Old 11-07-2011, 04:00 PM   #1
bmorecam
MACE's Intake Insulator/High Flow's Ported Intake Manifold
UPDATED NOV 14TH
I went in to dyno with my AFR in the 11's, and my timing being pulled 11-12* from 4k rpm to red line, and with a port mismatch. All this will be taken care of on my next dyno but here is tonight's result. Still very very impressive!
The result.. "peak", 9hp and 13lb ft of tq..I guess ok, and the good part, "off peak" almost all across the range, 20lb of ft tq and 18hp Not bad
Today's dyno condition(nov 14th) 71F, 41%, 29.82 Pressure(274rwhp, 259rwtq)
(baseline)Last dyno condition(oct 11th) 69F, 79%, 30.07 Pressure(265rwhp, 246rwtq)
As you can see the condition was almost identical for both of the time.
Do you guys remember the e85 dyno? check the comparison. The same 20ft lb of tq gain over e85.
I thought I was not going to get everything until later this week but boy did the mail man bring me a surprise
The first part of the project is all here. Mace's cold air intake insulator and High Flow's stage 3 ported intake manifold.
I will go ahead and update you guys as I go through the install, first impression, and finish with the dyno.
For now I guess I will let the pics speak for itself
SOME OF YOU REQUESTED, "LLT INTAKE MANIFOLD REMOVAL AND INSTALL PROCEURE"
1. Remove the fuel pipe shield. Refer to Fuel Pipe Shield Replacement .
2. Remove the air outlet duct. Refer to Air Cleaner Outlet Duct Replacement .
3. Disconnect the brake booster vacuum hose (1) from the intake manifold.
4. Disconnect the positive crankcase ventilation (PCV) hose (1) from the intake manifold.
5. Disconnect the purge line (1) from the intake manifold.
6. Remove the purge solenoid bolt (1) from the intake manifold and set the purge solenoid aside.
7. Disconnect the throttle body electrical connector (1).
8. Remove the intake manifold bracket bolt (1).
9. Unclip the engine wiring harness from the intake manifold.
10. Remove the intake manifold bolts (1).
11. Remove the intake manifold and gasket.
12. If replacing the intake manifold, disassemble the intake manifold. Refer to Intake Manifold Disassemble .
1. If installing a new intake manifold, assemble the intake manifold. Refer to Intake Manifold Assemble .
2. Install the NEW intake manifold gasket.
3. Tighten the intake manifold bolts in the sequence shown (1-6).
Caution: Refer to Fastener Caution .
4. Install the intake manifold bolts (1) and tighten to 25 N·m (18 lb ft).
5. Clip the engine wiring harness from the intake manifold.
6. Install the intake manifold bracket bolt (1) and tighten to 23 N·m (17 lb ft).
7. Connect the throttle body electrical connector (1).
8. Install the purge solenoid bolt (1) to the intake manifold.
9. Connect the purge line (1) to the intake manifold.
10. Connect the PCV hose (1) to the intake manifold.
11. Connect the brake booster vacuum hose (1) from the intake manifold.
12. Install the air outlet duct. Refer to Air Cleaner Outlet Duct Replacement .
13. Install the fuel pipe shield. Refer to Fuel Pipe Shield Replacement .
Old 11-07-2011, 04:05 PM   #2
usa1camaro1969
Back on the dino-juice
usa1camaro1969's Avatar
Drives: '10 LS + a few more
Feel like you're starting to tease us with this stuff.
I wake up in the morning and I piss excellence.
-Ricky Bobby
America is all about speed. Hot, nasty, badass speed. -Eleanor Roosevelt, 1936
usa1camaro1969 is offline   Reply With Quote
Old 11-07-2011, 04:07 PM   #3
PsychoZL1
PsychoZL1's Avatar
Drives: 2015 Challenger SRT
Looking forward to seeing your results! BTW, what size did you go with for the intake insulator?
PsychoZL1 is offline   Reply With Quote
Old 11-07-2011, 04:10 PM   #4
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
OH
EM
GGGGGGGGGGGGGGGGGGGGGGGGG
CAMARO
Old 11-07-2011, 04:12 PM   #5
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
with the 5inch insultaters LOL
CAMARO
Old 11-07-2011, 04:18 PM   #6
bmorecam
I originally got the 6mm, but mace also sent me 12mm to test fit on our camaro since the 12mm had fitment issue on the aussie's LLT. So I plan to put both together and test fit 18mm. If it fit.. it should give the best result. For a reference, the 23lb ft of tq or over 10% gain that mace got on their alloytec was with 12mm.
Old 11-07-2011, 04:38 PM   #7
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
Oh man I'm excited!
BaylorCamaro is offline   Reply With Quote
Old 11-07-2011, 04:45 PM   #8
bmorecam
Originally Posted by BaylorCamaro View Post
Oh man I'm excited!
Yhea, I think it's about time we have some excitement around here. Just wait until hp tuners and cams happen. Things are going to change Pretty fast and competition is going to get rough.
Old 11-07-2011, 04:50 PM   #9
OOLIE
OOLIE's Avatar
Drives: 2011 LS
yeah this wakes things up a bit. Can't wait to hear your results.
OOLIE is offline   Reply With Quote
Old 11-07-2011, 05:03 PM   #10
10RsCamaro
Slow v6
10RsCamaro's Avatar
Drives: Automatic Automobile
Send a message via Skype™ to 10RsCamaro
Full bolt on 2lt/Rs. Any questions? always a pm away!
Obx/Mace/Rx/Mrt/Vararam/Bcam/4.11 Gears/SS Brakes
USAF. Stationed in TX
10RsCamaro is offline   Reply With Quote
Old 11-07-2011, 05:38 PM   #11
LadyinBlue
LadyinBlue's Avatar
Drives: 260HP/242TQ
What 10RsCamaro said!
LadyinBlue is offline   Reply With Quote
Old 11-07-2011, 05:41 PM   #12
3859c1
Drives: 1997 Pontiac Grand Prix GTP L67
Looking good! I'm ready to port some more!!!
3859c1 is offline   Reply With Quote
Old 11-07-2011, 06:05 PM   #13
KMPrenger
KMPrenger's Avatar
OOoooooooo....so purty.
Old 11-07-2011, 07:09 PM   #14
mydreamcar
My Dream Car
mydreamcar's Avatar
Drives: 2011 SIM LS3 1SS
CAI intake/ADM Scoop/Stainless Power Headers/Dynatech cat back exhaust/Vitesse Throttle Control/ Ported Throttle Body/QTP Electric Cutouts/ 3.91 gears and janetty rear posi/ Tuned by Janetty racing
mydreamcar is offline   Reply With Quote
Anyone Dyno'd with a Ported Intake Manifold? TitoSS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 04-04-2011 08:48 AM
Ported intake manifold antivenom Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 52 10-20-2009 09:50 AM
