Old 09-02-2012, 04:20 PM   #1
jordan 572
jordan 572's Avatar
Drives: none
416ci single turbo, What size?
As of now I have an ls3 with the turbonetics kit, I was pondering replacing the rods and pistons when I add a jre cam but was thinking of maybe just hopping to the 416 stroker kit. Obviously the 68mm turbine wheel couldn't handle the cubic inches so I was think of running a mid frame style turbine housing turbo from turbonetics but this limits me to 78mm compressor and 75mm turbine wheel, this would probably be on the small side again. What size turbo would be suitable for a 416 single setup? This will help me determine other changes that would need to take place and help me decide if I even want to got this route.
jordan 572 is offline   Reply With Quote
Old 09-02-2012, 05:16 PM   #2
outlawprostreet
outlawprostreet's Avatar
Drives: 2012 Turbo SS
T6 is the best bet. The problem is where to fit it. Precision makes a PT8847. .96 T4, 88mm compressor, and 84mm turbine.
LS3 M6 w/ Turbonetics stage 1 turbo kit
Huron Speed twin 64's waiting to be installed
outlawprostreet is offline   Reply With Quote
Old 09-02-2012, 05:38 PM   #3
killmode_on
Drives: 2011 2SS/RS
If you go single and you don't want to have backpressure limitations, you have to go T6. BW S480 is prefect. But then how do you fit it, and how do you run a large enough single exhaust pipe out (4" minimum). I think twins are the way to go, especially on these cars. Easy to fit a pair of 700hp turbos in the right locations and right plumbing. Having the turbos mounted without the long u-turn piping you currently have, would spool much faster too. My pair of 56mm turbos with 61mm turbines, gets full boost about 3000rpm in the mid gears and can support ~1000whp.
killmode_on is offline   Reply With Quote
Old 09-02-2012, 06:06 PM   #4
JLE58
Drives: CGM,twin turbo, cam 2010 SS/RS
Jordan just stick with the 376... Also there are companies that produce turbos that have better suited turbines and exhaust housings than turbonetics. Either way adding 40 more cubes doesn't help in finding a turbo that will fit.
JLE58 is offline   Reply With Quote
Old 09-02-2012, 06:46 PM   #5
camarostar2010
Drives: 2011 SS
get twin gt35's then u can boost up 1400 whp, and have no drivability issues IPS turbos is my way too go..check them out.
camarostar2010 is offline   Reply With Quote
Old 09-02-2012, 06:48 PM   #6
pouncer72
Drives: 2011 Camaro SS
Send a message via AIM to pouncer72
88mm t6, or a BW S480 with the race cover
pouncer72 is offline   Reply With Quote
Old 09-02-2012, 09:42 PM   #7
jordan 572
jordan 572's Avatar
Drives: none
Took the words out of my mouth, after reading the first few posts I will for sure stay with what I have. Like others mentioned I was going to maybe try a midframe since the downpipe is only I believe a half inch or inch bigger. Ill stay with what I have and just add a cam and maybe max out boost at 9-10 psi and call it good for REAL. I'm going to start saving my money for a diesel pickup, make twice the power as my car literally for half the money. I am more of a truck guy too but love fast cars still. Thanks everyone for the input.
Old 09-03-2012, 06:37 AM   #8
HufferSS
I Wanna Go Faster!!
HufferSS's Avatar
Drives: 2011 2SS Synergy Green M6
Wow..twice the power for 1/2 the money? I'd like to hear how you plan on accomplishing that.
Built by Vengeance Racing
9.31@154.81 mph
Procharger F1-X
RPM Level 7 4L80e + Coan Converter
Hendrix 9" Rear Axle + 3.50 Gear
ARH 2" LTs+3.5" Exhaust
Fore Fuel System, Bogarts + Hoosier Slicks
Pfadt Drag Pack Suspension
My Build Thread | Best Pass To Date
HufferSS is offline   Reply With Quote
Old 09-03-2012, 06:40 AM   #9
Whipped416
Whipped416's Avatar
Drives: 2010 CAMARO SS
me too.. should be interesting
Whipped416 is offline   Reply With Quote
Old 09-03-2012, 11:39 AM   #10
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Maybe read on threads about MightyMouse's car, Dave Childress. If memory serves he's run a single T4 88mm and maybe then a T4 91mm. Went 8.4's I think.
We've run twin 76 T4's to 7.4@195, and most recently 4.75@160 in the 1/8th. On an LS 427.
If you are just sourcing turbos that fit your existing kit I'd for sure look at an 88mm turbo.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 09-03-2012, 02:13 PM   #11
jordan 572
jordan 572's Avatar
Drives: none
Minus the price of the truck itself might want to look at this. When I mean twice the power I am comparing to my car not yours although I would bet these trucks put down more torque than yours, can't touch the horsepower you have though.
http://www.hsperformance.com/ford-6-...-dyno-results/
All you need is 1000 tuner, 500 exhaust, 400 intake and there you have it. About a 1/5 what I have spent and about a 1/100 what others have. 582 & 1287 (mustang dyno) at the wheels with roughly a 12''-15'' lift on 40's. My brother has the same setup, (but on 35's) Powerstroke (international) power leaves your D-max behind.
Old 09-04-2012, 11:00 AM   #12
TitoSS
TitoSS's Avatar
Drives: 2010 Camaro 2SS Red Black Int. L99
I have that same turbo on my car check out my thread it fits trust me lol Nelson Performance Precision 88mm Turbo Build
"L99 K&N Intake, V-Max TB, Kooks 1 7/8 Non Catted, Magnaflow 16483, SCT Tuned by Jannetty !!!" Best 1/8th mile time 8.45 without cat back. Kenne Bell get's here 4/19/11
TitoSS is offline   Reply With Quote
Old 09-04-2012, 11:18 PM   #13
SRT10KLLR
Drives: 2010 Camaro 2SS/RS
Get yourself a Comp 80/70 with Triple BB , Billet compressor wheel and the new Stainless turbine housing.
Compared to the Garrett GT76
2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
2004 Dodge Ram SRT-10 - Silver - Stock
2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting Turbo
SRT10KLLR is offline   Reply With Quote
Old 09-05-2012, 08:11 AM   #14
jordan 572
jordan 572's Avatar
Drives: none
I'm staying at 376. Like that last picture show off.
