View Poll Results: how long will you warm up your 5th gen on a cold morning
wont 51 54.26%
5min 32 34.04%
10min 10 10.64%
10min plus 1 1.06%
Voters: 94. You may not vote on this poll
Old 04-24-2009, 08:10 PM   #1
perfxn
Drives: 2SS RS
How long will you let her warm up for? or him
Im not sure with a new car how long or if you even need to let it warm up? Lets use 60 degree day and a 35 degree day?
perfxn is offline   Reply With Quote
Old 04-24-2009, 08:15 PM   #2
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
till it goes into closed loop
I piss excellence
and fart awesomeness
Old 04-24-2009, 08:16 PM   #3
ShnOmac
ShnOmac's Avatar
Spike you just made his mind $hi! itself......
ShnOmac is offline   Reply With Quote
Old 04-24-2009, 08:17 PM   #4
ljustin293
ljustin293's Avatar
Drives: 2010 VR CAMARO 2SS/RS
Old 04-24-2009, 08:20 PM   #5
perfxn
Drives: 2SS RS
whats closed loop?
Old 04-24-2009, 08:21 PM   #6
ShnOmac
ShnOmac's Avatar
Here ya go
"Do not over-idle when starting. Even at -18°C most cars only require 15 to 30 seconds of idling before being driven. The engine and drivetrain warm up better when your car is in motion. However, drive gently until they are warm".
http://www.gm.ca/inm/gmcanada/englis...r_Vehicle.html
Old 04-24-2009, 08:23 PM   #7
zzz28zzz
zzz28zzz's Avatar
Drives: 2010 Chev Camaro 2SS/RS VR -
I am usually running late for .... well anywhere that I go so
warming up the car is not much of an option for me
zzz28zzz is offline   Reply With Quote
Old 04-24-2009, 08:25 PM   #8
Nexus6
More human than human
Nexus6's Avatar
Drives: 2010 IOM 2SS/RS
Originally Posted by perfxn View Post
whats closed loop?
Closed loop mode means that the ECU will compare the measured air/fuel ratio to the target air/fuel ratio and automatically increase or decrease fuel delivery accordingly. In open loop mode, the ECU will still use the oxygen sensor to read air/fuel ratios, but will not adjust fuel delivery as in closed loop mode.
1100 - 10/22/2008
3000 - 05/27/2009
3300 - 06/06/2009
3800 - 06/29/2009
4B00 - 06/29/2009
Warehouse 13 survivor
Blood stains,speed kills,fast cars,cheap thrills,rich women,fine wine,i lost my sense i lost control i lost my
mind.
Nexus6 is offline   Reply With Quote
Old 04-24-2009, 08:25 PM   #9
THE EVIL TW1N
Banned
Drives: 2003 Cobra Convertible
Here ya go
+1
More engine wear occurs by letting the car idle vs. just driving it (but with little load).
THE EVIL TW1N is offline   Reply With Quote
Old 04-24-2009, 08:32 PM   #10
CamaroSpike23
Truth Enforcer
I have that effect on people.
whats closed loop?
open loop: A mode of operation in a computerized engine management system that occurs after a cold start. During open loop, the computer provides a fixed air/fuel ratio that is richer than normal to improve cold derivability until the engine warms up.
Closed loop: In closed loop operation the ECU uses one or more oxygen sensors as a feedback loop in order to adjust the fuel mixture. This gives the name ‘closed loop’ from the closed feedback loop. The ECU won’t run in a closed feedback loop all the time, so ‘open loop’ is used to describe the operation of the ECU when the mixture is not being adjusted in this way (usually when the engine is cold or when running under high load).
In closed loop operation the ECU uses the oxygen sensor to tell if the fuel mixture is rich or lean. However, due to the characteristics of the oxygen sensor it can’t tell exactly how rich or lean, it only knows that the mixture is richer or leaner than optimum. The ECU will enrich the mixture if the oxygen sensor shows that the mixture is lean, and lean the mixture if it looks rich. The result of this is that the mixture will swing back and forward around the stoichiometric point.
when you are in open loop (first starting the car or WOT) the computer disregards signal input (for the most part) from the o2 sensors and a couple others until a set of parameters are met. what this means is that when you first start the car, it runs richer than normal because it cant measure the exhaust at all until the o2 sensors are warmed up. once they warm up, or the coolant temp reaches a specific temp, or the system times out, it will go into closed loop and start taking readings from the o2 sensors in an attempt to balance the air/fuel ratio.
I piss excellence
Old 04-24-2009, 08:33 PM   #11
New2010CamaroLover
New2010CamaroLover's Avatar
Drives: 2015 Ashen Grey Metallic 2SS/RS M6
Same here... But I'll be making a better effort once i get the car. Even if it only takes 30 seconds and warms up better when in motion I'll take the loss on the gas to ensure it's warmed up. You never know... Mustangs like to roll up on you early in the morning, trying to catch you off guard... Fbod would be disappointed if we weren't prepared!!!
"The Golden Age of muscle cars was not 30 years ago, it's now, long live the Camaro!"
New2010CamaroLover is offline   Reply With Quote
Old 04-24-2009, 08:37 PM   #12
10redrocket
Drives: 2SS Camaro LS3
I always let the coolant temp hit 100 degrees before I move the vehicle.
RECEIVED 5/22/09 - 2SS, SIM with CGM stripes, Black Leather, Polished 20's, Sunroof, LS3.
Past Rides: 69 Camaro RS Small Block
67 Chevelle SS Big Block
05 Cobalt SS Supercharged
07 Cobalt SS Supercharged
10 Camaro 2SS LS3
Soon: 18 Camaro 2SS 1LE
10redrocket is offline   Reply With Quote
Old 04-24-2009, 08:50 PM   #13
dodson914
Drives: 2008 2500 HD; 2008 G8 GT #199
Enough time for me to find a radio station, get situated and put my seatbelt on.
dodson914 is offline   Reply With Quote
Old 04-24-2009, 08:58 PM   #14
Hillbilly
Rider of the short BUS
Hillbilly's Avatar
Drives: Ukon/F350(work)/Intruder800
A couple hours should do it. NOT all according to ambient.
SIM with CGM rallieshttp://www.creativegraphicsvinyldesign.com/images/SIM1.jpg
Hillbilly is offline   Reply With Quote
Music for the Maiden Voyage? LSxcellent 5th Gen Camaro SS LS LT General Discussions 1088 05-27-2012 11:43 PM
Ordering issues in New York, long island silvrcamro010 Camaro Price | Ordering | Tracking | Dealers Discussions 38 04-19-2009 10:58 PM
Camaro5 T-Shirts, Long Sleeve, Sweatshirts, Hoodies FOR SALE!!! (CLOSED) TAG UR IT Camaro5 Store Merchandise 122 03-31-2009 12:06 PM
So how long before..... Prospect20 Camaro Price | Ordering | Tracking | Dealers Discussions 18 01-27-2009 05:04 PM
So how long does this stuff normally take??? Wedgy 5th Gen Camaro SS LS LT General Discussions 27 03-18-2008 01:10 AM
