Old 01-31-2011, 11:08 PM   #1
Speed Kills
Live to Drive
Drives: 2010 IBM RS/SS, 2018 Toyota Tacoma
20 x 10 on the Front
Car is lowered with an Eibach Pro Kit. Found some wheels that I like. They are available in 20 x 9 ET 25 ( I assume that is offset), 20 x 10 ET 30, and 20 x 10.5 ET 35.
My questions are these:
1. Would a 20 x 10 fit in the front (with the car being lowered) and could I run a 285/40/20?
2. You thoughts on running 20 x 10's on all four corners, but with a 285/40/20 front (if it will fit) and a 305/35/20.
or
3. 20 x 10, 285/40/20 Front and 20 x 10.5 with a 315/35/20 on the rear??
You thoughts and feedback are appreciated.
Speed Kills is offline   Reply With Quote
Old 02-01-2011, 01:49 AM   #2
NinoSS
Drives: 2SS/RS CGM LS3
or
I have 20 x 10 et 40 all the way around. I am running a 3mm spacer in the front with 275's and could definately go more aggressive but I wanted to maintain at least 8 full turns of lug engagement. I am running a 315 on the rear.
my guess is that there is room for a 20 x 10 et 30 with a 275 since my set up is about a 37mm offset and could go at least 5mm's more. I believe the perfect front offset for 275's would be 32mm.
This is just my opinion, good luck...
Current - 2018 NGM 1LE (LT4 conversion coming soon)
SOLD 2010 LS3 / Vengeance stage I cam / CAI intake w/ADM race scoop / Dynatech LT's / Eaton Posi LPE-JRE 3.91's / L99 Corsa / ZL1 wheels / NT05 275/315
NinoSS is offline   Reply With Quote
Old 02-01-2011, 01:24 PM   #3
Speed Kills
Live to Drive
bump to the top. Thanks!
Old 02-01-2011, 08:09 PM   #4
FEN
FEN's Avatar
Drives: BLACK 2SS/RS
My car is also lowered via Eibach Pro Springs and im running 20x10's with 275/40/20's up front.....275's are about the largest your going to be able to run in the front w/o rubbing.
[IMG]http://i736.photobucket.com/albums/xx5/fenemij/DS****16.jpg[/IMG]
[IMG]http://i736.photobucket.com/albums/xx5/fenemij/DS****15.jpg[/IMG]
CCW polished 505a's
Front 20x10 w/275/40/20's
Rear 20x11.5 w/305/35/20's
Eibach 1" Pro Spring Kit
Factory GFX
MPD1 spoiler
painted bowties
15% tint
FEN is offline   Reply With Quote
Old 02-01-2011, 10:37 PM   #5
Speed Kills
Live to Drive
Thanks!
Old 02-01-2011, 10:52 PM   #6
Berean
Drives: Truck
I have 20x10's all the way around on 275's, lowered 3/4th of an inch.
Berean is offline   Reply With Quote
Old 02-02-2011, 08:37 AM   #7
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2016 Camaro SS
The wheel width isn't the problem, the tire width is critical. Yes, 10" wheels fit up front no problem, but you simply do not need that wheel width just to fit a 275 max tire. The 285 tire will rub unless you are stock height, where they will stick out slightly. A set of Pedders coil-overs can bring them in a little more, as their spring perch has more clearance than stock. KW, Pfadt, BC etc.. all have less clearance than stock. Be sure whatever you decide on, factor in the suspension route you may go later. Not all vendors know the proper fitments for each
Fquick.com/NineBall
FRONT RADIUS ROD BUSH UPGRADE FROM EASY DIYer TO FULL RACE SETUP Info@PeddersUSA.com Suspension / Brakes / Chassis 4 08-25-2013 10:12 PM
Pfadt Introduces New Front Camber Plate Kit. Available NOW! PfadtRacing Suspension / Brakes / Chassis 43 02-07-2013 12:40 PM
NO MORE FRONT PLATE! SUPPORT NYS Bill A09426 LT1Jeep USA - NY / NJ / PA 17 05-04-2010 09:23 PM
APR Performance CF Front Wind Splitter w/Rods | IN STOCK + FREE S&H!! AJ@ECSMotorsports Exterior Parts & Accessories 4 05-03-2010 03:32 PM
