06-15-2011, 07:19 PM | #1 |
Drives: jealous vendors mad!! HAHA!! Join Date: Jan 2011
E85 TUNE RESULT!!(UPDATED 8/9)
Post edited 6/20
The final result was 284/291HP(ASE corrected) and 244/250TQ(ASE corrected). The e85 made 7.5% more power at peak vs gas. The rest I will leave it up to you guys to figure out. I dont want to stir up anything other than the result so I wont get into speculating what is the "total gain" in my opinion. This is on a dynojet 248x which is known to read low with long tube header, no cats, and full exhaust. Still factory intake UPDATE: AUG/9 I've done lots of changes since the first dyno result. Since then, I've got rid of the factory intake and added vararam intake, tuned out the vararm intake according to the new AFR and fuel trims, reworked on the timing from running 34* of total timing(dyno graph is with 34*)and dropped to more conservative timing at 25*. Have not had a chance to redyno the car and test the new timings but after carefully reviewing the recent torque based timing curve it def show that the car look to be the happiest around 26*, and the car feel alot stronger and faster. we moved the AFR back to 11:5 from 10's. Running richer just made the car smell like alcohol and went through the tank much quicker with no noticeable change in power at all. With all the change, I made a 1/4 mile run at the track and it def show overall improved gain with run time of 13.5@104. The calculation put me right around 320rwhp at the moment and possibly could be even more if I could have made better 60' but the best I could do with stock 20's was 2.1 At this time the only thing left to do is to get back on dyno and rework the timing based off what we know now Dynojet Research Inc. Run NameYNO RUN FILES\E85 MINUS 2 02.drf Run Title: Run Notes: Run Date: 6/19/2011 E85 MINUS 2 s RPM x1000 hp ft-lbs Air/Fuel 0.38 2.55 N/A N/A 13.17 0.63 2.70 124.76 242.69 12.61 0.89 2.85 131.76 242.82 12.67 1.15 3.00 139.48 244.18 12.77 1.40 3.15 145.54 242.67 12.90 1.67 3.30 150.95 240.24 12.97 1.92 3.45 157.66 240.01 12.93 2.18 3.60 164.26 239.64 12.96 2.43 3.75 171.77 240.58 12.98 2.70 3.90 179.39 241.58 12.98 2.96 4.05 184.26 238.95 12.96 3.22 4.20 188.75 236.04 12.96 3.49 4.35 194.83 235.24 12.92 3.75 4.50 202.44 236.27 12.88 4.02 4.65 210.21 237.42 12.87 4.28 4.80 217.21 237.67 12.87 4.55 4.95 222.56 236.14 12.84 4.82 5.10 229.90 236.76 12.78 5.08 5.25 238.34 238.44 12.78 5.35 5.40 244.32 237.63 12.69 5.61 5.55 251.29 237.80 12.65 5.87 5.70 257.11 236.91 12.65 6.15 5.85 262.14 235.35 12.65 6.43 6.00 264.96 231.93 12.64 6.69 6.15 270.93 231.37 12.68 6.97 6.30 276.32 230.36 12.67 7.26 6.45 279.25 227.39 12.62 7.54 6.60 281.23 223.79 12.46 7.84 6.75 282.69 219.96 12.44 8.14 6.90 282.49 215.03 12.38 8.45 7.05 281.84 209.96 12.39 8.78 7.20 277.86 202.69 12.35 --------- --------- --------- --------- --------- MAX: 8.78 7.20 282.69 244.18 13.17 MIN: 0.38 2.55 124.76 202.69 12.35 -------------------------------------------------------------------------------- Dynojet Research Inc. Run Name: TRIFECTA GAS TUNE01.drf Run Title: Run Notes: Run Date: 6/19/2011 2:25:39 AM TRIFECTA GAS TUNE01.drf: s RPM x1000 hp ft-lbs Air/Fuel 0.76 2.10 93.71 234.37 13.24 1.26 2.25 100.52 234.63 12.96 1.77 2.40 105.73 231.39 12.82 2.28 2.55 111.19 229.01 12.70 2.80 2.70 120.28 233.97 12.72 3.31 2.85 126.78 233.63 12.78 