Old 09-21-2010, 09:25 AM   #1
Rudy@Tirerack
Rudy@Tirerack's Avatar
Drives: 1-800-428-8355 X4664
Arrow FAQ Camaro Winter Tires - Wheel/Tire Thread 2017-2018 *
So you want to use your car in the winter but it has summer tires, lots of horspower and rear wheel drive. What to do? The Tire Rack has options to fit all different 10/11 Camaro options. In this thread I will do my best to answer questions regarding anything winter.
Why do winter tires work so much better in the snow? A winter tire needs 3 things to work well in snow/ice. First is tread depth. Snow tires come with more tread depth than summer tires. Second is tread design. Most tires come with a directional style tread that evacuates slush and snow. Also if you look at the tread blocks of a snow tire there is much more siping to claw and bite the snow and ice. Third is the tread compound. A snow tire has a cold weather compound that stays flexible in very cold weather. A summer and/or all season tire become hard and unable to grip.
The First picture shows a new tire at 11/32nds of tread depth the 2nd picture show a tire approaching the winter tread bar at 6/32nds of tread depth and the last picture shows a tire at 2/32nds which is worn out for dry use. Tread depth why too little is never enough.
But do I need winter tires. The answer is yes. Click here to find out why.
My car is rear wheel drive so can I use just do two rear snow tires. Bad idea while its true the rear tires will get you moving how are you going to stop or steer? Four winter tires the only way to go.
Winter Tire FAQS
Start your winter tire search here.
Why consider a wheel and tire package? Its expensive to have winter tires mounted/and unmounted twice a year. With a package its easy to do the switch over yourself. Remember all of our packages come with the mounting hardware and are mounted & Hunter Road Force balanced for free.
Find wheel and tire packages for your car here.
I have had lots of questions regarding the 10/11 SS models. As long as you do not have the Roller skate brake pads I have 18 inch wheels that will fit. You will need to call me on these as we do not list them on the website. Keep in mind if you ever change to the roller skate pad these wheels will no longer work. Also if you have the factory wheels which are 9 inches wide in the rear the 245/45R20 Blizzak LM 25 works great front and rear for winter.
I live in the snow belt and have lots of knowledge with the snow tires we sell so I can help you find what will best fit your needs.
Feel free to contact me with questions. I am here to help. Everyone please feel free to add input to this thread!!
Rudy@Tirerack is offline   Reply With Quote
Old 09-21-2010, 01:19 PM   #2
Mike529
Mike529's Avatar
Drives: 2014 2LT RS
Rudy,
Thanks for the great information!
I've heard that taller sidewall tires are better for winter handling, so would you recommend going with the 17" package for an LT?
Thanks,
Mike
Mike529 is offline   Reply With Quote
Old 09-21-2010, 01:23 PM   #3
Rudy@Tirerack
^ Absolutely. Downsize when possible is the better option and it will help to protect your wheels from ugly potholes. Check out my preferred 17 inch winter packge for your car on my website.
Old 09-21-2010, 02:54 PM   #4
bowtie_beauties
Drives: White SS & Green LT
Thanks for this. What are "roller skate brake pads"? I'm getting a 2011 very soon (on order) and does it come with "roller skate pads" from the factory?
bowtie_beauties is offline   Reply With Quote
Old 09-21-2010, 03:03 PM   #5
Rudy@Tirerack
^Lots of information in this thread. I would guess your car will have them as this is the new design to elimate pad noise.
http://www.camaro5.com/forums/showthread.php?t=58624
Old 09-21-2010, 03:54 PM   #6
skuttduck
skuttduck's Avatar
Drives: 2010 RJT 2LT Camaro
Send a message via ICQ to skuttduck Send a message via AIM to skuttduck Send a message via Yahoo to skuttduck
Rudy,
just curious, are the pirelli scorpion ice and snow's no longer recommended as a 20" tire for the camaro? They were last year when I did my research, and I got them from a local tire shop. http://www.tirerack.com/tires/tires....omCompare1=yes
I found that if I manually select 245/45/R20 and 275/40/R20 I can get them.
