View Poll Results: if you definitely want a cylinder please chose V6 or SS. need to figure out how many
I own a V6 20 20.83%
I own a V6 but will wait for a core exchange 7 7.29%
I own a SS 50 52.08%
I own a SS but will wait for a core exchange 21 21.88%
Multiple Choice Poll. Voters: 96. You may not vote on this poll
Old 03-28-2012, 09:07 AM   #1
IDEALG
Chevy's "Rumble" Best!
IDEALG's Avatar
Drives: 2015 ZL1 6 speed
Send a message via AIM to IDEALG
Project clutch master cylinder/second gear grind
I'm working on a fix for our crappy clutch master cylinders. I'm going to make this one flow more fluid and i'm going to test it in my own camaro.
If this works as it should, it should eliminate our high rpm second gear grind. machine shop is hard at work, i will be updating as soon as i get it back together.
UPDATE: INSTALLATION VIDS http://youtu.be/l8vacHyCInw 1st one
http://youtu.be/txlMf92EX4k 2nd one
This is the link for purchasing the cylinders
www.jerryspeedshop.com
This is another link showing you the bleeder location and few extra tips.
http://youtu.be/x5edLIp2CoM
Edit - 4/28/2015 THIS IS AN OLD THREAD WITH A LOT OF POSTS SO IF YOU DON'T WANT TO READ THROUGH IT ALL JUST GIVE ME A CALL OR PM ME IF YOU HAVE ANY QUESTIONS
list of interest
toml_pa
GTAHVIT
BigCarrot
Heliwrench
Inferno LS3
IndeedSS1
1977and2010
flht99b
stieger
Synner
mrgm
jrrod6410
gjarzabek009
VanquisherSS
Jayrcr3
Mach
nak3dsnake
600hp-lpe
CyberPredator
MiSTER
octane
rakanet
SSE 4 2SS
bcarkle
piticu667
Hendrix-Engineering
11SynergyGr&Bl
calbert1999
2011Camaro
Blue70SS
Nick Boulin
jmaynard
bmoney
Aries240SS
DandD
Retro69
RacnJsn95
BackinBlack
Phat Ralph
JTRJSS
IDEALG is offline   Reply With Quote
Old 03-28-2012, 09:09 AM   #2
Heliwrench
Heliwrench's Avatar
Drives: 2010 Black 1SS
2010 Black 1SS LS3 M6
Power: Kook's 1 7/8" Long Tubes and 3" Exhaust, Injen Full Length CAI, Jannetty Tune
Drivetrain: MGW Short Shifter, Street Slayer Twin Clutch, DSS 1 Piece Aluminum Driveshaft, DSS 1000HP Axles, BMR Pro and Delrin Diff Bushings
Suspension: BMR Trailing Arms and Bushings, FE6 Swaybar Conversion With Pedders 27mm Front and 32mm Rear ZL1 Swaybars and Links
Chassis: Hotchkis Chassis Max Brace, BMR Pro Cradle Bushings
Exterior:: Shine by Adam's.
...and plenty more
Heliwrench is offline   Reply With Quote
Old 03-28-2012, 09:58 AM   #3
toml_pa
ʇuɐıʌǝp lɐıɔos
Drives: 2011 2SS/RS LS3/M6
Subscribed.
toml_pa is offline   Reply With Quote
Old 03-28-2012, 10:03 AM   #4
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
Old 03-28-2012, 10:31 AM   #5
IDEALG
IDEALG's Avatar
I got it back already! ok now i need to test it. It might be a few days before i get to test it im not sure yet , i have a lot of work to get done here at the shop. as soon as possible i will get it installed and post the results
Old 03-28-2012, 11:37 AM   #6
1stGM
1stGM's Avatar
Drives: IOM 2SS/RS M6
2010 2SS..LS3..Procharger..4l80e..DSS 9"
1stGM is offline   Reply With Quote
Old 03-28-2012, 06:59 PM   #7
1977and2010
Tampa Gulf Coast Family
1977and2010's Avatar
Drives: 1977 Z28, 2SSRS 2010 M6
Watching this for sure.
1977and2010 is offline   Reply With Quote
Old 03-28-2012, 07:31 PM   #8
Nessal
Drives: Exige, Miata, Ghia
You make it and they will come....
Nessal is offline   Reply With Quote
Old 03-28-2012, 07:34 PM   #9
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
Watching this.
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 03-28-2012, 07:47 PM   #10
IDEALG
IDEALG's Avatar
i got it installed, got all the air bleed out of it. hopefully tomorrow i will have time to test it.
Old 03-28-2012, 07:48 PM   #11
Fishdadddy
Fishdadddy's Avatar
Drives: 2010 2SS/RS ; 1970 Firebird Formula
HMMMMM? Berry Interesting
Fishdadddy is offline   Reply With Quote
Old 03-28-2012, 08:50 PM   #12
sschevybear11
sschevybear11's Avatar
Drives: 2011 Black 1SS
I don't think its a clutch issue but nice work.
2011 Black 1SS M6 12.75@110.91 bone stock
Now: Coated Dynatech LT's/!Cats/Hurst Shifter/Roto-fab/SLP SS badges/JRE 415HP Tune, Scoop & Washer Relocation Bottle,Hurst Stunner 20X9 Wheels, Moroso Catch Can, ASP pulley, Magnaflow X-pipe, GTO remote clutch reservoir
1989 Silver 5.0 Mustang LX Coupe
1999 Pewter Tahoe LT
2011 Blue Camry SE
sschevybear11 is offline   Reply With Quote
Old 03-28-2012, 08:59 PM   #13
IDEALG
IDEALG's Avatar
i need to be sure so were going to find out for sure with real tests not just theories
Old 03-28-2012, 09:04 PM   #14
The Stig
knows 2 facts about ducks
The Stig's Avatar
Click to view my build thread
Rear End Gears 101 danhr V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 92 06-02-2021 04:17 AM
2nd gear grind issue and updated GM parts (pics) Oxtar41 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 67 03-04-2015 10:11 PM
GTO Clutch Reservoir Install terry_b Camaro DIY & HOW-TO instructions & discussions 68 06-13-2014 07:46 PM
V6 AY6 M6 2nd Gear Problem - Report Your Issue Here CAMAR0 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1606 10-25-2012 03:18 PM
Street Slayer brought to you by Hendrix Engineering Hendrix-Engineering Transmission / Driveline 2 12-08-2011 02:55 PM
