Old 03-24-2009, 02:40 PM   #1
perfxn
Drives: 2SS RS
whats this mean? 1st-to-4th skip-shift to deal with when you walk it from a stop
you have an obnoxious 1st-to-4th skip-shift to deal with when you walk it from a stop? Edmunds. Is this a problem or normal thing? i apologize for my ignorance. and thanks for those who respond
perfxn is offline   Reply With Quote
Old 03-24-2009, 02:44 PM   #2
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
There's a solenoid the PCM controls that physically blocks the driver from shifting from 1st into second and 3rd under light load conditions. This means unless you are on the throttle less than a certain percentage, you can only shift from 1st to 4th. I believe it was only active the first time you left from a dead stop and only reactivated after coming to another complete stop, but don't recall exactly. I dealt with it on my LT1 for a couple weeks until I got the eliminator kit. I think it was less than either 1/4 or 1/3 throttle opening. You should be able to tune it out and there may still be eliminator kits out there that will work.
BTW - there's no ignorant question
'20 ZL1 Black "Fury"
Old 03-24-2009, 02:49 PM   #3
2Scoops
2Scoops's Avatar
Drives: 2010 Camaro 2SS/RS
One of the first things I get rid of....
SGT Earl D. Werner - 28AUG2009, KIA, Ramadi, Iraq
SPC Taylor D. Marks - 28AUG2009, KIA, Ramadi, Iraq
CPT Bruno DeSollenni - 20SEP2008, KIA, Kandahar, Afghanistan
Rest in peace my Brothers.
2SS/RS MN6, Cyber Grey Metallic w/ Black Rally Stripes
http://twoscoopscamaro5.mybrute.com
2Scoops is offline   Reply With Quote
Old 03-24-2009, 02:50 PM   #4
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Thanx rads, I didn't know either. I got the Auto so I just looked over it.
Old 03-24-2009, 02:59 PM   #5
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
It's almost just flat-out silly to deal with. I'd like to see if the eliminator kits are out there though for these 6060s. Either way, I'm sure a quick tune will get rid of it; you might as well, because that speed limiter needs to go bye-bye too, LOL (after getting more suitable tires...)
You know, with six-speeds, that auto' looks really great in my eyes. If there is any performance disparity between the auto' and stick I think another tune with shift speed, firmness, and pressure along with some Torque Management manipulation will work wonders. It sounds like it works for the G8 boys.
Old 03-24-2009, 03:01 PM   #6
perfxn
Drives: 2SS RS
thanks for the info! by ignrance i was talking about the lack of knowlegde in that area, i also agree about the no bad question thing.
Old 03-24-2009, 03:02 PM   #7
perfxn
Drives: 2SS RS
what is the point of this system?
Old 03-24-2009, 03:04 PM   #8
CamaroSSforme
Got my two
CamaroSSforme's Avatar
Drives: 2010 Camaro SS/RS - RJT/Black
Send a message via Yahoo to CamaroSSforme
To make you ask questions
(it just had to be said)
CamaroSSforme is offline   Reply With Quote
Old 03-24-2009, 03:04 PM   #9
zebra
just can't seem to leave
zebra's Avatar
Drives: your mom wild!!
it avoids the gas guzzler tax
ps - this has been discussed in great detail in a few threads around here.
for those who are new - there's a on the top-right that has proven very useful
Eve ('00 FRC): hot-air intake
Old 03-24-2009, 03:32 PM   #10
mousemotor
Drives: 2010 camaro ss,pontiac G6
my 2000 Z-28 had this skip shift, bought the slp skip shift eliminator, easy install, no more 1st to 4th.
mousemotor is offline   Reply With Quote
Old 03-24-2009, 03:46 PM   #11
Nimzoblanca
Nimzoblanca's Avatar
Drives: 2006 Pontiac GTO M6
Save $20. Instead of the skip-shift eliminator, get a resistor from Radio Shack. $1 for a pack of 5 (I still have 4 available!). Jack up car. Crawl under. Remove skip-shift solenoid connector. Insert Radio Shack resistor in each hole of connector. Seal it up with black electrician tape. Use tie-wrap to secure loose wire.
Problem solved.
Current toy: 2006 GTO, 6M, Quick Silver exterior, black interior, 17" wheels. Modifications:
  • Kooks 1 3/4" coated LT headers
  • SLP Loudmouth II catback
  • GMM Street w/ LSS
  • Volant intake
  • SLP 455 Bobcat tune
  • SAP grills
  • Elite Engineering Catch Can
  • CAGS bypass (Radio Shack resistor)
Previous toys:
2001 Trans Am convertible, WS6, A4.
1967 Corvette Coupe, 427/435 HP, 4-spd, 4.11 rear, factory original tri-carbs.
1979 Corvette, L82, 4-spd, 3.70 rear.
Nimzoblanca is offline   Reply With Quote
Old 03-24-2009, 04:30 PM   #12
Kelster
Kelster's Avatar
Drives: Many
How many ohms?
"Every government interference in the economy consists of giving an unearned benefit, extorted by force, to some men at the expense of others.”
Ayn Rand
Kelster is offline   Reply With Quote
Old 03-24-2009, 04:33 PM   #13
Mindz
E.B.A.H.
Mindz's Avatar
Drives: you wild...
Aren't stocks P-zeros from Pirelli?
Old 03-24-2009, 04:36 PM   #14
Nimzoblanca
Originally Posted by Kelster View Post
How many ohms?
I'll have to check when I get home. The remaining 4 resistors are in my garage. I guess that means I need to buy 4 more six-speeds!
  • GMM Street w/ LSS
  • Volant intake
  • SAP grills
Previous toys:
Skip Shift? cam2fst4u 5th Gen Camaro SS LS LT General Discussions 65 04-03-2009 02:01 PM
Performance Numbers - Skip Shift fireresq157 5th Gen Camaro SS LS LT General Discussions 16 03-23-2009 12:59 PM
