Old 05-13-2009, 03:12 PM   #1
TheMadHatter99
Kept the Faith
TheMadHatter99's Avatar
Drives: '10 Camaro 2SS/RS CGM
DIY: How-To Disable Skip Shift
The guys at CadillacFAQ hacked together a replacement quick-disconnect plug which replaces a part of the same with one loaded up with a resistor as jumper to fake the system into thinking the servo is still in the circuit. All it takes is a replacement plug bought from the local parts store (here a "Conduct Tite" male end connector part number 85307 - $2.99) the pins to load into that connector ( "Conduct Tite" inserts, part number 85317 - $2.99), a 2.2K ohm 0.5 watt resistor from Radio Shack which costs about $1, some solder, electrical tape and time. The hacksters here soldered both ends of the resistor into the pin inserts after crimping them on, then bent the resistor for insertion into the plug housing.
Here they just leave it bare and insert it into the connector leading to the transmission, leaving the servo unpowered, then they tape it all together with duct tape and call it good. We'd probably get a vacuum cap and stick it over the end, then seal it further with heat shrink wrap, but that's just us. In any case, for seven bucks you no longer have the annoyance of your transmission wrestling some amount of control from you. Now perhaps Krewson will grant the Pontiac G8 GXP that final star in the transmission department. [CadillacFAQ]
http://jalopnik.com/5252686/how-to-d...or-seven-bucks
TheMadHatter99 is offline   Reply With Quote
Old 05-13-2009, 03:14 PM   #2
theshadow1234
theshadow1234's Avatar
Drives: Shelby GT500
Will this VOID the warranty?
09 Shelby GT500
(Stock)
theshadow1234 is offline   Reply With Quote
Old 05-13-2009, 03:20 PM   #3
Nezacant
Nezacant's Avatar
Drives: 2010 Camaro 2SS/RS
Warranty void?
Edit: Wow I'm Slow.
Proud owner of a Black 2010 2SS/RS Chevy Camaro.
Nezacant is offline   Reply With Quote
Old 05-13-2009, 03:21 PM   #4
camaro5's Avatar
Drives: X-15 Velocipede
If you're going to the dealer for tranny service, remove this first, and restore to stock, as they can void the waranty if the dealer or manufacturer wants a way out.
CAGS Skip Shift Eliminator - $15.99
http://www.pfyc.com/p/VT6001/
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to, any warranty of merchantability
or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 05-13-2009, 03:27 PM   #5
BlackRaptor
BlackRaptor's Avatar
Drives: 08 GMC Sierra, 07 G6 GT
If you want this level of control why not just go manual
*edit* this isn't me trying to step on anyones feet just a question.
BlackRaptor is offline   Reply With Quote
Old 05-13-2009, 03:30 PM   #6
Phenix
Drives: 2015 Camaro 1SS/RS 1LE
It IS the manual that has CAGS
Phenix is offline   Reply With Quote
Old 05-13-2009, 03:32 PM   #7
trudawg660
Drives: 2006 Dodge Charger / 2SS IOM
The skip shift is with a Manual.
trudawg660 is offline   Reply With Quote
Old 05-13-2009, 03:33 PM   #8
BlackRaptor
oh i thought this was something for the auto tranny tap shift to let you have better control over shifts.
So the manual won't let you skip gears if you want to?
Old 05-13-2009, 03:37 PM   #9
Camar0wn3d
formerly "wh0rsep0wer"
Camar0wn3d's Avatar
Drives: 2016 1SS Summit White
Anyone know if a 4th gen Skip-shift (CAGS) eliminator will work in a 5th gen? the connectors look very similar
2010 1SS/RS - CGM/Gray Interior - M6 (SOLD) Kooks 1 7/8" headers, Solo Mach-X, Vararam.
2012 2LS - Black A6 (SOLD)
2016 1SS Summit White A8
Camar0wn3d is offline   Reply With Quote
Old 05-13-2009, 03:38 PM   #10
LabRat
Drives: Wheeled Vehicles
That's the point!
It MAKES you skip gears!
GOOGLE SKIP SHIFT
LabRat
LabRat is offline   Reply With Quote
Old 05-13-2009, 03:39 PM   #11
Danno
Danno's Avatar
Drives: 1993 Trans Am, 2007 Acadia
Shamelessly copy/pasted from www.bfranker.badz28.com/96ss/skipshift.htm
CAGS stands for Computer Assisted Gear Selection and is on 1994 and on cars with 6 speed transmissions. It's purpose is to improve gas mileage and avoid the "gas-guzzler" new car tax. CAGS comes into play under the following conditions:
* you're in 1st gear (of course)
* you're at 35% throttle or less
* you're between 15 and 21 mph
* engine coolant temperature is greater than 171 F (77 C)
This will energize the skip-shift solenoid and force a 1st to 4th shift. What happens is you'll be moving happily along when suddenly the "Skip Shift" light goes on in the dash. At this point you will be locked out of 2nd and 3rd. You simply cannot shift into them.
US Navy retired submariner.
previous cars, starting with my first.
1970 Nova
1967 RS/SS Camaro
1969 Chevelle
1970.5 Camaro
A long, undistinguished line of sedans, SUV's, and minivans.
Danno is offline   Reply With Quote
Old 05-13-2009, 03:39 PM   #12
rolnslo
Rolling along...
rolnslo's Avatar
Drives: 2011 2SS/RS SGM
...So the manual won't let you skip gears if you want to?
Sure, you can skip gears with the manual if you want. The skip-shift "feature" (ahem) forces you to go from 1st to 4th in low-throttle conditions to help fuel economy. Give it more gas and you can go from 1 to 2 to 3 to 4 without interference.
rolnslo is offline   Reply With Quote
Old 05-13-2009, 03:39 PM   #13
Camaro509
Camaro509's Avatar
Drives: 2010 2SS/RS Black
No, the manual 6-speed transmission, in low RPM situations prevents you from shifting from 1st to 2d or 3rd gear, instead forces you to go from 1st to 4th gear.
If you drive with gusto, it allows you to take advantage of all the gears.
Understeer, Oversteer, Wheel Alignment (Camber etc), Torque, Horsepower, Camaro
Fold for team 11108 to help find a cure!
Folding@home Stanford's Research DC Program.
Camaro509 is offline   Reply With Quote
Old 05-13-2009, 03:40 PM   #14
rolnslo
Rolling along...
rolnslo's Avatar
Ha ha...Did you get the answer BlackRaptor? (in triplicate+1).
V6 Skip Shift? B.A.Brunswick V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 10 10-08-2010 10:42 AM
TUNE and Skip shift eliminator SSCamaro2010 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 05-12-2009 09:15 AM
skip shift Old School Chevy 5th Gen Camaro SS LS LT General Discussions 13 04-18-2009 11:44 AM
Skip Shift? cam2fst4u 5th Gen Camaro SS LS LT General Discussions 65 04-03-2009 02:01 PM
Performance Numbers - Skip Shift fireresq157 5th Gen Camaro SS LS LT General Discussions 16 03-23-2009 12:59 PM
