11-11-2011, 12:13 PM | #1 |
need....more....hp
Drives: The Neighbor Hater Join Date: Dec 2010
LS3/L76 3 bar MAP sensor??
Where is the best place to buy one of these? Would a dealership or parts store carry one of these?
Mast Motorsports Built LS3 Stroker 418, IPS GT35R Twin Turbos, Exedy GTO4XD Twin Disc Clutch, Aeromotive A1000 Eliminator Stealth Fuel Pump, AEM Meth Injection, DSS 1400hp Axels, BC Coilovers, Pfadt & BMR Suspension, Hawk HPS Pads, Drilled/Slotted Rotors, Hurst Shifter, Custom Roll Cage by Blu808, T3 Ports, 22" Custom Concave Mesh Rims |
11-11-2011, 12:24 PM | #2 |
Drives: 550+RWHP 2010 camaro Join Date: Sep 2007
dealership around $40, change these settings in your tune to make it work:
zr1 map part # 12592525 Map sensor linear: 312.50 kpa Map sensor offset: -11.25 kpa
11-24-2011, 07:01 AM | #3 |
Drives: 2006 twin turbo Corvette Z06 Join Date: Nov 2011
I use the sensor that camaro1 listed in every boosted LS3.
12-11-2011, 11:04 PM | #4 |
would it be better to run ZR1 map sensor or change these settings??
Map sensor linear: 312.50 kpa Map sensor offset: -11.25 kpa |
12-12-2011, 06:38 AM | #5 |
these changes need to be made when you use the zr1 sensor they will only work with the zr1 sensor
12-12-2011, 09:35 AM | #6 |
instigator
Drives: 2020 6.2 Trail Boss, 2022 XC90 Join Date: Jan 2010
is this in the same place as the ls1...back of the manifold? lol...I never paid attention.
-John S.
12-12-2011, 09:48 AM | #7 |
on the ls3 intake, it is on the front/top. but you only need this zr1 sensor if your running boost,, on the magnacharger they relocate the map sensor to the bottom rear passenger side of the magnacharger base.
Similar Threads | ||||
5th Gen Suspension -- The Book | JusticePete | Suspension / Brakes / Chassis | 151 | 05-07-2015 05:52 PM |
irpq11 has permagrin...updated with vids..... | PQ | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 198 | 01-15-2014 12:23 AM |
ZR1 MAP Sensor | the rich dude | Forced Induction - V8 | 13 | 04-16-2012 04:52 PM |
Looking for a ZR1 MAP Sensor | WhoMadeWho | Forced Induction - V8 | 28 | 08-04-2011 07:25 AM |
Acronyms? | KEEP RT | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 20 | 03-11-2011 08:57 PM |
