01-26-2011, 07:06 PM | #1 |
NOW CAMMED & SUPERCHARGED
Drives: 2010 Camaro 2SS/RS Black w/ IOM Join Date: Oct 2008
Anyone with 500-550rwhp able to hook with drag radials on street?
Hey everyone I am about to send my car off for a stall small 2400 with Livernois 2C cam to accompany my current 501rwhp Magnacharged auto. It is projected that I will see 530-550whp on the dyno with some hp hidden by stall. What I am wondering is if with this power is there anyone that is able to use a drag radial on 20" wheel that will hook at these levels at a roll or from a dig. I will have the BMR trailing arms, non adj toe rods, and rear cradle inserts along with Nitto 555R. With these stock tires I already have some turbo diesel trucks that can give me a run for my money due to my car spinning and getting squarly. They never get by me lol but I feel that I could be much further ahead especially once I add this power but I need to get it to hook and I know the stall can make that worse. Any opinions suggestions would be great.
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
01-26-2011, 07:08 PM | #2 |
Drives: 2011 2SS Join Date: Jun 2010
305 555r and a big no from me.
01-26-2011, 07:17 PM | #3 |
Drives: 2010 2SS/RS IBM Black Polished Join Date: Feb 2009
My gosh guys..what temps are you having down there to even think about running DR right now.
They are like hard plastic when below 60 degrees and not very effective. Of course PZeros are just as bad but at least you wont be cracking them.
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
01-26-2011, 07:24 PM | #4 |
Yes my car might as well be on ice all the time in 30 below. Just sucks when a big heavy trunk can hold you because of it lol. Thanks for the info on not running the dr's in winter though that way I will know I need to have mine changed back over to stock atleast for winter. man I was hoping for some luck on hooking atleast from a roll!
01-26-2011, 07:48 PM | #5 |
Drives: 2010 Camaro SS/RS 427ci Join Date: Jul 2009
When it is warm you will see a HUGE difference running DR on the street. I also vote for either the 555 or 05.
01-26-2011, 07:58 PM | #6 |
I can say I have heard the 05 is not great for mileage. I drive my car about 12k a year so I think the 555r would allow me a full years use which would be most cost effective but I really want the car to hook I did do ok one pzeros this past summer I spun but once it hooked it went and now winter is really sucky so I was thinking atleast in the summer on dr's I could hook pretty good.
01-26-2011, 08:01 PM | #7 |
Drives: Black 1SS Join Date: Apr 2009
I have about the same HP with an auto and 555 DRs on the OE wheels. I could not tell much difference between the Nittos and the PZeros when driving on the street. Now when you can let some air out and heat them up like at the track there is a huge difference.
01-26-2011, 08:01 PM | #8 | |
Drives: 2010 Camaro Join Date: Feb 2010
01-26-2011, 08:08 PM | #9 |
Gotcha. So basically you guys are telling me I am going to have to put up with all these damn diesel trucks kicking my ass because I got so much power with no traction!!! Damn!!
01-26-2011, 08:11 PM | #10 |
Pretty much. 4wd/awd will win out all most everytime on the street and short runs. Instant traction is hard to beat.
01-26-2011, 08:17 PM | #11 |
Well then I wont give um the time of day to beat me then lol unless we are at 40-50 mph which then I hook and go good and will kick that azz!
01-26-2011, 08:17 PM | #12 |
01-26-2011, 08:31 PM | #13 |
Thats the spirit!
01-26-2011, 08:48 PM | #14 |
SST...
Drives: SST Camaro 2010 Join Date: Oct 2008
If you are willing to go down in rim diameter you can gain some traction back. Also M/T is coming out with 20" drag radials.
Similar Threads | ||||
Unbeatble Prices on ACT / Fidanza / Hurst / Mishimoto / MTI / SLP / Spec / More | maperformance | Transmission / Driveline | 18 | 10-26-2010 02:16 PM |
SATURDAY September 18 - Fontana Drag Strip (TWILIGHT DRAGS) STREET LEGAL RACE NIGHT! | aet08 | California Meets and Events | 1 | 09-13-2010 01:04 PM |
Challenger Fest ! Only 20 spots for Camaros to Drag race | nhra stocker | Dragstrip and Launch Techniques Discussion | 61 | 08-23-2010 06:30 PM |
Chevy Street Cruise to open Super Chevy Show Weekend in Houston | Houston Raceway | USA - Texas | 0 | 08-08-2010 08:11 AM |
5th Annual Nitto NMRA/NMCA Super Bowl July 15-18 | nmcajeff | Dragstrip and Launch Techniques Discussion | 0 | 06-28-2010 11:26 AM |