3.82 3.00 133.34 233.43 12.69 4.34 3.15 139.29 232.24 12.49 4.83 3.30 146.59 233.31 12.53 5.33 3.45 155.29 236.41 12.44 5.85 3.60 162.10 236.49 12.47 6.35 3.75 171.76 240.56 12.50 6.84 3.90 176.74 238.02 12.51 7.36 4.05 182.24 236.34 12.50 7.87 4.20 186.03 232.63 12.49 8.39 4.35 191.40 231.09 12.47 8.92 4.50 197.97 231.06 12.43 9.44 4.65 201.65 227.77 12.44 9.98 4.80 207.07 226.57 12.42 10.52 4.95 214.63 227.73 12.45 11.05 5.10 223.28 229.94 12.40 11.58 5.25 230.69 230.78 12.40 12.11 5.40 237.42 230.92 12.44 12.65 5.55 244.33 231.22 12.42 13.19 5.70 246.63 227.25 12.37 13.74 5.85 251.29 225.61 12.27 14.25 6.00 254.29 222.60 12.28 14.87 6.15 255.69 218.36 12.27 15.43 6.30 258.06 215.13 12.28 16.03 6.45 258.53 210.51 12.26 16.63 6.60 261.87 208.39 12.24 17.23 6.75 262.44 204.20 12.23 17.88 6.90 260.36 198.18 12.20 18.51 7.05 259.97 193.68 12.18 19.21 7.20 254.21 185.43 12.07 19.89 7.35 249.62 178.37 N/A --------- --------- --------- --------- --------- MAX: 19.89 7.35 262.44 240.56 13.24 MIN: 0.76 2.10 93.71 178.37 12.07 Last edited by bmorecam; 08-09-2011 at 06:52 PM. |
06-15-2011, 07:31 PM | #2 |
Drives: 11 F150 EB/13 Sonic RS/15 Z06 Join Date: Sep 2010
I'm a little shocked by the torque, it should have gone up more than that. 13 sounds too lean to me, too. Since that looks like it was down low, then I'm wondering if he's over compensated to make sure he doesn't run out of fuel up high. Don't know!
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread |
06-15-2011, 07:36 PM | #3 |
Drives: Green Dream Machine Join Date: Mar 2011
Was hoping for the big 300.
06-15-2011, 07:52 PM | #4 | |
Also, remember that this dyno read lower than others. According to the owner I could have easily seen HP number up in the 290's++ Once I get the VR installed I will post up some 1/4 mile times. The trap speed should defenitely tell me how much power I am really pushing |
06-15-2011, 07:57 PM | #5 |
Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
Don't sweat it man!! You've done more than your fair share for the V6 community.
284 HP on a dyno which typically reads lower than some others...call me impressed! I am a bit suprised on the TQ, as I was almost thinking that might be the big gain since you seemed to feel it so much in your "butt dyno"..but hey who knows what happened. Did the car still feel strong as ever on your drives today? If you datalogged your dyno runs, then I'm bettin there are some tweaks to be made. Just wait until you get that Vararam and have it on for awhile and allow your ECU to adjust itself to that...then tweak your tune again, and you should be looking at an easy mid to upper 290s...and again on a dyno that supposedly reads a bit lower than some. The 300 number is not lost yet!
2010 Camaro 1LT V6 (Sold. I will miss her!) |
06-15-2011, 07:57 PM | #6 |
Drives: 2010 2SS/RS Coupe Join Date: Feb 2011
good work. i'm sure you were expecting a lot more out of it, but at least we got some info out of this. i'm sure vince can still do some more tweaking and find some more. thanks for being the guinea pig!
2010 CGM 2SS/RS
06-15-2011, 08:19 PM | #7 |
Hail to Pitt
Drives: 2016 Charger R/T Scat Pack Join Date: May 2011
Not bad on the power. I expected more torque gains than power though. Does look a little lean to me.
I'm a little confused though. You didn't dyno today with the gas tune did you?
