05-28-2011, 07:29 PM | #1 |
Drives: One of the baddest handling Gen 5s Join Date: Feb 2011
Help with my dragstrip experience
At New Hampshire Epping dragstrip I am running mid 13s with hot tranny and hot 200 degrees coolant temps all day in 70 degree weather with just a no tune Vararam maybe 335-350 whp still less than Ls3. The things is with the crapomatic, I mean automatic, I can't rev before takeoff or anything , a Pontiac G8 maybe GXP nosed me out lastnight with a low 13.2 vs my 13.5. Also my car always feels somewhat restricted at the strip like TM is really holding me back. At the strip my car never threw me back into the seat, however on the street it does in a very violent manner, could this be the heat killing my performance, this is after a 70 mile drive to the strip, sign in and then hit the track asap, with a 10 min cooldown for sign in only. With the button shifters or full auto car runs the same time. Would a tranny cooler, 160degree Tstat, Linelock help , I already have BMR trailing arm and LSRs toe link arm, wheel hop mimimized, stock 60lb plus wheels and tires crappo Pirellis . This strip is listed to be 90 feet above sea level, does this hurt.
05-28-2011, 07:59 PM | #2 |
Drives: 2010 Camaro 1LT/RS M6 Join Date: Nov 2007
Did you hold down the Traction Control button for 7 seconds to turn off all the nannies? I'm thinking a transmission tune would help you more than anything.
Trifecta tune, Vararam Intake, VMAX throttle body and manifold insulator, RxPerformance Catch Can, , MRT v1.0 and Louvers, Barton shifter, BMR strut tower brace, RED dome light and Plasma LED DRL's, fieldgoal00's Halo 1 harness, hood spears/side stripes, rain guards, custom bowtie, Team LLT badges, headlight and foglight covers, taillight and side marker covers, backup light covers, WeatherTech floormats
05-28-2011, 08:08 PM | #3 |
This was a couple of weeks ago, I am number 642 on the right, I tried all traction options, all on being the slowest by a hair. Stabilitrac Competitive mode was the best, 8sec hold down resulted in wheelspin and not good 60ft. This is a copy of my best run with Vararam no tune intake and Janetty tune,( For CAI intake) this was a test, however even this run the L99 tranny shifted very very slow and felt like a 15sec time, turned out to be a 13.1 at 108mph. . This is the things though, when I first installed the tune 5 days prior , with the Vararam the car ripped like a freaking retard, however by Friday 13th 2011 (date of this run), 5 days, 300miles later the car got slower, this tune wasn't meant for the Vararam the install was only a test, but on the first day, Dammmmmmmmm is all I could say, weird to say but it felt too damn fast to know what the hell is going on, it would push me back in the seat and keep me there until I let off literally. If I had been to the strip with the tune just installed and I posted a low 12s time I wouldn't have been surprised.
05-29-2011, 08:31 AM | #4 |
Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
First off (70 degrees and 90 ft elevation track) = pretty good conditions
So you should be able to run low 13s with a decent 60' time. What are your 60' times? The first 60' is the most important part of the run. I've always run with TC off (that's it). I use either D or M letting the computer do the shifting and my car has always run good times. Also Show up early and let your car sit (open your hood) and cool to prevent a heatsoaked engine. To launch, do a brake stall launch (1000 rpms) rolling into the gas. With a decent 60' time (around 2.0) you should pull easy low 13s in 70 degree air. And I wouldn't talk down about the automatics. My car only has 352 rwhp (dyno jet) and it ran 12.1 @ 114 mph. So an L99 A6 doesn't need the same RWHP as the LS3s to run fast times. A big part of that is Torque management. Once you get your car tuned (by a skilled professional) you'll be a lot happier with your automatic. |
05-29-2011, 08:44 AM | #5 |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
Have to agree w/SGO. Also, if your serious about going quick in the 1/4 mile a torque converter and Phil from Tampa Tuning tweaking the tune and you wont believe its the same car.
05-29-2011, 08:57 AM | #6 |
Why can't you hold the brake and gas at the same time before launch and release the brake and launch?
05-29-2011, 09:41 AM | #7 |
Drives: 2010 Camaro Join Date: Jun 2009
My car runs 13.2's with a Roto-Fab CAI, no tune. Perfect everything (weather, launch holding my mouth right, etc), I believe it will go into the teens.
You may also want to try different air pressures. And I drive about an hour to the track then park the car for about 45 minutes. Andy
2SS/RS L99 IOM GFX Painted Blk Stripes
05-29-2011, 05:20 PM | #8 |
Oh how can I forget I was supposed to contact those guys about 2 months ago about a Tranny tune .
05-29-2011, 05:23 PM | #9 | |
05-29-2011, 08:15 PM | #10 |
Drives: '69 SS Convertible Join Date: May 2009
160 T-stat will help keep some of the temps down. Do the generic heater hose relocation and take the engine cover and turtle shell off. This will help let it cool down between runs which you should be letting it do.
Like others said though the converter is going to help a lot on the L99.
Build Journal |
Similar Threads | ||||
First negative experience with my Bumblebee. | Plainfield | Off-topic Discussions | 97 | 09-25-2010 03:52 PM |
My Experience with AAC | mtdew | Vendor and Seller review / feedback / experiences | 0 | 07-20-2010 03:11 PM |
My frustrating experience with dealers | cj21tol | Camaro Price | Ordering | Tracking | Dealers Discussions | 31 | 07-19-2010 09:31 PM |
The Best Buying Experience Ever! | DrumDawg | Camaro Price | Ordering | Tracking | Dealers Discussions | 5 | 10-20-2009 03:07 PM |
