03-21-2011, 03:09 PM | #1 |
Thinking About Swappin' Gears? Here are the numbers!
Here is an article from our blog that should be helpful for those of you considering a gear swap. All of the information concerning cruising RPM and torque gain are included. Feel from to shoot me a PM if you have any questions.
Swappin’ Gears Added Dec 31, 2010, Under: Camaro Warning: Installation of rear end gears should only be performed by professionals. As owners of the 5th generation Camaro continue their pursuit of more performance, many are swapping to a more aggressive set of rear end gears. While not an inexpensive modification, the bang for your buck with a rear end gear swap is hard to beat and the improvement in performance is dramatic. Making this sort of modification can be intimidating because many people don’t understand differentials and gearing. In this post I will try to provide some basic information to at least try and help get you pointed in the right direction. How It Works The rear differential is the device that transmits torque and rotation from the driveshaft to the rear axles which then drives the rear wheels. The rear end gears contain a ring and pinion gear that can be swapped to different ratios. The stock Camaro comes with either a 3.27 (all V6 models and the automatic SS) or a 3.45 (manual SS) rear end gear ratio. This means that for every 3.27 or 3.45 rotations of the drive shaft your rear wheels will turn once. A lower gear ratio means increased torque and increased acceleration without the engine having to create any additional power. This all sounds great but the are some potential draw backs. A lower gear ratio means that your engine has to turn faster at cruising speeds which means fuel mileage can suffer. In the case of the 5th generation Camaro, the new six speed transmissions help mitigate the impact of this. Camaro owners that do a lot of highway miles have been reporting a loss of about 1-2 MPG, while those who drive mostly in town are reporting no change and even an increase in some cases due to the engine not having to work as hard to get up to speed. The other potential draw back is that a lower gear ratio will shave away top end speed. This is not important to the average Joe since the Camaro is capable of speeds well beyond the speed limit right off the showroom floor, but for competitive drag racers it can be. It is possible that while the lower ratio will cause your car to accelerate faster it can also cause you to have to shift gears one more time before you cross the finish line, potentially sacrificing the gains made. Careful calculations should be made when selecting the correct ratio for these sorts of applications. The Numbers Camaro V6 Models Currently, there is only one gear ratios made specifically for the 5th generation V6 Camaro. For the V6 Camaros Richmond manufacturers a 3.55 gear ratio. With the stock 3.27s the automatic (A6) equipped V6 runs 1750 RPM at 70 MPH. Swapping to the 3.55s provides an equivalent torque gain of approximately 10% or 27.3 ld.-ft. of torque at the rear wheels and will raise 70 MPH cruising RPM to 1949. The V6 Camaros equipped with the manual transmission (M6) come with 3.27s and run 2000 RPM at 70 MPH. Swapping to the 3.55s provides an equivalent torque gain of approximately 10% or 27.3 ld.-ft. of torque at the rear wheels and will raise 70 MPH cruising RPM to 2167. The rear end in the M6 equipped V6 Camaro is similar enough to the SS that their gears will also work. Apex Motorsports recently had a customer install Richmond 3.73s in his car. The result was an equivalent torque gain of approximately 15% or 41.2 rear wheel lb.-ft. of torque at the rear wheels and will raise 70 MPH cruising RPM to 2277. Camaro SS Models The Camaro SS models currently have three aftermarket gear ratios available for them; 3.73, 4.11, and 4.33. When equipped the the automatic transmission (A6) the SS comes with a 3.27 rear end and cruises at 1795 RPM at 70 MPH. By upgrading the factory 3.27s in the stock A6 equipped Camaro SS to the 3.73s you will realize an equivalent torque gain of approximately 15% or 61.5 rear wheel lb.-ft. of torque and cruise at 2050 RPM at 70 MPH. By upgrading the A6 to the 4.11s you will realize an equivalent torque gain of approximately 27% or 110.7 rear wheel lb.-ft. of torque and cruise at 2250 RPM at 70 MPH. By upgrading the A6 to the 4.33s you will realize an equivalent torque gain of approximately 33% or 135.3 rear wheel lb.-ft. of torque and cruise at 2377 RPM at 70 MPH. The A6 transmission is geared more aggressively than the M6 SS so we have found that 3.73 is the ideal gear for most A6 equipped SS applications. When equipped with the manual transmission (M6) the SS comes with a 3.45 rear end and cruises at 1612 RPM at 70 MPH. By upgrading the factory 3.45s in the stock M6 equipped Camaro SS to the 3.73s you will realize an equivalent torque gain of approximately 10% or 42 rear wheel lb.-ft. of torque and cruise at 1750 RPM at 70 MPH. By upgrading the stock M6 equipped Camaro SS to 4.11s you will realize an equivalent torque gain of approximately 20% or 84 rear wheel lb.-ft. of torque and cruise at 1915 RPM at 70 MPH. By upgrading the stock M6 equipped Camaro SS to 4.33s you will realize an equivalent torque gain of approximately 25% or 105 rear wheel lb.-ft. of torque and cruise at 2025 RPM at 70 MPH. We have found that the 4.11s are the ideal gear for most M6 equipped SS street applications. Once the 550-600 rear wheel horsepower range is reached we recommend dialing back to 3.73 unless the vehicle has a very solid suspension package and a very competent driver. Make It Happen Hopefully, the information in this post has helped you better understand gear swaps. If you think a gear swap may be right for your project be sure to consult a professional during your decision making process. Last edited by Apex Motorsports; 04-21-2011 at 08:35 AM. |
03-21-2011, 03:49 PM | #2 |
dirtbag
Drives: 2010 camaro LS Join Date: Mar 2010
what happened to the old thread? why dont you guys recomend 4.11's in a v6?