Current: 2016 Charger R/T Scat Pack
Past: 2011 Camaro 1LT/RS IBM, 2006 Cobalt SS |
06-15-2011, 08:30 PM | #8 | |
06-15-2011, 08:37 PM | #9 |
I guess it all depend on how seriously you take dyno numbers. If I would have dynoed on a dyno that read 250-265 stock numbers than what number do you guys think I would have come out with? Probably 290+ and maybe even 300.
Unfortunately, I've used low reading dyno that dyno stock cars anywhere from 230-245. Also, if we would have checked off smooth to anything other than raw data at zero, I would have got 4-5 more ponies. Another thing you have to look at is the peak numbers. Nobody drive their car at over 6000 rpm. The number I posted is the highest number at the highest rpm band. The reason why I feel so much power in the lower rpm is because of change in peak tq. The peak tq is now at 3000 rpm and damn near start at 2000 rpm. This is due to change in valve timing. Hopefully some of you can now get a better understanding with looking at the dyno |
06-15-2011, 08:49 PM | #10 |
look at the tq only starting at 2600k rpm!! stock cars are like in the 190-200 ish starting at 2600rpm??
s RPM x1000 hp ft-lbs Air/Fuel 0.47 2.60 120.04 242.48 12.81 0.64 2.70 124.79 242.75 12.61 0.81 2.80 129.55 243.01 12.63 0.97 2.90 134.08 242.82 12.71 1.15 3.00 139.48 244.20 12.77 1.32 3.10 143.67 243.41 12.85 1.49 3.20 147.54 242.16 12.95 1.67 3.30 150.96 240.26 12.97 1.83 3.40 154.96 239.37 12.95 2.01 3.50 159.97 240.05 12.93 2.18 3.60 164.28 239.67 12.96 2.36 3.70 169.59 240.73 12.98 2.53 3.80 175.17 242.11 12.98 2.70 3.90 179.39 241.59 12.98 2.87 4.00 182.80 240.02 12.96 3.05 4.10 186.03 238.31 12.95 3.22 4.20 188.73 236.01 12.96 |
06-15-2011, 08:52 PM | #11 |
Drives: Really Slow Join Date: Apr 2010
I'm a bit dissapointed in the results. Was hoping for a larger gain. I'll keep an eye out on your progress though. good luck. I may switch mine as well, if the gains get better, and as soon as i get my nitrous worked out.
06-15-2011, 09:00 PM | #12 |
Drives: 2011 LS Join Date: Oct 2010
Yeah it is also summer probably not going to get ultimate numbers. Still pretty good. I might have won the award for closest guess after all. lol I am sure you are feeling that lower end torque which your butt dyno probably loves and I am sure makes the car much more fun to drive. Thanks for all you are doing. Many will benefit I am sure.
06-15-2011, 09:14 PM | #13 |
Slow Turtle
Looks completley normal. Torque is huge increase, that motor just peaks early, so it's misleading. 3-4% is all E85 is worth over gasoline, and that's about what you're seeing.
The car is super lean, though. Like, oh my god it's going to blow up lean. Get that fixed. You're WAY out of the ballpark. The reason your timing is ****ed up (yes, -2 retard is WAY ****ed up) is because you don't have enough fuel. Add a shitload of fuel, and add timing with it, and your engine will not only run safer, your power will increase. PS: Get a tuner who has a clue about ethanol.
06-15-2011, 09:32 PM | #14 |
Back on the dino-juice
Drives: '10 LS + a few more Join Date: May 2010
You sir have no clue
I wake up in the morning and I piss excellence.
-Ricky Bobby America is all about speed. Hot, nasty, badass speed. -Eleanor Roosevelt, 1936 |
Similar Threads | ||||
Finally, E85 tune is in!!! | bmorecam | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 206 | 06-15-2011 07:25 PM |
HP Tune question | Darth_Emma | Tuning / Diagnostics -- engine and transmission | 40 | 06-15-2010 09:42 AM |
Drawbacks to a mail order tune | herkman | Tuning / Diagnostics -- engine and transmission | 24 | 05-28-2010 05:27 AM |
Lets play a game | 2SSRS@Gen5diy | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 56 | 09-26-2009 09:08 AM |
Undetectable Tunes - What You Should Know | kelley@vectormotorsports | V8 Bolt-Ons & Tunes | 159 | 09-18-2009 02:18 PM |
