03-19-2011, 10:15 AM | #1 |
Drives: 2010 2SS/RS M6 Join Date: Jan 2010
Blown LS3 Blew
This is what happened with a stock LS3 with a conservative tune. Rod and piston right threw the block. it happend down shifting from 6th to 4th @ 70mph to pass someone. 32k 0n the SC
600hp to crank 520rwhp rev limit set @ 5600rpms Now I have an excuse to rebuild....... |
03-19-2011, 10:19 AM | #2 |
Drives: Aggressive Join Date: Jul 2008
I'm sorry for your loss
Black 2SS RS LS3 Inferno Int. '17 1LE replica 20's {MODS} KOOKS LT: Borla S-Type: Roto-Fab CAI: Hurst ST.: PFADT Stage 2, Trailing arms, Tie Rods: ECS BigBlower Cam: Fast 102mm intake: Brian Tooley racing dual spring kit: TFS pushrod set: Katech C5R timing chain: Mellings high volume oil pump: ATI Balancer: Ideal performance upgraded clutch master cylinder:Tick performance upgraded slave cylinder/throwout bearing: Mantic 9000 twin disk clutch & light weight flywheel: Tuned by Doug Ring at ECS. 475RWHP/445RWTQ.Dynapack Dyno.
03-19-2011, 10:22 AM | #3 |
NOW CAMMED & SUPERCHARGED
Drives: 2010 Camaro 2SS/RS Black w/ IOM Join Date: Oct 2008
How much boost did you have and who did your tuning?
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
03-19-2011, 10:25 AM | #4 |
Drives: Chevy Join Date: Dec 2008
geez. that must have scared the crap out of you!
03-19-2011, 10:27 AM | #5 |
NOICE!!! ™
YIKES! Even on a safe tune Hmmm...? How much pounds of boost? What type of power adder?
03-19-2011, 10:29 AM | #6 |
Go Blue!!!!!
Drives: 2012 Cruze LT Join Date: Mar 2009
Defective block. This is ALL on GM. Just send them the bill.
03-19-2011, 10:29 AM | #7 |
03-19-2011, 10:45 AM | #8 |
SST...
Drives: SST Camaro 2010 Join Date: Oct 2008
You just never know with boosted motors and a stock bottom end. There are so many variables...
The bright side is you get to build the bottom the way you want it. |
03-19-2011, 10:52 AM | #9 | |
Boosted Moderator
I seem to remember the statement about boost being higher than tire pressure certified you as a nut.. well we both fit...
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
03-19-2011, 10:53 AM | #10 |
Drives: aqua 2ss l99 Join Date: Jun 2009
details man.....
May your exhaust note, sing in harmony with your blower.
03-19-2011, 10:59 AM | #11 |
Drives: 2010 Transformer 1SS Camaro Join Date: Nov 2009
Also, redline at 5600RPM??
03-19-2011, 11:04 AM | #12 |
Drives: 99 Camaro SS, 79 z28, 70 GTX Join Date: Oct 2009
Nice...LOL.. That is the worst case scenario although it seems to be real common these days.. ..losing the whole block.
We talked... ( THe OP called me) one thing to say here... Bearing gaps are different for a boosted motor than a naturally aspirated one. The metals swell under boost more than a regular engine does... with a tighter bearing gap this cuts the flow of oil... eventually it seizes and then breaks.... Hard to say what made this engine come apart from just a phone call so I cant be sure of course unless we had the parts to examine and say for sure... If there is blueing then it was heat Hopefully the head is still OK. This is why is say it's not a matter of can it be done but for how long it will last. Naturally aspirated motors are built different than boosted engines and it not just the piston and ring material and compression. If we are lucky to get your business then we will provide you with a proper engine that is built correctly for the application. Our/HKE's reputation is second to none. |
03-19-2011, 11:24 AM | #13 |
Drives: 2010 ABM SS #14 of 2,027 Join Date: Jan 2007
...I hate seeing these posts..sorry for your loss
"One of the ordinary modes, by which tyrants accomplish their purposes without resistance, is, by disarming the people, and making it an offense to keep arms."
-- Constitutional scholar and Supreme Court Justice Joseph Story, 1840 |
03-19-2011, 11:37 AM | #14 |
Camaro SL,UTs
Drives: 2010 Camaro SS/RS #16429 Join Date: Sep 2006
build it. blow it. rebuild it. repeat.
Cars rule!
Similar Threads | ||||
LS3 and L99? | black2black10 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 26 | 05-07-2010 12:58 AM |
Specs on L99 vs LS3 .... | Bowtie Junkman | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 3 | 04-28-2010 12:26 PM |
Check your Order here | bvonscott | Camaro Price | Ordering | Tracking | Dealers Discussions | 665 | 06-29-2009 01:00 PM |
Advice---Supercharged L99, S/C'd LS3 or LS9? | CamaroZR1 | Forced Induction - V8 | 25 | 09-25-2008 09:21 AM |
LS376/480 EFI LS3 Gen IV V-8 | NOODLESgoneWILD | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 18 | 09-04-2008 08:14 AM |
