Old 05-09-2009, 01:34 AM   #1
blackedout010
Drives: on order black 2010 2ss
how wide can we go???
for those of you who already have your cars. has anyone checked or looked to see how much room we have in the rear for wider meats?? im goin with some iforged or cor wheels. im wanting 20's in rear 325's vette style.
blackedout010 is offline   Reply With Quote
Old 05-09-2009, 12:55 PM   #2
Rallyman6
Member
Rallyman6's Avatar
Drives: '10 2SS/RS IOM, Wht Stripes, Roof
Does anyone have the true offset and the hub dimensions?
Most important to be true hubcentric.
Not just a range.
2SS/RS IOM, Wht Stripes, 6MT, IO Interior, Roof, Eibach Sways, BC Coilovers, BMR Swing arms,Barton Short Shift, BBK LT's, GMPP exhaust, Hi-Flow Cats, MAST Stage 2 Cam, CAI = 470RWHP
Rallyman6 is offline   Reply With Quote
Old 05-09-2009, 04:37 PM   #3
gunslinger
Drives: 1998 Z28 M6
Not just a range.
What does hubcentric mean?
Does that mean the middle of the tire is on the same plane as the middle of the rim?
GTR: Get Transmission Replaced
gunslinger is offline   Reply With Quote
Old 05-09-2009, 04:58 PM   #4
UsedTaHaveA68
UsedTaHaveA68's Avatar
Drives: Hyundai Sonata
It means it uses the hub of the axle to center the wheel rather than the wheel studs. It's more accurate that way.
UsedTaHaveA68 is offline   Reply With Quote
Old 05-10-2009, 03:59 PM   #5
ADM PERFORMANCE
Drives: Anything I want
YOU CAN GO 315/35 20 ON THE REAR AND 275 40 20 ON THE FRONT
WWW.ADMPERFORMANCE.COM - HAS THEM !
ADM PERFORMANCE is offline   Reply With Quote
Old 05-14-2009, 02:11 PM   #6
SilverBulletSS
SilverBulletSS's Avatar
Drives: 2004 R/Cab F-150
But what are the offsets???
Future: 2SS/RS M6 Silver Ice Metallic
SilverBulletSS is offline   Reply With Quote
Old 05-16-2009, 07:15 AM   #7
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
Same as above - what offset ?
I assume you meant a 315 will fit with zero mods, correct ?
Thanks.
Old 05-16-2009, 09:29 AM   #8
blackedout010
Thanks.
i was wondering the same thing!! if so if you did a lil trimming on inner fender would 325's fit??
How big of a tire do you think you can put in the stock 9" wide rims? alex33x Wheels and Tires Talk Sponsored by The Tire Rack 3 04-12-2009 09:47 AM
How Wide in Inches are Tires? Scott@Bjorn3D Wheels and Tires Talk Sponsored by The Tire Rack 8 02-17-2009 03:00 PM
How wide can go on rims? GCguy2169 Wheels and Tires Talk Sponsored by The Tire Rack 23 08-06-2008 11:01 AM
Is the Camaro as wide as the specs indicate? rolnslo 5th Gen Camaro SS LS LT General Discussions 31 03-18-2008 10:48 AM