03-21-2011, 04:01 PM | #3 |
I needed to make some adjustments, sorry about the confusion. With the stock gears you will run right at 2000 RPM at 70 MPH and about 2300 RPM at 80 MPH. Throw in 4.11s and you will be running 2500 at 70 MPH and almost 2900 RPM at 80. That is a big jump and getting pretty high. Since most V6 Camaros are daily drivers I do not advice going that far. So far, all of our V6 customer have agreed and gone with the 3.73 which result in an equivalent torque gain of approximately 15% or 41.2 rear wheel lb.-ft. of torque at the rear wheels and only raise 70 MPH cruising RPM to 2277. They seem to be the best compromise between performance and drivability.
03-21-2011, 07:10 PM | #4 |
What gears would be recommended for am SS Manual, with a supercharger putting down 526RWHP?
Would the gears be different for road track racing, compared to 1/4 mile racing? Thanks |
03-21-2011, 07:39 PM | #5 |
You are closing in on the point where I would recommend dialing back to 3.73. A 3.90 option will be available soon that will make for a nice compromise. As for picking the correct ratio for road course racing goes, I can't really give you a blanket answer. A quarter mile is a quarter mile everywhere you go but a road course can mean so many things that it needs to be evaluated on a case by case basis.
03-21-2011, 08:00 PM | #6 |
dirtbag
is the daily driving the only reason you wouldnt recomend the 4.11's for the v6? most of my driving is 65 at the most. when the 3.90's come out would it be better for the v6?and how long till they come out?
03-21-2011, 08:04 PM | #7 |
Drives: WHITE CAMARO 2SS Join Date: Mar 2011
Iv got an ss auto with cai, full exhaust, underdrive pulley, ported throttle body and intake manifold and soon to be jannetty custom tune. What would u recommend for me to get a little more pep without losing to much mpg?
03-21-2011, 08:12 PM | #8 | |
It is that the RPMs will be very high. The 3.90s would certainly be a better option than 4.11 for the V6 in my opinion if you think the 3.73s aren't enough. I'm not sure exactly when the 3.90s will be available yet but it should be soon. |
03-21-2011, 08:13 PM | #9 |
3.73 all day. You will realize an equivalent torque gain of approximately 15% or 61.5 rear wheel lb.-ft. of torque and cruise at 2050 RPM at 70 MPH.
03-21-2011, 08:17 PM | #10 |
So then my acceleration with the 3.73's compared to the 4.11's alot of difference?
Can u pm me the price of a set of 3.73's and a set of 4.11's please. Thanks |
03-21-2011, 08:19 PM | #11 |
dirtbag
ok well i may hold off then, i want as much as i can get but i dont want it to be a track only car
03-21-2011, 08:36 PM | #12 | ||
03-24-2011, 03:42 PM | #13 |
Se habla espaņol
Drives: 2010 Camaro SS/RS VR Join Date: Jun 2009
Do you think that 3.90 gears will be released before the CF2?
What brand are they? Richmond? Ive been thinking in getting the LPE 3.70s....but the 3.90s might be better for a daily driver with ocassional trips to the track. JM
2010 VR 2SS/RS
BMR Suspension Parts Hendrix HD Axles DSS Aluminum Shaft RPM Diff / 3.91 Gears LPE ZR1 Clutch Edelbrock E-Force SC / JRE Fuel Upgrade Livernois 1C cam 570 rwhp/559 rwtq SAE Best 1/4 time: 11.43 |
03-24-2011, 07:05 PM | #14 | |
3.90 is going to be sweet option for the SS A6 cars. |
Tags |
3.73, 4.11, gears, rear differential, rear end gears |
Similar Threads | ||||
Richmond Gear Camaro gears | RichmondGear | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 85 | 01-19-2015 11:43 AM |
Tune, gears, warrantee, all that stuff again...but | f5journal | Tuning / Diagnostics -- engine and transmission | 6 | 02-25-2011 11:13 AM |
Why does Camaro have lower skidpad numbers than CTS-V? | OldJedi | Suspension / Brakes / Chassis | 9 | 06-22-2010 07:00 PM |
Fastlane Tune - Are these numbers good? | Dangeruss | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 58 | 03-15-2010 12:38 AM |
Thinking of Painting my Camaro. | Scott@Bjorn3D | Cosmetics and Lighting Modification Discussions | 24 | 12-26-2008 05:59 PM |