Here's the post where number 3 suggested them. http://www.camaro5.com/forums/showthread.php?t=51061
skuttduck is offline   Reply With Quote
Old 09-21-2010, 04:03 PM   #7
Rudy@Tirerack
^They are still highly recommended for the camaro. I have sold several sets to start the season. How do you like yours?
Old 09-21-2010, 06:30 PM   #8
skuttduck
skuttduck's Avatar
I can't say enough good things about the Pirelli scorpion ice and snow tires.
They feel a lot like the summer only tires, they have only a bit more road noise. The Camaro with the Pirelli scorpion Ice and snows performs far better than my 2000 Toyota Camry with Michelin XS One all season tires.
I had driven it on 6 inches of unplowed snow, and I would have gotten stuck in the camry. The camaro just plowed through it. I experimented in the neighborhood, and I had to turn off traction control and use the emergency brake to get it to slide.
I was more curious why nothing comes up in the OEM 20" size, when you have the Pirelli Scorpion Ice and snow tires in stock.
Old 09-21-2010, 11:13 PM   #9
Cyber/Orange10
Cyber/orange10
Cyber/Orange10's Avatar
Drives: 2010 2SS 96 CE LT4, 12 CRUZE ECO
Send a message via AIM to Cyber/Orange10
Yes, I was too. I ordered 245/45R20's all around and they will fit just fine (thanks Luke). But yes if you have the roller skates you have to watch the wheel fit, best to get take offs and use them.
Cyber/Orange10 is offline   Reply With Quote
Old 09-22-2010, 06:48 AM   #10
SRFnSNO
SRFnSNO's Avatar
Drives: Blown & Flamed
I have the P-Scorpions in 19" with the 19" Type 16 Rims Tire Rack had on clearance last year.
Car went great in the snow last Winter.
SRFnSNO is offline   Reply With Quote
Old 09-22-2010, 07:12 AM   #11
Rudy@Tirerack
^Thanks to all who have ordered so far!!
Old 09-22-2010, 09:09 AM   #12
Don57
Drives a beast!
Don57's Avatar
Drives: Yellow 2014 Camaro 2SS/RS
Excellent information!
I used to use all-seasons with all my previous cars until a few years back when I switched to using two sets of seasonal tires on my Pontiac Sunfire GT (one for winter and one for summer). Going from all-seasons to winter tires made a huge difference -- like night and day.
I live in "Winterpeg", and I've learned how important a set of tires dedicated to driving in winter are. Never again will I use all-seasons in winter. And after researching winter tire & rim packages both online and off, Tire Rack had the absolute best deal for my new Camaro! (I hate to sound like a commercial, but it's true)
Don57 is offline   Reply With Quote
Old 09-22-2010, 10:07 AM   #13
Rudy@Tirerack
^Excellent we ship to Canada all the time. Its good to hear you saved a lot of money shopping with us.
Also one other thing I did not mention, but we install TPMS sensors for free in our packages if you purchase them from us.
Old 09-22-2010, 10:19 AM   #14
cab2g
love. my. car.
cab2g's Avatar
Drives: 2011 2SS/RS
In your opinion, which tire is better for deep snow/slush? The Blizzak or Scorpion. I plan on mounting one of these two on my stock 20" wheels next month
cab2g is offline   Reply With Quote
5th Gen Suspension -- The Book JusticePete Suspension / Brakes / Chassis 151 05-07-2015 05:52 PM
Winter Tires for my 2010 Camaro in Canada Camarodriver Canada 21 12-20-2010 11:19 PM
Pedders Suspension Benchmark Track Testing and New Jersey Track Day Info@PeddersUSA.com USA - NY / NJ / PA 35 10-26-2009 05:20 PM
