Old 04-06-2012, 04:48 PM   #1
insomniac2k2
Drives: 2012 2SS/RS IOM
Did I just fix most of my drivetrain chatter?!
So I decided to do a little experiment after i climbed under my car looking for possible reasons why there could be so much drive line chatter and "weirdness" with the clutch/shifting. I was also looking for the reason for a knock that was making my ecu pull timing. As it wasn't a real knock, i figured it must be exhaust, or drivetrain..
Here's what I found:
My cross-member bolts were loose. If I were to guess, there was probably only 5-10lbs of torque on them. So i snugged them up a bit.
Then i looked at everything further. Eyeball clearances between my exhaust and body were way off from side to side. You could see this all the way up to the manifolds. The passengers side had a ton of clearance and the drivers side had very little. After further inspection, it seemed quite possible that my engine was out of alignment.
Out came the jack stands...
I loosened the crossmember bolts on the body and from the transmission. After I loosened the last bolt, I gave the transmission a nice little knudge. It quickly shifted towards the passenger side about an 1/8". That was about exactly half of the clearance difference between the 2 sides of the engine and exhaust. So i decided to loosen top and bottom bolts on both motor mounts for a "formal" adjustment.
Being that the exhaust and engine was indicating the same miss-alignment, I just eyeballed the engine and transmission, using manifold to body clearance on both sides. Tightened it all up and took it for a half hour drive.
This could ABSOLUTELY be placebo, and time will definitely tell if things stay better, but as of this moment, I notice a big difference on a few things. My driveline chatter is much quieter and I have yet to get the awful driveline unloading noise that irritates the crap out of me. No matter what I did, if I depressed the clutch at low speed, It would sound like I was driving a garbage truck with all the clanking!!
Here's the kicker. I havent felt the weird knotching between first and second gear (which is grinding when the car is cold...) yet. I will know for sure if anything changed there in the next few days. As it's very consistent....
I would never really imagine that all these "issues" could be caused by a little drivetrain miss-alignment. Is this possible???
insomniac2k2 is offline   Reply With Quote
Old 04-06-2012, 04:50 PM   #2
Driveshaftshop
Driveshaftshop's Avatar
Drives: own more cars than i can list
The Giubo joints on the shaft need to be aligned or they push and pull, if very possible they were part of the problem.
Driveshaftshop is offline   Reply With Quote
Old 04-06-2012, 05:01 PM   #3
insomniac2k2
Interesting. I REALLY hope that this was my issue. I never really gave it much thought when swapping motors and transmissions in my old schools. I would just line them up and bolt away. Never really "Felt" anything bad or different by doing so this way.
I cant wait to get more time behind the wheel to see if some things are truly better. It would certainly suck if this was all placebo
Old 04-06-2012, 10:24 PM   #4
insomniac2k2
Just got back from a 2.5 hour round trip drive. I am still very happy with the results. Way less chatter, and still have yet to feel the second gear notch. I will try and give it a go first thing in the morning when the transmission is cold.
Old 04-06-2012, 10:43 PM   #5
Run and Gun
Run and Gun's Avatar
Drives: 2011 1SS/RS , 1966 GTO
A machine for shrinking time and distance.
Run and Gun is offline   Reply With Quote
Old 04-08-2012, 10:36 PM   #6
insomniac2k2
Another 3 hours of driving today. Chatter is greatly reduced, and It hasn't felt like its pulling timing. Time for some data logging to confirm this.
Old 04-11-2012, 02:00 PM   #7
TJeezey
Drives: 2011 SS/RS M6
subscribed
2011 IOM SS/RS M6 w/Hurst. C.A.I. inc Intake, Borla ATAK catback, ARH LT's with HFC, Vmax TB, Apex Scoop, 91 oct Jannety Tune
TJeezey is offline   Reply With Quote
6L80E with stall converters tcc fix camaro1 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 8 10-24-2010 08:06 PM
clutch sticking halfway fix? GQ4Life V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 3 10-13-2010 12:20 AM
LS3 M6 Clutch chatter jordan 572 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 12 10-04-2010 06:34 PM
What happens if dealer can't find and fix problem? CamaroC-17 5th Gen Camaro SS LS LT General Discussions 9 08-14-2010 06:04 PM
To fix or not to fix... heyomayo 5th Gen Camaro SS LS LT General Discussions 55 07-30-2010 09:13 AM
