toyos. It sounds like if you wanted to run on the OEM wheels, you could also try the 20" MT ET SSs, too. I've heard those are pretty good. Maybe some DRs on the OEM wheels are worth trying.
I'm not near your power, but on ET Street SSs and a drag pack, doing digs on the street just beat those tires up. I learned that they tend to ball-up doing that too much, and traction goes out the window (which I verified). Subsequently - the fix was just finding some clean concrete (e.g. my driveway, lol), and doing a minor burnout, which cleaned the balls-off, and traction improved. I still couldn't go WOT from a dig, and I still had traction issues from a 40-roll in 4th gear, but it was better than OEM GYs... I think there are guys on Nitto DRs (King') and OEM wheels that like them.
'20 ZL1 Black "Fury" A10, PDR, Exposed CF Extractor Magnuson Magnum DI TVS2650R // RFBG // Soler 103 // TooHighPSI Port Injection // THPSI Billet Lid // FF // Katech Drop-In // PLM Heat Exchanger // ZLE Cradle bushings // BMR Chassis-Suspension Stuff // aFe Bars // Diode Dynamics LEDs // ACS Composites Guards // CF Dash // Aeroforce // tint // other stuffs |
04-29-2024, 11:51 AM | #4 | |
Drives: '20 ZLE Join Date: Jun 2020
My Toyo 345/30ZR19 are useless on the road below say 60-70 mph
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct. Not a DD. |
04-29-2024, 12:09 PM | #5 |
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 (stock) Join Date: Jul 2012
The SS's are markedly better if rain. The R's will elevate you to a new level of "scared to death!" These would probably be the best for traction and driving here and there, and still be able to give it more throttle in-between your stop and go's, and go-more on the street. I've no experience with Nitto's for the street (but have ran the NT05R's at the stripe, which sucked (no hook)).
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
04-29-2024, 03:06 PM | #6 | |
@Blackmamba_1LE
Smooth boost is new, never heard of that before. Will look into it. Sound like the boost controller of some sort. I just love how quiet the Michelins are but its way to dangerous. All I hear about the toyo's is how loud they are and last my OCD doesn't want Michelins up front and toyos out back,
04-29-2024, 03:17 PM | #7 | |||
@Blackmamba_1LE
Anyway, Afterall this time, it seems like the "best" option is still the nittos or toyos, and still will be not good enough on these HP levels but im sure definitely better than the Michelins.
04-29-2024, 05:25 PM | #8 | |
Drives: 2018 Camaro 2SS A8 Join Date: Jul 2017
One either compromises severely on the street beyond 700-ish rwhp by running crazy drag tires or slicks, or if not, adding more horsepower simply reduces usable accelerator pedal travel...
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 |
04-29-2024, 05:46 PM | #9 | ||
I think you’re better off scaling down the power a bit on the street and the Smoothboost is perfect for that. I usually run around 750-800 WHP on the street and the R888R is surprisingly good there (but louder than many would like). I think you’d like the 555R2 (NOT G2!) honestly and will give them a try myself at some point. But if you’re at 900 WHP on a Whipple 2.9, then you’re spinning it pretty hard and the drawback will be nasty midrange torque on the hit that you really cannot control…ask me how I know. Quote:
04-29-2024, 06:23 PM | #10 |
Both the Toyos and the Mickey's have terrible traction in the wet. Both are terrible below say 40°. But the Mickey's have much better traction in the dry. It all just depends on how you use the car.
'20 ZL1 1LE A10.
04-30-2024, 11:15 AM | #11 |
Drives: 2016 1SS NFG A8 Join Date: Aug 2017
I would go with the 555r2's over the 888's. Much nicer driving tire with similar traction capabilities.
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA |
05-03-2024, 02:50 PM | #12 |
Drives: 2021 Camaro ZL1 Join Date: Mar 2023
I have liked my Atturo az850dr tires so far. I have never driven my car in the rain but have left a car wash and they definitely don't like water. I may try the 555r2s next... however, I am not a fan of the available sizes or lack of rim protection. Those are the main reasons I went with the 850s this go around.
2021 Camaro ZL1 Satin Steel Metallic
Rotofab CAI, Banks Idash, AEM X series wideband, CSP 2" headers, Jet hot 2500 ceramic coating, DSX Flex Fuel Sensor, DMS Fender Tank, Velossatech Big Mouth, JMS Fuel Booster, MPI Billet Lid, Jokerz race port, 2.30" upper, 107mm Soler TB, 160°F Billet DMS, Big Gulp, LPE Big Bore HPFP, XDI +30, ECM & TCM tuned by Elite Tuned, Atturo 315 AZ850DR |
05-03-2024, 09:50 PM | #13 |
Boosted Moderator
Regardless of the tires, I recommend strongly staying out of boost in any degree of wet conditions, better yet, leave it in the garage if there is any suspicion of it getting wet....
Having said that, with what you have invested already, it's only a small expenditure (relatively speaking) further to get some form of quality traction control. I ran ProEFI on my 5th Gen, and it was amazing.... My street tires were the Good Year Eagle F1 Supercar G3's and I never had any issue on the street.... Granted, I couldn't put anywhere near full power down... It would dump boost, pull timing, or whatever it had to do to keep the fronts and rears spinning at the same speed. There are other systems out there, but it is impossible to put full power to the ground on an asphalt roadway, not at your 900/900 power levels... An option if you wanna harass with LEO's is the Hoosier Road Racing Slick I ran at the mile, with over 2000 RWHP. They are DOT stamped, though there is no "tread." Concrete track and I was still spinning at over 200 in 5th gear.... We loosened the traction control the faster we went to free up the power... The trade off of big power is limitations on the street.... It isn't worth it to get sideways and end up wadding your car up.... I cant recommend a traction control device strongly enough...
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
05-08-2024, 06:24 PM | #14 | |
Drives: 2018 2SS Camaro Join Date: Mar 2020
Having a quick look at the SmoothBoost website, all I can see is that it's electronically controlling the (previously vacuum operated) bypass. As we know the standard vacuum bypass is operating only at lowish revs (say up to 2000 rpm). So to 'dial down boost' is the Smooth Boost now partially opening the bypass across the whole rev range? Doesn't that reduce volume in bypass rather than boost pressure? And what does Whipple think of this? Any issues for S/C operation/durability?
2018 2SS, Hyper Blue, Australian HSV delivered
2.9L Whipple 98RON tuned 650hp/850Nm Elite Engineering E2 Catch Can Eibach Prokit springs Mamo LT1 Ported TB |
